The argument for/against room treatment
MadFloyd
775
1,700
Mass
I don't understand why some audiophiles would suggest that NO room treatment works best.
It seems to me that unless your speakers are really far from surfaces that absorption should be used. When I listen to headphones there are no surface reflections; I'm hearing what's on the recording and nothing more. When I listen to speakers, I'm hearing room reflections. How can this be good? Are speakers designed with this in mind and if so, how?
Kingsrule
1,444
704
1,430
For or against is a foolish and myopic way at thinking about room treatments.
Room treatments are dictated by the room in question, it either needs them or not.
Pretty simple.......
PeterA
12,669
10,942
3,515
USA
Ian, In my room I prefer the sound after having removed all of the room treatments I previously had. But that does not mean that a professional couldn’t come into my room and add some room treatments here or there and improve things further. I think it is very difficult to generalize.
I’m glad listening to my speakers in my room does not sound like listening through my headphones.
I agree with kingsrule it depends on the room. I learned through experience that it’s very easy to add too much treatment creating sound which is overly damped. A lot depends on the type of speakers and the construction and dimensions of the room, and then personal listener preference.
jeff1225
3,013
3,266
1,410
51
I believe that it’s all about the room. You have to treat every room individually. I had no treatment (other than furniture and an area rug) when my system was in a large great room with cathedral ceilings. When I converted my garage into my music room, I absolutely needed to at defusers to the ceiling.
but we can also go crazy and over damp our rooms zapping excitement.
Al M.
8,801
4,550
1,213
Greater Boston
There is no room without room treatment. Any carpet is already room treatment. Peter, you also have room treatment. You have a carpet and furniture, and you adjusted the blinders covering your windows. Also, you very conciously removed the glass from your picture frames -- clearly room treatment.
I did remove all my TubeTraps recently, but that was only made possible after moving the subwoofers next to the main speakers rather than having them at the front wall. In that former configuration the TubeTraps were indispensable.
There are still in my room diffusers, including on the ceiling (super important in my room!!), ASC window plugs, and diverse carpets.
So indeed, the level of room treatment needed will always depend on the room and situation.
Yet again, there is no room without room treatment.
Reactions: K3RMIT and bazelio
MadFloyd
775
1,700
Mass
Let me put it another way (you guys aren't understanding the essence of my question).
Why not have a room that is FULLY DAMPED?
BlueFox
1,709
407
405
What is fully dampened? How do you measure that?
Al M.
8,801
4,550
1,213
Greater Boston
Is that the essence of your question? Because in my view room treatment is not necessarily about a dichotomy absorption vs diffusion, but about controlling detrimental uncontrolled, or unwanted, reflections. This can be done either with absorption or diffusion, and which of these needs to be applied depends on the situation.
Some lively spaces will have lots of hard reflections, some others will have more natural diffusion. You will probably need less room treatment in the latter.
Reactions: MPS
Gregadd
1,791
1,850
Metro DC
Here is a simple test for the effect of a room on sound. Get one of those small bluetooth (tm) portable speakers. Play some music on it. Walk from room to room. Observe how the sound changes.
Mike Lavigne
Apr 25, 2010
12,601
11,693
4,410
headphones have a 'room' too, it's just a bit smaller. physical laws still apply. headphone designers have to jump through their own sets of space issues. they are not perfect. and the whole stereo perceptive thing is different.
and keep in mind that speakers designed for domestic rooms have room gain designed in for their average room.
we would not want to listen in an anechoic chamber......for long.
every room has treatment. every single one of them. the question is whether you like it..
4,702
Surely. F. Toole refers in his book a statistical analysis of RT60 carried in 600 rooms in Canada. The average was around .4s and about 70% of them were quite acceptable, but some people must have got the unacceptable ones. :oops:
Reactions: kach22i
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
Visit a fully dampened mastering room and you'll know why. You can even become disoriented in some of them because they're so damp.
david
Never heard/seen a "fully-damped" mastering room. A "fully-damped" room is a theatre, where there is NO reflection/diffusion of sound waves.
Now, I've seen mastering/mix room that are total diffusion (Blackbird?).
marmota
260
247
275
david
This, +1000!
The worse sounding audio system I've ever heard, by a country mile, was at a local mastering studio, medium-large size, room-within-a-room construction but almost zero diffusion (just in the ceiling and a little bit in the back wall), stuffed with bass traps and absorbers. Literally, my car's stock radio was more enjoyable, I don't understand how that guy can work 8 hours per day there without going nuts. Oh, and he also had various troubles with mixes translating incorrectly to other audio systems, that was how much that expensive room sucked life out of music, didn't matter if it were on the big speakers or the small monitors.
Reactions: mtemur and ddk
16,219
13,682
2,665
Yes, this is a different question than what I thought you meant originally. :)
For me, a fully damped room takes out of the sound too much of the energy and "aliveness" of the music.
Reactions: PeterA
MadFloyd
775
1,700
Mass
Thank you, Mike. This is the type of answer I was looking for.
When I listen to music through various high end headphones, room issues seem to be non-existent. Bass is obviously the best example of this, but I also find the sound in general to be much drier and cleaner (e.g. in high frequencies). In short, superior.
In many listening rooms the highs do not seem as clean and they are not as dry - and it makes sense to me that they are bouncing off of many surfaces and creating a coloration. Real time reverberation on top of recorded reverberation.
But I also know that speakers are designed with room boundaries in mind - e.g. real world situations - at least for low frequencies... and mostly all we hear about is addressing first or secondary reflections. I don't see much talk about the wall behind the speakers - or the sidewalls between the speaker and the front wall and it made me wonder if that area should have absorption for better results.
Lagonda
3,515
4,825
1,255
Denmark
David probably meant a vocal booth, we had many that could not do the vocal booth for long before feeling uncomfortable, you can hear your own heartbeat and space is also limited. :oops:
Cellcbern
1,224
730
585
71
Washington, DC
There are no sound arguments against room treatment. If you do not take steps to minimize reflections that interfere with/cancel out your speakers' direct radiations then you will be listening to your room - not your system, which also means that you will not be hearing the music as it was recorded. What steps you take will depend on the room. If you deployed acoustic treatments in a room and your system sounds better if you remove them then your initial deployment was misguided. When acoustical room treatment is done well the improvement is obvious.
ddk
6,261
4,043
995
Utah
Maybe those too, my experience is with mastering rooms, the deadliest of which was Sony's in NYC.
david
Reactions: Lagonda
