BETONart-audio Tyrexx Subwoofer
19,013
16,938
3,530
TYREXX
EARTH VIBRATION - brute - impulse - dust-dry & mega powerful
  • Uniquely rigid cabinet made of 260 kg carbon concrete
  • Maximum impulse fidelity - bass as if carved in concrete
  • Brutal pressure from two 54 cm diaphragms
  • 18 Hz - 100 Hz
  • 2 - 5 kW for the ultimate sound experience
  • Closed cabinet without airflow noise
  • Perfect room adaptation thanks to DSP sound processor
  • H 155 / W 58 / D 40
  • from 13.860 €/piece incl. delivery, installation & calibration
LISTEN NOW
SUPERLATIVES MADE OF CARBON CONCRETE
Earth Vibration
The extremely stripy and heavy cabinet made of carbon concrete delivers an impulse-frequent, pitch-black & punchy bass like we love it.
Ultra-stable power amplifiers up to 5 kW
Ultra-stable power amplifiers with an output of up to 5000 watts and a very high efficiency of the bass chassis of 95dB/1Watt provide superior power at any time.
Rigid bass cabinet made of carbon concrete
The uncompromising, fine- and exploding coarse-dynamic reproduction of even the lowest frequencies takes place live-like, playfully dynamic and with perfect timing due to the unique cabinet properties of the carbon concrete and the huge two diaphragm surfaces (54 cm diameter).
Maximum impulse fidelity - closed cabinet
The TYREX was developed as a closed system to avoid all disturbing flow noises that usually occur with bass reflex systems and to guarantee maximum impulse fidelity.
DSP - Goodbye Noise
Disturbing room modes or eigenmodes of your listening room, i.e. frequencies at which an increased reverberation time can be detected, which usually leads to droning in the bass range, can be equalised via a DSP.
Uncompromising Fine and Coarse Dynamics in the Low Range
Due to the extremely large diaphragm diameter, the bass plays uncompromising fine and coarse dynamics light-footedly and authentically. A bass drum sounds like a bass drum and characteristic low-frequency decay processes of a bass string become audible.
Attractive price
BETONart-audio speaker systems are distributed exclusively and directly by us. The absence of the usual dealer's margin as well as a lean organisation of our high-end manufacture enable us to offer you exquisite loudspeakers in a class of their own at extremely attractive prices.
The best cabinet material is carbon concrete !
Each of the two acoustically decoupled modular enclosure parts of the TYREXX is made of carbon concrete in one casting as a monolith with 28mm wall thickness.
The high damping capacity and the stiffness of the concrete enclosure are the guarantee for an ultimate listening pleasure and ensure a pure sound far away from the typical "box sound" often found in wooden enclosures.
THERE IS NO PLAN B TO DIAPHRAGM AREA!
The larger the diaphragm area of a subwoofer, the easier it is for the low tones to escape from the diaphragm.
Ideally, the diaphragm area should always be the diameter of the musical instrument that produced it - the TYREX is the equivalent of a bass drum from a drum kit.
That's why we use 21? inch high performance drivers with powerful neodymium magnets with max excursion of +- 15 mm.
Sound processor for maximum flexibility & precision
As standard, the high-end subwoofer is delivered with two integrated power amplifiers (2 x 1000 watts) and integrated 4-channel DSP.
If you wish, it is possible to use a power amplifier with up to 5000 watts.
The phase adjustment is set electronically via the runtime adjustment.
With the DSP, room adjustments can be made and disturbing room modes can be eliminated.
Inputs: WISA / analogue / SPDIF / XLR
TYREXX
WISA / XLR Panel
Uncompromising wireless technology
The TYREXX can also be controlled wirelessly via various WiSA transmitters if desired.
WiSA features:
2x audio quality: WiSA transmits 24bits at 48kHz/96kHz, which is comparatively twice the CD quality.
Nothing succeeds like excess!
TYREXX
  • 18 Hz - 100 Hz
LISTEN NOW
Earth Vibration
DSP - Goodbye Noise
Attractive price
TYREXX
WISA / XLR Panel
WiSA features:
Beautiful sub.
