No, I like my preamp) It's not an electronics issue, apparently even Trinnov cannot fully solve it. I'll try some room treatments, but my options are extremely limited: it's a living room with only 3 walls.The PX25 is quite a good meaty tube. Did you change anything else in your system, like preamp etc?
Not yet. Do you think, that 45s may have more body, than PX-25? How about PX4?Did you try any 45s? NOS ones are not that expensive and they might go into direction you need...
You may be right, I have Mundorf, but I had the same issue with my old L4, which had Duelunds, so it is the room issue. Room is the king.I always found the Mundorf and the new Lampi cap dacs to have less body than Jupiter and duelund dacs
PX4 I have I would not say it goes into this direction while 45 (at least NOS) might do the trick to some extent. But room you can't play around with tube tricks I would say so rather try room treatments. U boat 211 just said the sameNot yet. Do you think, that 45s may have more body, than PX-25? How about PX4?
Thanks, I'd rather not do any digital correction in the signal path. That in my view defeats a purpose of having a SET based system with high efficiency speakers. The speakers are not dipoles. The system is in the living room combined with an open kitchen. So, there is no side wall on the right speaker side. Maybe that explains poor matching.Between about 100 to 500 Hz you are appreciably down in output by around 5 DB ish. But you have loads of bass.
I'd use a digital EQ package to bump that region up. I recommend Equaliser API and the Peace GUI but you'll need some very basic understanding to use it.
That will only work for digital sources with a laptop.
You could use some digital x-overs instead and that will work with all sources.
Room treatments are not really going to cut it IMHO.
Are these speakers dipoles? Pair matching looks poor but how much is due to the room I cannot say.
Io Signature. Still waiting for delivery of Eclipse.Which phono do you have in your system now?
