Very good choice. Let us know how it sounds when it is settled.I settled on a Lamm LL2.1
Is that yours?Silvaweld SWC 1000R with WE 417 Tubes/E 88cc Valvo or TFk
Dynamic and Resolution wonderful
Used for 2.5- 3k€ a bargain
From Netherlands for 2700€ It is from my cousin, i ask him what tubes he used for power supply.Is that yours?
I paid a LOT more for mine
But it really is a wonderful preamp
What tubes do you recommend for the Power Supply?
I have the two box SWC1000R which I like better visually.From Netherlands for 2700€ It is from my cousin, i ask him what tubes he used for power supply.
But does yours have a poker chip insideI have the two box SWC1000R which I like better visually.
I also use the E88CC from Valvo. For the 417, I have to check what brand they are.
Agreed...I had one for several years. Mine was not with remote control though...I had dual mono silver contact stepped attenuators...and in two separate boxes.Silvaweld SWC 1000R with WE 417 Tubes/E 88cc Valvo or TFk
One of it used in Silvaweld SWC 450 Pre for Stereo unbalancedAgreed...I had one for several years. Mine was not with remote control though...I had dual mono silver contact stepped attenuators...and in two separate boxes.
He changed Power Supply to Mullard GZ 34, Telefunken EF 86 and 300b Electro Harmonix more clean smooth sound and more detail ,a bit less noise when idling.I have the two box SWC1000R which I like better visually.
Thanks for the info.He changed Power Supply to Mullard GZ 34, Telefunken EF 86 and 300b Electro Harmonix more clean smooth sound and more detail ,a bit less noise when idling.
Elrog fits same bulb size as 300bThanks for the info.
I have a Mazda GZ34 (Mullard made) and a single survivor Elrog 300b at home to try in the Power Supply
I'm just not sure the Elrog 300b will physically fit into the enclosure![]()
Great preamp I love it.Silvaweld SWC 1000R with WE 417 Tubes/E 88cc Valvo or TFk
Have you ever heard it?Great preamp I love it.
I have heard of them but not heard it personally.I’m sure it’s excellent sounding.Have you ever heard it?
Or even heard of it?
My room is not complete and just using my system in a temporary arrangement so hard to really tell... I believe there is a more natural sound but I should replace the tubes as they are an unknown right now, original owner wasn't sure when he last changed them.A very fine choice. I have one currently in-house, eventually to be reviewed.
What do you think of it? How did it change the sound of your system?
Had him ship directly to Lamm factory shop for complete checkup/test, which Elina said it tested and sounded great.
