xlr are a better way to connect.The XLR connectors are Neutrik with a custom endpiece.
Audioquest, of course!As the title says, among the cost no object cables, which are the best? Siltech, Crystal Cables, Tara Labs, Transparent, MIT?
These are all excellent brands .there is no best.Audioquest, of course!
Oliver, I ran across your post and wanted some clarification. Is the recommended Neotech model SOCT-14 or is it 18? Do you have a photo of your build?Having tested pure silver, copper, expensive, cheap cables i ended up in using 16 Neotech 18 AWG solid core pure copper NEOTECH SOCT-14 without termination as speaker cable. This is the most resolving, dynamic and realistic sound. 8 per side, 4 per pole. All cables must have a certain distance (Air is the best isolator). I put black cable coating on.
You mustn´t change the setup often as the connection is a bit tricky and you shouldn´t be bothered by the number of cables.
With interconnect, i swear on Neotech Nemoi-3220.
But all is a matter of taste as i really like a very fast and musical presentation. And no, i don´t deal with Neotech![]()
Hi Agent86,Oliver, I ran across your post and wanted some clarification. Is the recommended Neotech model SOCT-14 or is it 18? Do you have a photo of your build?
Do you know if your SOCT is cryogenically treated too?Hi Agent86,
i do have both. SOCT-14 using 2 per pole and SOCT-18 using 4.
I braided them now and flattened the ends a bit with a hammer.
The picture shows the 18.
I don´t use termination. From time to time i use a very fine sandpaper to clear the contacts.
In comparison they are very similar, perhaps the SOCT-18 is a bit smoother and has better bass extend than 2xSOCT14 per pole.
Best
olivier
I don´t know but don´t think soDo you know if your SOCT is cryogenically treated too?![]()
Oliver, was there a discernible change in sound when you moved to a braided design? Originally, you configured each of the four wires per pole with a bit of physical distance from the others, correct? How much space was needed? I guess I'm asking whether the braiding was necessary for noise cancellation or whether the change was purely for the convenience of not having some many parallel runs of wire.Hi Agent86,
Best
olivier
I just wanted to test both and my experience is that the braided design is a bit more forward, engaging. I think this is because of the lower inductance. Resolution is good with both designs.Oliver, was there a discernible change in sound when you moved to a braided design? Originally, you configured each of the four wires per pole with a bit of physical distance from the others, correct? How much space was needed? I guess I'm asking whether the braiding was necessary for noise cancellation or whether the change was purely for the convenience of not having some many parallel runs of wire.
Thanks,, Olivier! That's good advice. You just save me the trouble of demolishing my living room. to make space for each run of wire.I just wanted to test both and my experience is that the braided design is a bit more forward, engaging. I think this is because of the lower inductance. Resolution is good with both designs.
And all solid core designs are more precise than any stranded designs i tested before, i tested copper and silver
haha glad to hear thisThanks,, Olivier! That's good advice. You just save me the trouble of demolishing my living room. to make space for each run of wire.
SOCT is not cryoed as delivered from the factory,. Takefiveaudio in Canada can supply several Neotech wire types cryoed. The SOCT wire which is UPOCC, might benefit less than other wires from cryoing due to the extremely long crystal structure.Do you know if your SOCT is cryogenically treated too?![]()
More importantly, are we talking cryo-treating via the much more popular but much inferior vapor method or the lesser-known much superior full-immersion method? Makes a big difference.SOCT is not cryoed as delivered from the factory,. Takefiveaudio in Canada can supply several Neotech wire types cryoed. The SOCT wire which is UPOCC, might benefit less than other wires from cryoing due to the extremely long crystal structure.
Perhaps. But I've had maybe 20 or different cables cryo-treated since 2005 and I don't recall a single cable coming back more inferior. I've never viewed the process being done but I've been told it helps if the vendor knows what they're doing.The cryo process can under some circumstances result in microfractures at the conductor surface.
Hmmmm. Did he mention that he only measured after the cryo-treated cables were fully burned in? It would seem this could impact any measurements since the cryo'ing process returns a cable to a new/unsued state that has to be burned in all over again.Steve at Empirical Audio did some very interesting measurements regarding cryo treated wires. Some wires measured worse after having been cryoed. Possibly due to microfractures.
