Looking at your photos, you appear to be using the panels individually rather than covering a wall or significant part of a wall surface with them, which means that you don't have the minimum recommended coverage on any wall surface. It follows that you are not going to get the same level of benefit that I am getting. Again, coverage is simple in my room whereas you have windows and other challenges that I don't face. And unfortunately achieving minimum recommended coverage for you would require purchasing additional panels. If you are going to stop at eight ZR panels you might consider grouping four ZR panels in each corner behind the monitors, and getting conventional absorbers on stands for in front of each window/behind the sub.So some surprising observations after a few experiments. In an attempt to confirm real, audible differences, I took the 8 panels in and out of the room several times, playing a few tracks over and over to make sure an improvement could be heard.
My previous experience was correct and it reproduced the same results. Improved soundstage, better instrument tone, realism and spacing. Not, "blow you out of the water", but still good improvements. The panels had less of an effect on vocals but some improvement nevertheless.
But here's where things got interesting. First, in my previous house/room I had the 851N streamer and compared it's digital pre-amp vs the Wyred4sound STP-SE 2. The STP-SE 2 was way better, less digital, cleaner and higher resolution. Same thing with the Ares DAC vs the 851N DAC - better bass and less of a digital sound. Without the panels, in the new house/room the differences were there but less so than my previous room. I would attribute this to the room acoustics and that I just simply had a better room before (which is true especially in the bass response).
However - with the panels in the room, I had a really hard time hearing ANY difference between the preamp/DAC switch. And this was done in a way where I was able to toggle between input 1 (STP-SE/Ares) and input 2 (set as bypass for the 851N) immediately during playback. I did the test comparing both the pre-amp portion and DAC portion separately and later together. No difference. I am going to try this experiment with my other two amplifiers I use for the home theater and even my 25 year old pioneer Elite receiver. Will also see if it sounds different with my midfi turntable setup.
As mentioned earlier, in their temporary placement, the panels has not solved my bass issues and the same frequency issues will most likely show up in the room measurements once I find the (quiet) time to accurately take those measurements. Granted, I only have 8 panels, covering only 16 total sqft of front wall space so I never expected it to solve all my issues, including bass. I believed from the very beginning it will take a combination of further bass trap treatment, an active crossover for the sub and monitors and continuing to adjust placement of panels and speakers. Last option could be to replace the speakers all together with something of a sealed design or at least without a rear port.can you post some REW measurements with and without the panels? This will be very interesting as the claim was that these panels will fix the bass problems.
The problem is the windows are directly behind the speakers. I have played with their placement and due to the dimensions of the room, adjusting the width of the speakers in either direction do not sound (or measure) as good. There is more flexibility in moving them forward or backward, but they sound best where they currently sit.Looking at your photos, you appear to be using the panels individually rather than covering a wall or significant part of a wall surface with them, which means that you don't have the minimum recommended coverage on any wall surface. It follows that you are not going to get the same level of benefit that I am getting. Again, coverage is simple in my room whereas you have windows and other challenges that I don't face. And unfortunately achieving minimum recommended coverage for you would require purchasing additional panels. If you are going to stop at eight ZR panels you might consider grouping four ZR panels in each corner behind the monitors, and getting conventional absorbers on stands for in front of each window/behind the sub.
What are you finding confusing? What questions can I answer for you?I have read this entire thread and am totally confused and cannot think of a way to test for myself!!!!
My confusion stems from where to put them and which and how many to buy? Thank you for your assistance.What are you finding confusing? What questions can I answer for you?
