Hello Morricab
Yes it is the M2 waveguide but I am using a different compression driver the JBL 476Mg. It's a large format 4" driver with a coated magnesium diaphragm. Much more output than a 2430 down low. I am also going passive, I have the compression driver comp done. Might need a little tweak with padding and from listening impressions as I am only working with on axis measurements for now but it's essentially done. I have to measure the woofer in the cabinet and do the low pass crossover from there.
I am setting up the 2216nd in a low tuned 26Hz cabinet so I can dial up the low bass as required. Gives you a nice banana curve so with any room gain you don't get overwhelmed and you can add a little EQ at Fb where drivers excursion is lowest. That EQ will be done with digital EQ.
Rob![]()
One of the benefits of the JBL D2 Dual Diaphragm driver is that it extends to 20K+ hz. JBL uses the 476MG in the current top of the line speaker (D67000) with a super tweeter on top. Will you be adding the super tweeter?
Hello jeffrey
No they actually run out past 20Khz and they are actually quite clean if you look at the waterfall plot. They don't have the really ragged break up modes like the Ti diaphragms do and are more extended than the Be which tend to start to roll off above 10K. So it's a good compromise. That and adding a tweeter is going to cause other issues. In the 67000 they just let the 476Mg run out they don't high pass it. The super tweeter improves the DI in the upper octaves and give true ultrasonic performance for the Asian markets. We do have a guy over on Lansing Heritage who CNC machined his M2 waveguides to add 045 tweeters to them! Little too ambitious for me!
Rob![]()
Seems like a cool driver. Is it with a 1.5 inch throat or 1.4 inch throat?
I have now purchased a pair of Radian 475pbBe drivers (16 ohm),
I have now purchased a pair of Radian 475pbBe drivers (16 ohm), which I will try on the Iwata 600 horn in place of the Beyma CP350Ti. We will see if the Be drivers are that much better (or at all better) than the wonderful sounding CP350Ti. I am very curious how this will turn out.
Not all but caps are obligatto I think and iron is supposed to be petty goodWE 91B are really famous, would be very interesting amps. Do you know the parts they are using?
Make a video!Hello morricab
Great! best of luck with them. I am partial to the Be drivers and am curious what your impressions are. Got my speakers up and running installed the passive networks last night. Was doing a Bi-Amp passive comp until I could get them built.
Rob![]()
I am not sure how much breakup there is for the Beyma because sounds very clean in the top octaves. I have heard the Be version in the Live Act Audio speakers, which encouraged me to go for it. The Nd version you were using was with the Mylar diaphragm, wasn’t it?I use that driver and like it a lot.
Because of the lack of break-up it may not have as much top-octave energy as you are used to, so you may need to make some adjustments to your crossover and/or EQ. NOT trying to put down the Beyma (I used the neo-magnet version of yours for many years), just relaying my experience.
Hello morricab
Rob![]()
Yes, the CP350TI is an older driver, the predecessor of the current CP380m, which is the Ferrite version of the CP385Nd you used. The 350 and 380 seem to have had the same motor only a change of diaphragm. I am not a big fan of the plastic diaphragms so far but the 385Nd was on my list.Yes, the CP385-Nd has a Mylar diaphragm (or some type of polymer diaphragm). I didn't catch that yours is the Ti version; didn't realize they made one.
In my R&D phase I went through something like nineteen compression drivers before the CP385-Nd. It was recommended to me by Al at US Speaker.
I've probably sold more home audio speakers with the CP385-Nd than all others combined.
Yes, I heard many good things about this driver, especially the Be version. Let’s see if it matches well with my Iwata 600 horn crossed around 1khz. The Beyma works very well in this horn (It didn’t work well in an 18 Sound XT120).I tried them head to head with tad 2001. 2001 may have just a little on them, and that’s a maybe! I also use 850 for my mids which sounded better than 4001 and 950’s as well as bms. So ended up choosing a family member
Still, whether it is good or bad depends on the implementation. It is as important as the driver. What bandwidth you are using them for, with which horns, does the throat angle match with exit angle, how are the crossovers... It all works together and any comment without complete information about these would be very lacking.
Make a video!
I am using the Mg driver more extended than Be and very clean up top.
