Robert Koda Takumi K160
Marcus
604
701
1,155
New power amp from Robert Koda with interesting technical solutions.
https://audioexotics.vanillacommunity.com/discussion/13089/robert-koda-s-ground-breaking-amplifier-??-takumi-k160-mono-amplifier
150W / 8 ohm @ less than 1% THD (any mode)
230W / 4 ohm @ less than 1% THD (high power mode)
120W / 2 ohm @ less than 1% THD (high power mode)
Signal to Noise
105.5dB (A weight) @ 1W into 8 ohms. 125.5dB at 100W into 8 ohms
Distortion
0.0009% at 5 watts into 8 ohm, 1KHz.
0.005% at 50 watts into 8 ohm, 1KHz.
Power consumption
550W at all times (high power mode)
400W at all times (normal mode)
Output impedance
0.05 ohms at 1KHz (damping factor is 160)
Input impedance
Greater than 10K ohms (SE, balanced or floating)
Voltage gain (SE, balanced or floating)
26dB
Weight: 45Kg per unit after unpacking
Dimension: 540mm deep 396 wide and 280 highrux9gewcydiu.jpg
Reactions: Addicted to hifi
Robert Koda has always had fascinating designs and musically involving sound you don't hear often. I really enjoyed my K10 preamp while I owned it...I bet this amp is amazing
John, I trialled the K10 for a couple of weeks, and every visitor to me swore it was a top quality tubed preamp. If Robert has found magic again in producing a Class A SS power amp that has that tube signature vibe, he will truly be a modern day alchemist.
Reactions: jfrech
Jazzhead has a K15, and Shakti has one
Fantastic! Are you going to audition?
Signal to Noise
Distortion
Power consumption
Output impedance
Input impedance
26dB
Given that it comes from a family of extremely well regarded, highly nuanced designs...i do wonder how it would sound compared with the Gryphon which is also a high powered Class A SS design.
The new old Luxman amps I have do a very convincing job of not sounding SS like. More so than any SS amps I have tried. And better than any valve amps I have tried to boot.
Just saying.
Reactions: howiebrou
Justin, for me the K10 was "too much". I found its effervescent technicolor presentation a little overbearing. And it seemed to slow music down, not in the sense of sluggishness or lack of PRaT, more this zen sense of being "in the moment". For me this was hugely attractive at the start of the trial, but not self effacing enough after 2 weeks.
In my new system that now sounds a million miles better than the one I trialled the K10 in, in a way better room, it would be intriguing to hear it again, or the K70.
Certainly the tuneful fleshed out and non hurried sound of the K10 or 70 thru this Koda SS amp that can also do the "I can't belive it's not tubes" trick would be fascinating.
What is the RRP of the new amplfier
Amadeus should know the price.;) He’s a great Koda fan and owner of K15 Ultimate line stage and K70 power amps.
Reactions: amadeus
Some people I respect a lot praised the Koda 10 and 5 a lot. What is the RRP of the new amplfier?
150k$ , seemingly limited to 5 pieces a year
The K160 has arrived at the Divin Lab of Audioexotics in Hong Kong.
https://audioexotics.vanillacommuni...mplifier-匠心-takumi-k160-mono-amplifier#latest
