darTZeel NHB-468 mono blocks in my system
Mike Lavigne
Apr 25, 2010
12,471
11,368
4,410
Congratulations Mike. Yes, just as you begin to get used to a new turntable drive type or LT tonearm, these new amps come in and elevate the overall sound to a new level. Your system now seems less stable than mine does (joking).
Two questions: Could you please elaborate on how these sound more "tube like" than your previous amps? And, I don't see lights on the active isolation platforms under the amps. Is that normal for in use operation? I thought they always had lights indicating the corrections taking place.
I look forward to reading your thoughts as these break in and you get a better handle on their sound. I suspect they will also let you appreciate differences between your sources that much more than your old amps did.
I'm happy for you.
thank you Peter.
it was not by design to have new amps right now. honestly i'm somewhat unstuck with so many changes; 2 new turntables, 2 new cartridges, a new Durand Tosca tonearm plus the new CS Port linear tracker, new CS Port phono pre, the double Daiza addition to my digital, an upgraded King Cello phono repro, and a new Extreme server and digital network approach. that is the last 5 months.
and now new amps. that was not on the plan.
i'm enjoying it all, but am just started investigating most of it. and no idea when i'll get farther down the road.
i admire your very well thought out sane methods. i'm now going to have to focus on one thing at a time to find the source and system synergy. especially the tt/arm/cart/phono balancing act. that is chaos mostly.
back to the amps; obviously they are the kingpin to the whole system. i'm going to sidestep your 'how these sound more 'tube-like'?' question for now. maybe remind me in a week or so and i will try to elaborate. i'm working that out in my mind and need more music listening first. as far as the 'dark' lights on the TS-140 Tana platforms; you never miss a trick. two of my Tana power supplies are back at Taiko in the Netherlands for an upgrade; they should arrive back mid week. i can tell you that after those being under the 458's for a year, now that they are not doing their thing it's a big deal regarding how the music is affected. the smear and lack of focus and delicacy is profound. bass textures are diminished. nothing like removing something to make it clear what was going on. i'm not complaining that the music is not captivating, but my ears are aware of what could be. i'm very anxious to hear those Tana platforms added to the 468 equation. should be epic.
and agree on break-in and it's significance. it will be fun to enjoy the progress.
Mike Lavigne
Apr 25, 2010
12,471
11,368
4,410
spent the last 2 hours listening to the 468's and the CS Port + string quartets and Chamber Orchestra. what an absolutely delightful combination! i suppose the GFS, the CS Port linear tracker, and the CS Port phono pre should be added to that mix.
the 468's rich tonal palette, delicate nuanced textures and timbre, and overall refinement, ease and micro-dynamic energy really deliver the musical connection and flow. beautiful mid-range fire and sparkle. this type of music with solid state is many times riding the edge of brightness or glare with all the stings and higher frequency energy. the 468' take the beauty and ultra detail and ease of the CS Port and take things to a whole different 'tubes only' dimension, while retaining the low noise and linearity of solid state. this just grabs me and holds my attention.
never heard this music like this. i did listen to this with the ML3's, which had the beauty, but not quite the life and energy of what i am hearing. my mind is thinking i need to go find more of this music, even though i have quite a bit, as i will have a steady diet of it.
Reactions: jeff1225
redandgold
215
174
148
So if I get you well the 468s don‘t sound like tubes. They sound like it‘s own signature, but don‘t have the weakness in some points a normal solid state amp has. Strength of tube + SS = 468 without the weakness, correct?
Sounds like the holy grail. :)
Reactions: Mike Lavigne
analyzer
315
137
220
Torino - Italy
Mike... I'm Happy to hear your satisfaction.
You have certainly noted that the community of WBF has looked with attention and enthusiasm all the process of your decision.
We all are very interested to understand which kind the improvements you've reached since 458's were already among the holy grails (that most of us can't afford).
Happy listening with new amps!
Marco
Reactions: joeinid
bonzo75
22,448
13,475
2,710
London
"it's almost impossible to fairly compare 'uber' amplifiers. i tried a year ago and over 1000 posts could not agree that i did it."
- That was funny
Mike Lavigne
Apr 25, 2010
12,471
11,368
4,410
yes, when i step back and read what i have written it can be distilled down to that......based on 36 hours in my room so far.
the 468's don't sound like the darker, rounder part of tubes, or the closed in highs of tubes, or the slightly opaque rendering of tubes, or the sameness coloration of tubes, or the higher noise floor of tubes (not that all tubes are equally like those descriptors.......but most all have at least a touch of that in comparison with better solid state). but the 468's do have the 'breath of life' and textures and timbre of tubes, the rich tonal pallet of tubes, and the human touch, delicacy and ease of tubes. but without the constantly changing life cycle or cost of replacement of tubes. and of course, all the low noise, slam, authority and explosiveness of an uber solid state mega amp.
i've heard 45 tubes and 2a3's that did not sound like tubes either in those more colored references. so i know not all tubes are something that you hear through. but those tubes have other limitations. if you hook up the right horn's to those very pure low power tubes you can get a fantastic result. so there is that extreme and i've not really experienced that.
but i don't think tubes can fully connect the dots and put the whole package together like the 468's. just my opinion.
holy grail? mine for sure.:cool:
i guess i answered Peter's question too.