DHDI says that their research/testing revealed that the wall directly behind the speakers is the most important to treat, and that the speakers should be right up against the panels/wall - as close as possible. I followed this recommendation (as did the Stereophile reviewer) with good results. I started off with four of the bare wood ("Sample Rate") panels in the position where the blue "Hybrid" panels are in my latest photos. DHDI says that you need to cover a minimum of half the square footage (sf) of the wall for best results, which I have now done, but I got a dramatic improvement with just 16 sf of panels on a 70 sf wall. Based on all of the photos I've seen I think you have to have a panel directly behind each speaker's radiating area (the area of the front panel where there are drivers) that is at least twice the sf of that area. Note that when I tried pulling the speakers out away from the wall/panels I lost some of the effect of the panels (reduction in clarity), which suggests that if you don't put your speakers right up against the panels you will need more sf of panel coverage. Note also that I bought both the Hybrid and Sample Rate panels to test, however I do not hear a big difference between the two. The Hybrid panel is already in a wooden box type frame and is therefore more durable and easier to handle than a Sample Rate panel. The ZR panels are designed to be installed with Velcro on a cloth studio wall, but I was not able to make this work in my home. The Sample Rate panels in particular are very delicate and can be broken just through routine handling. I put each ZR panel (Hybrid and Sample Rate) in a floater frame (the type used for canvas art) to protect them, and hung each one with a wire and hook like framed artwork. Note also that I deliberately put the ZR panels up against the side walls (into the corners) even though that left a gap in the middle so they could reduce the pressure buildup in the corners. Since the wall area behind the listening seat is smaller than the area behind the speakers (there is a door to a bathroom on the rear wall) I was able to cover the whole thing with 16 sf of panels and a small strip of SR 4 (4" square) panels in the middle. To sum up, I think you should start with the minimum amount of sf on the wall behind the speakers and add incrementally until you stop hearing an improvement. DHDI recommends a mix of Hybrid and Sample Rate panels which I have, but the technology is in the Sample Rate panels - the Hybrid panels are Sample Rate panels in a box frame with a thin later of absorbing material, covered in acoustical fabric. The Sample Rate panels are cheaper and you could get away with just using them, but when you consider the necessity of putting them in some kind of box or frame it is a wash. If you are starting out with ZR Acoustics panels I would focus on the front and rear walls and use inexpensive GIK absorbers at the side wall first reflection points. Without knowing your room dimensions or what speakers you are using I cannot be more specific. See my progression in photos below:My confusion stems from where to put them and which and how many to buy? Thank you for your assistance.
I suspect they do have "some positive effect", and on more than the bass. Just look at the list of film/recording studio and mastering lab clients:My take on these panels is that they should have some positive effect on the bass when placed on the front wall behind the speakers as they recommend. They will repeatedly "scrub" the bass waves that bounce side to side and up and down in the front of the room, helping to reduce what we here at ASC call "head end ringing." Any rough surface will attenuate a sound wave moving parallel to that surface, and these provide a very rough surface. If a bass wave hits them perpendicularly they will have almost no effect, so front to back bass reflections are not addressed unless these panels are placed all along the ceiling and side walls. I'd like to see some measurements before and after. REW's C50 clarity before and after would be worth looking at to see how low they go and how much they increase measured clarity.
For the sake of comparison I googled Acoustic Sciences Corporation "Portfolio" and "Commercial Client List". Here is a link to what my search turned up:I suspect they do have "some positive effect", and on more than the bass. Just look at the list of film/recording studio and mastering lab clients:
The trade secret, what makes ZR Acoustics panels work as claimed is a precise, specific size, angle, and pattern of non-parallel surfaces. Hanson Hsu was granted U.S. Patent #9,845,598 for the original Zero Reflection panel design. The current circular one that they use (as in my photos) is an advancement on and superceded that original design. In fact, DHDI claims that as long as the trade secret angles/patterns are maintained the ZR technology can be incorporated in something as thin as a window curtain:My take on these panels is that they should have some positive effect on the bass when placed on the front wall behind the speakers as they recommend. They will repeatedly "scrub" the bass waves that bounce side to side and up and down in the front of the room, helping to reduce what we here at ASC call "head end ringing." Any rough surface will attenuate a sound wave moving parallel to that surface, and these provide a very rough surface. If a bass wave hits them perpendicularly they will have almost no effect, so front to back bass reflections are not addressed unless these panels are placed all along the ceiling and side walls. I'd like to see some measurements before and after. REW's C50 clarity before and after would be worth looking at to see how low they go and how much they increase measured clarity.
In the higher frequencies I don't think there's too much doubt about how the surfaces on those panels could be beneficial. In the bass, it's not always clear to everyone how that works. That's why I specifically mentioned the bass. At first glance it seems the surface is inadequate to affect bass waves - quantum shaping or otherwise. But when you consider waves passing parallel to the surface in an enclosed space you can get effects going into lower frequencies than some might expect.I suspect they do have "some positive effect", and on more than the bass. Just look at the list of film/recording studio and mastering lab clients:
Can you elaborate on what you mean by waves passing parallel to the surface?In the higher frequencies I don't think there's too much doubt about how the surfaces on those panels could be beneficial. In the bass, it's not always clear to everyone how that works. That's why I specifically mentioned the bass. At first glance it seems the surface is inadequate to affect bass waves - quantum shaping or otherwise. But when you consider waves passing parallel to the surface in an enclosed space you can get effects going into lower frequencies than some might expect.
