Current “Best Bet” SOTA Phono
Power can be fixed with Kagura, room???
I doubt it will be powerful enough. Nice sounding for sure but not powerful enough.
depends on crossover frequency...i asked earlier remember ;)
I am not saying it needs to change but open baffle at high volume needs a lot of woofer area!
I’ll move my OB further away, perhaps 1-5-2 m from wall
No room treatment that can help except making the room bigger? I don’t mind spending lots of money to fix my room if I can avoid tearing down my room. Too noisy and stressfull
First one.
I ended up buying this, coming in 30 min as I forced my regular tapestry seller to delover it himself. Damn thing expensive $8300, silk handmade I hope it helps a lot61278CE5-EAC9-42DD-9F38-F03F0E026D3C.jpeg
What do you think? Awesome or too expensive?
Reactions: Uwiik
How big is your room right now?
New update. Just called my dealer and ordered Kagura and G1000i, they said Kagura V1 is slow as molasses and Kagura V2 is Ongaku on steroid. Will be delivered March 2022…. Can’t wait.
Holy Moly. Congratulations!
Thanks all. I am a bitch but should I just keep my G70? I heard G70 hangs well with G1000
4.8m x 8.5m x 3.2m
It’s a good size room. Although I don’t see a point to crank up to 120db, I imaging you need a much more powerful amp. Maybe show us your room so we can find how you can treat your room.
If you hang it to the wall, make sure it hangs with a 10 cm air gap from the wall to be most efficient ;)
Reactions: tima and TDX
Reactions: Uwiik