LL21
14,411
2,509
1,448
...the 468's do have the 'breath of life' and textures and timbre of tubes, the rich tonal pallet of tubes, and the human touch, delicacy and ease of tubes. but without the constantly changing life cycle or cost of replacement of tubes. and of course, all the low noise, slam, authority and explosiveness of an uber solid state mega amp...
holy grail? mine for sure.:cool:...
Awesome feedback, Mike. For [some] of us who love tubes and have migrated over to SS, I think that description sums up the goal perfectly. Well said. For my own budget and ears, the Mephisto has gotten me there. I know it may/may not have the elements you describe above for other tube lovers or for other SS lovers...nothing is perfect. But it works for me...and your stated goal is surely a very eloquent way to describe why. And great to hear how well the 468s have delivered this for you. Congrats.
Holli82
318
329
1,620
Nothing more satisfying than upgrading your system and realizing that you have a whole bunch of "new" music to listen to. Congrats and enjoy!
Mike Lavigne
Apr 25, 2010
12,471
11,368
4,410
+1
this morning i was listening to a number of classical digital pieces which i liked before and visit often; i realized how significantly better i was enjoying them now, and your comment is exactly what went through my mind.
this is the payoff, of course. it's cool when you are not consciously thinking about it and then it just hits you.
manjy
53
18
913
Congratulations Mike!
XV-1
3,591
2,576
1,860
Sydney
I thought the 468's sounded wonderful at the Philippines hifi show last weekend.
jeff1225
3,011
3,259
1,410
51
I listened to Marriner's Bach all day yesterday. These Philips recordings bring me a lot joy.
SuperDave
252
78
158
Texas
Congrats Mike, what a great Thanksgiving! Your description certainly raises an eyebrow, I need to check these out.
Dave
Mike Lavigne
Apr 25, 2010
12,471
11,368
4,410
Congrats, Mike. The perfection of the combination of many attributes clearly advances another major step.
- speed
- transparency
- detail
- ability to handle complex, multi-instrument easily
- dynamics (macro and micro, decay)
- extension
- effortlessness
- effortlessness at high volumes/low impedances
- sweetness
- liquidity
it appears these last two are really doing it for you with the 468s. We have all seen designers prioritize when ultimately, no component can be perfect, and so those priorities became the 'signature' of the sound. And yet, as designs advance, ultimately being able to excel in ALL areas must remain the goal. Sounds like Herve continues to be a leader in this regard. Enjoy.
agree no amp is perfect, the concept of perfect is just is not appropriate for hifi.
yet; an amp can perfectly (maybe fully is a better word) fit our expectations. and when i've spent more time getting to know the 468's they might just check all my boxes perfectly for me. it's looking like that. the liquidity and sweetness.....or whatever words you use.....it is a game changer.
Herve does seem to be ahead on this at this point. what he has done here has really touched me. and it does not matter the source or the music, what i'm hearing is profoundly special.
PeterA
12,523
10,688
3,515
USA
Mike, what do you think the active platforms will add further to your experience? You are describing the sound as more glorious than ever before, and this is without the active isolation. The impression I have is that the 458 + active < 468 w/o active. In other words, you have been comparing your new amps to the old ones with active isolation. I wonder what if anything that has to do with the more liquid "shouting tubes" sound signature you are now getting. From your past descriptions, the active had a dramatic effect on the amps' overall sound. I'd be very curious to read what you think after they return. When do you get them back?
Mike Lavigne
Apr 25, 2010
12,471
11,368
4,410
what they do is to 'clean up' textures and nuances that you never realized needing fixing and add focus. also, as the music gets intense and complicated they improve the ease and flow as everything stays coherent and organized. where this could get crazy good is all that extra texture, timbre, richness and weight that the 468's have added are going to be further expressed to some degree. and this should be immediately evident as there is no break-in time for this. i can turn it on and off and it hits you in the nose.
where will all that go? the active will have more information to work with.
yes....it could be a big deal......i expect it to be epic.:)
i'm anxious to hear that. they should arrive tomorrow......so tomorrow night hopefully if US Customs and fedex cooperate (they don't always :( as we know).
LL21
14,411
2,509
1,448
Fantastic. Put another way...magic. That's what its all about. Thats what MUSIC is all about. Nice one and look forward to reading more about the outer edge of the universe of high end audio!
