I recently got a head-amp from Allnic, HA-5000 and it works very well in my system.
Head Amp is not such a popular idea in modern phono amplification anymore. There’re not too many choices on the market. Out of curiosity, I tried one in my system and it proves to be such a good idea to have an active head-amp in the phono amplification route.
After experiencing quite a few SUT‘s, I became convinced that SUT is my preferred way to drive a cart. If matching with the right SUT, the cart can reveal its real potential in terms of quality and characteristic. I can always hear more from a good and matching SUT than a normal voltage/current amplification phono stage. The problems with SUTs are that you have to try and match, ending up with multiple SUTs pairing with your carts, while the SUTs, especially good ones are always expensive. One can easily spend a lot of money on SUTs. The other problem is that for the high impedance carts, for example the old version of VDH Colibri is at about 50 ohm impedance, 0,35mv output. For such a cart, it is very difficult to find an SUT perfectly matching the needs for gain and quality of this cart. MC voltage amplification to VDH colibri can also easily pick noises from the environment due to the high load impedance needed.
The HA-5000 is a 2-piece all tube unit, separating power supply and the phono amplification. It adds 30db, with 4 levels of load impedance: 50 ohms, 100 ohms, 200 ohms and 500 ohms. Those are good enough to cover most of the carts. I use the HA-5000 with the mm input of my Soulution 755. It is a good match for my ears. The gain of 755 mm is on a high side, therefore I have to turn down the volume of my preamp by 10db. The 755 mm gain is rated 60db and 66db in 2 levels. I feel it is a bit overrated but still it is pretty high. If pairing with an MM stage with 38db or so gain, I guess it is an even better match.
When the HA-5000 just arrived, the sound was a bit muddy, while the S/N ratio seemed to be overrated too, it was a bit noisy. After a few days burn-in, and a few attempts in different placing locations, the HA-5000 starts to get better and interestingly getting quieter and quieter.
It also became more “powerful”, cleaner sounded, with a touch of tube warmth which I adore but not overly colored with a bloated tube sound. And it gives enough gain to most of my carts, ranging from low output carts such as 0.2mv Anna D, 0.25mv Etsuro Bordeaux, 0.3mv Etsuro Gold up to 0.56mv Lyra Atlas. I’m more impressed by its performance with VDH Colibri since I rarely experienced an ideal amplification since I bought this cart years ago.
It has a typical Allnic sound, which means transparency and a bit of sweetness. I got the similar taste from the previously owned H-8000 DHT, which regretfully didn’t stay in my system for some random reasons. After burning in, it works pretty well with almost all my carts. Honestly, it is not a dead quiet unit but the noise is barely audible.
Compared to SUT, it is a more generic solution. SUTs are more critical in matching with carts. But i still believe SUT can drive the most out of a cart. A Head Amp brings benefits of a more versatile matching to carts, quiet and enough gain. It works exceptionally well with high imp carts. I’m quite excited to have HA-5000 in my system.
