Phase shifting with a filter is possible indeed. Even easier in active systems with the filtering on pre-amp level or even DSP
I am a big fan of DSP for horn speakers. My fully horn loaded tri-amplified DIY speakers uses a DEQX DSP without which the system as I built it would not be possible. I wanted to use a good bass folded corner horn with the wide range and super tweeter horns well out into the room. Counting the path inside the bass horns plus the physical separation between bass horns and the wide range horn the woofer and the wide range driver were about 16 and 1/2 feet apart. The DEQX DSP allowed me to correct this so that the acoustic centers of the drivers sound as though they are about 3mm (less than 1/8") apart. This is in addition to crossovers, speaker correction, room correction, etc. I use 16th order crossover slopes which allow me to run the bass corner horns up to 200 Hz which would not otherwise be possible. Since the speakers are DIY no one else on this forum other than me knows how the sound, but I do receive very gratifying compliments from local audiophiles and frequent requests for listening sessions.Indeed so. DSP is clearly much the easiest solution for this time alignment issue especially with the length of that back loaded horn. I did read of some analogue based filters capable of inducing quite long delays but didn’t find any capable of delaying sufficient for 3m disparity.
If anyone wants to know more about my DIY horns additional information and a photograph may be found at: https://www.diyaudio.com/forums/full-range/65061-range-speaker-photo-gallery-408.html
Unfortunately no pics without registering on the diy forumI am a big fan of DSP for horn speakers. My fully horn loaded tri-amplified DIY speakers uses a DEQX DSP without which the system as I built it would not be possible. I wanted to use a good bass folded corner horn with the wide range and super tweeter horns well out into the room. Counting the path inside the bass horns plus the physical separation between bass horns and the wide range horn the woofer and the wide range driver were about 16 and 1/2 feet apart. The DEQX DSP allowed me to correct this so that the acoustic centers of the drivers sound as though they are about 3mm (less than 1/8") apart. This is in addition to crossovers, speaker correction, room correction, etc. I use 16th order crossover slopes which allow me to run the bass corner horns up to 200 Hz which would not otherwise be possible. Since the speakers are DIY no one else on this forum other than me knows how the sound, but I do receive very gratifying compliments from local audiophiles and frequent requests for listening sessions.
Hello DonI am a big fan of DSP for horn speakers.
What are they? Looks like the drivers from the M2, but in a different enclosure. Are the ports on the back?Just got these back together after veneer.
Hello DukeWhat are they? Looks like the drivers from the M2, but in a different enclosure. Are the ports on the back?
They are my DIY's.
Beautiful...look like JBLs just nicer!Hello Don
I went the other way. I use one filter at 25hz to extend the low end the box is tuned to 26Hz so it mimics the BX-63 used in the B380 and B460 subs and the M2 box tuning. The speakers are passive otherwise. I can use Dirac Live for room integration but have not tried it yet. I like them as they are. They sound very smooth with no harshness or are aggressive sounding unless it's on the recording. Fun to listen too very lively!
Rob![]()
Hello Don
Rob![]()
This will depend greatly on what form or horn you are looking at, priorities and choices of the designer, and the efforts taken to smooth the on axis response.Is it a fair criticism? For which models and brands?
And if so, is it the speaker design or the amps interacting with the speaker? Or something else?
https://aer-loudspeakers.com/full_range_driver_bd_4/Hey Audiophile Bill, If I remember correctly (I sometimes do) you stated that you use an AER BD4 driver in your wooden horns. Since I use AER BD3s I was curious to see if AER was making a better driver than my BD3s. When I checked AER's website I didn't find a BD4. Please tell me about your BD4s.
Here's an interesting data point for the What's Best Forum members, many with very expensive systems (let's say >$100K MSRP). Of this small % of audiophiles how many chose to buy horn speakers for their system? I'd wager ~15%.
