Magico A5 official announcement
Rhapsody
3,484
6,606
2,535
Brooklyn NY
rhapsody.audio
Rhapsody has a pair of A5's on order and will have them available for demo some time in Q1 of 2020.
Hayward, CA (USA) – December 6, 2019 – The largest and most advanced of Magico’s A Series, the A5 incorporates the company’s first 5-inch pure midrange driver as well as enhanced midrange and bass driver cone technology. These new cones achieve unprecedented stiffness-to-weight ratio, a key parameter that Magico has pursued over the past 15 years. In addition, the crossover debuts Mundorf’s new M-Resist Ultra foil resistors for unmatched transparency, liquidity and power handling. “The A Series has been a great success in reaching a wider audience,” said Magico’s founder, Alon Wolf. “The A5 builds on that success with a new 5-inch midrange of extraordinary musicality. And the A5 ‘plays larger,’ with powerfully extended dynamic range.” The three-way, five- driver floor standing speaker retains such Magico hallmarks as extensively cross-braced 6061 aircraft grade aluminum and Elliptical Symmetry Crossover. Finished in brushed black anodized aluminum, the loudspeaker will be available in the first quarter of 2020 at a suggested retail price of
$21,800/pair.
New bass drivers with advanced new sandwich cones
The 9” bass drivers of the A5 feature a newly enhanced version of Magico’s Graphene Nano-Tec cones. Graphene, a hexagonal lattice of carbon, achieves 50 times the tensile strength of high-carbon steel. The new cone design combines Graphene layered carbon fiber with advanced new core materials to achieve the highest possible stiffness to weight ratio. Thanks to extensive computer simulation and prototype tests, the driver chassis achieves an ideal combination of stiffness and damping, minimizing acoustical contribution and maximizing airflow. The new bass unit incorporates oversized components including a 5-inch pure Titanium voice coil and huge copper cap with 1?2” of linear excursion. The super-stabilized magnetic field enables the A5 to really thunder, producing 115 dB SPL (@ 50 Hz, 1 meter), while maintaining very low distortion and inductance below 0.18 mH. Finite Element Analysis (FEA) provides Magico engineers a single platform to assess acoustical, mechanical, electromagnetic and thermal properties. This meticulous testing helps minimize distortions in the frequency and time domains. Borrowed from the Magico M3 and M6, the triple bass driver configuration provides easy room integration, maximum distribution of the floor bounce effect and effortless reproduction of extreme musical peaks.
New five-inch pure midrange driver
The new 5-inch full-cone midrange driver enables wider dispersion and greater midrange transparency. Like the bass driver, the midrange also incorporates an advanced Graphene carbon fiber sandwich cone. A new foam surround helps achieve ideal cone/surround integration, faster settling time and impressively low distortion. The all-new motor system uses a pure Titanium voice coil. The super stabilized magnetic field and pure copper pole cap minimize eddy currents and maximize efficiency. This latest midrange driver sets new benchmarks of measured performance.
High frequency driver
Based on the fundamental design platform and geometry of the M-Series tweeters and shared with the other members of the A-Series, the tweeter incorporates a pure beryllium-diaphragm with an optimized 28-mm dome. Magico encases the customized neodymium motor system in an engineered back chamber with the company’s most advanced damping materials. This enables ultra-low distortion, high power handling, massive dynamic capabilities and extended linear voice coil movement.
Crossover debuts the Mundorf M-Resist Ultra foil resistors
Magico acoustically integrates all five drivers with the proprietary Elliptical Symmetry Crossover topology built with state-of-the-art components from Mundorf EB Gmbh of Cologne, Germany. The A5 will be the first product in the world to offer Mundorf’s new M-Resist Ultra foil resistors. Now perfected after years of development, the new resistors deliver greater power handling, transparency and liquidity. The 3-way network features a 24 dB per octave Linkwitz-Riley filter that maximizes frequency bandwidth while preserving phase linearity and minimizing intermodulation distortion.
Aircraft-grade aluminum enclosure
Weighing in at 180 pounds each, the A5 features a massive, sealed enclosure machined entirely of 6061-T6 aircraft grade aluminum, the same material and construction methods as in Magico’s acclaimed Q-Series. Complex internal bracing helps stiffen the entire enclosure and minimize resonance. A dedicated sub-enclosure houses the midrange driver, protecting it from the extensive back wave energy of the bass drivers. The aluminum has an elegant, brushed black anodized finish.
Driver Complement
1” Tweeter (x1)
5” Graphene Nano-Tec Midrange (x1) 9” Graphene Nano-Tec Bass (x3)
Specifications
Sensitivity:
Impedance:
Frequency Response: Recommended Power: Dimensions:
Weight:
Suggested Retail Price (US): Ship date:
88 dB
4 Ohms
22 Hz – 50 kHz
50 – 1000 Watts
10.5” (W) x 14.9” (D) x 44.75” (H) 180 lbs.
$21,800/pair
1st Quarter 2020
What's a "pure" midrange driver
Semantics (I think), just saying it is only producing midrange and not extending further down in frequencies as in some of the other Magico midrange drivers that go down into the bass region. That's just my thought, maybe it means something else. I will ask Magico when I talk to them.
JoeP -I posted the announcement again in a new thread here to get away from the comments that were being made in the post you referenced and to let people know that Rhapsody will have the A5 in Q1 available for demo.
Rhapsody does a considerable amount of Magico business. Not a problem for you or others to spend time commenting on the other referenced post.
Bob, thank you so much for your permission to comment in the "other referenced post."
I don't think I would travel 5K miles to hear this new $22K speaker in your show room:
https://rhapsody.audio/about-rhapsody-audio/
Hi Joe,
I totally respect your opinion about not being wife friendly. I get it and would never ask for you to not give your opinion.
Although when someone says that a speaker is not WF and I happen to have experienced literally hundreds of customers/visitors that one of the things about this line of speakers is that because of their ease of room placement from the sealed cabinets and they can fit in easily, wives usually REALLY like them, I feel obligated to offer my opinion as well. Your opinion, my experience.....nothing more than that.
Reactions: Joe P
