That is a very generous offer but you are aware that I am in Europe and shipping might be either slow or expensiveIf I do end up buying the FTA I will be happy to send the Sablon to you to try out.
Well let's wait for your verdict firstWell, the expense would be yours and I can deal with not having the cable for a month if I have a new one!
I just posted this in my Skogrand thread, and thought I'd post here too.......
I spent some time last night comparing USB cables. To hand I had both flavours of StavEssence, Skogrand Beethoven, FTA Callisto, Gekko USG-1, and a homebrew cable.
The first thing to say is that the differences here are pretty small, and if these tests were done blind I suspect you would fail to consistently pick each cable. That said, there were differences that seemed to be pretty consistent.
The homebrew cable had great dynamics but sounded too digital in this company.
The Gekko cable sounded shiny. It's silver in construct so may be knowing this influenced my hearing but none-the-less I wasn't keen.
The FTA Callisto has all the positive attributes talked about in the thread - has great air, musicality, and sounds very analogue. My initial impressions were incredibly positive. However, in comparison, you realise it is doing this by slightly softening the leading edge of notes and so blunts the attack somewhat of the music. If your digital side of things is not absolutely 1st class or emphasises detail, then this is likely a very good thing. However, in my system (LDMS server + reclocker, Lampizator GG2), it slightly robbed the music of something compared to Stavessence / Skogrand.
StavEssence - both great cables, maintaining the air of the FTA Callisto but with more dynamic attack to the music. There is a very small difference (to the extent it could be perception rather than fact) between Eunoia (smooth) and Apricity (dynamic), with my preference being for Eunoia.
Skogrand Beethoven - a small amount better than Stavessence in terms of sounding more natural in conveying the music.
Value-for-money then FTA takes it. All-out performance then Beethoven. My preference would be StavEssence.
What was the outcome of your compare?If I do end up buying the FTA I will be happy to send the Sablon to you to try out.
Which is the one you use and which is the one on the shelf?I have both the Callisto and Sablon. One sits on the shelf
What are your findings so far? Things will change with more mileage.
Thanks for the answer.I didn’t hear anything with the FTA that I preferred over the Sablon. In fact, I did not like the high end sound with the FTA. It was a little edgy, for lack of a better term.
I am really happy with the Sablon. I am waiting for the demo box so I can try out Mark’s interconnects.
Was the FTA Callisto brand new or did it have some hours on it?
Thanks for your extensive answerChristoph,
Thanks for reminding me to dust my unused equipment shelf.
The Sablon cable is nestled between an EML 5U4G rectifier, which is handsome (just don’t let it talk) and my SOTA turntable, which is the only thing I can play my crap LP’s from the ‘70’s on.
As I stated in another forum during the FTA break-in, it had a sharp leading edge that annoyed me for the first 30 hours or so. At this early stage I just considered it to be another silver sounding cable with a tilted treble. With more time it developed to a more resolved 3D sound. I learned it was passing more information, not just playing tone control. Eventually the frequencies settled in to portray a holistic picture, not one pocked with frequency aberration. In this regard it easily surpasses my other cables, whether usb or spdif.
In comparison the Sablon is flatter and less extended in the high frequencies portraying a rather smoothed sound. This may be the perfect antidote for some systems, but not mine. What I find unique about this cable is it seems to actively smooth the midrange and to me the result is a coloration. Of course opinions will vary.
I would say the Sablon is a good cable at its price point, which is a bit lower than the FTA. Also, I am not certain of its age as I acquired it second hand. It is the unpowered version.
