Mike, Thank You. I suppose I'm an outlier in pairing a multi- single SS component to tube amplification.
About the music apps, knowing the internals of how these stuffs actually works there should be no SQ difference as long as all things are kept equal. There is no actual “better.”Quick Q, Mike. Was the compare both on Roon, or Roon on Wadax and TAS on Extreme?
I have been pairing a solid state dac (Tidal Camira lately but before that inter alia DCS) with tube amplification (Kondo preamp and poweramps) for many years. And I will keep doing this with adding the Wadax Reference dac. Bought the latter about three weeks ago and I hope to receive it at the end of this month.Mike, Thank You. I suppose I'm an outlier in pairing a multi- single SS component to tube amplification.
my Extreme is going to a new happy owner. i'm buying the Wadax Reference Server.
on Friday night my friend Victor, who owns is an MSB Select 2 and is an Extreme owner, came over to assist with the compare. Victor also brought a Gigaswitch and LPS to optimize the copper Ethernet that both the Wadax and Extreme would use. both the Extreme and Wadax server were sitting on Dazia's. we used TAS for the Extreme, and Roon obviously for the Wadax. Emile had optimized the USB driver for the Wadax Reference dac.
we did the compare, first three tracks with the Wadax Server, then those same three with the Extreme. i'm not going to speak on behalf of Victor. but it was a clear choice. we move on. synergy? Akasa Optical link? hard to know cause and effect exactly.
the Extreme/Wadax Ref dac is awesome in every way. the Wadax combo is better.
below is how my system looks today.
I don't begin to agree with that Steve. There is a difference between TAS and Roon with my Extreme, less after the latest Roon change but still evident. Maybe something to do with how busy the software is?About the music apps, knowing the internals of how these stuffs actually works there should be no SQ difference as long as all things are kept equal. There is no actual “better.”
Music apps should only has one job: controlling what files go to the player. If the file is bit perfect, it means they have not changed the file. If one changes things about the music in Roon, Taiko TAS/XDMS, Lumin app, Aurender app or dCS Mosaic... then the file is no longer bit-perfect. It is different.
I hope the music apps always acquits themself of their task in the future. There is no real difference in absolute performance and it only comes down to the preference of the listener.
So after all, the SQ should depends on the quality of the original recordings and the quality of music server/streamer.
It’s all a matter of preference so as long as you’re enjoying the whole experience and listening more then you’re on the right track.
Yes, I know there is the difference between TAS/XDMS and Roon on the Taiko Extreme. Like I said, I hope the music apps can acquit themself of their main task in the future and do not change anything about music in them. If these stuffs actually work, there should be no SQ difference as long as all things are kept equal. There is no actual “better.” Andrew of dCS also said this.I don't begin to agree with that Steve. There is a difference between TAS and Roon with my Extreme, less after the latest Roon change but still evident. Maybe something to do with how busy the software is?
Hi MicroThanks for your clarification. Can you tell us something about your system and preferences?
Victor is member V-Squared; he was with Elliot and i the first night with the Wadax. his system is listed in his Signature here. he lives in Northern Calif but is considering moving to the Seattle, so is doing an extended stay here right now.What is Victor's system, and does he live in Seattle?
Streamer for Youtube and TV: Rose RS 150
Ohh, if everything is like you said, why there isn't the difference between Mosaic and Roon about SQ? I don't know how TAS/XDMS is but I believe Andrew because he is the representation of dCS to answer this problem on the dCS forum.This is just not true. Music software does so much more than just send bits to the DAC. For example, Roon is constantly creating network traffic doing various tasks. This could all be happening while the music is playing, which causes the processor to be multi-tasking. In addition, all the music players may be checking the music sources (NAS, hard drive, streaming) to check for updates. Some also load music into RAM waiting to be played. When does this happen? There is so much going on in addition to sending data to the DAC.
Hi Cyrusjonyung, are you using a server for Roon Core? If so which one (if not Wadax)? Thanks.
On the dCS forum, there are also many people who think Roon and Mosaic sound the same. Andrew had the statistics and he told clearly that: "If these stuffs actually work, there should be no SQ difference as long as all things are kept equal. There is no actual “better.”"In reading the dCS forums there are a lot of people who think Roon and Mosaic sound different. I don't own any dCS equipment so I can't comment from my own experience. What I do know is that I have listened to Roon, TAS and Euphony and they all sound different. In addition, Roon has made changes over time which has affected the sound. I can assure you that I am not the only one who thinks each software player sounds different (and I am not saying better or worse, just different).
Hi Mike,you don't see MSB Select in many tubed systems either. Lampi or Nagra more common.
in Asia dealers are selling big tube amps, and maybe you will see more Wadax sold into those type systems.
Yes, and I have seen people complaining a few years ago that back then a Roon software update made the music sound softer, on otherwise the very same playback.
The myth "bits is bits" just doesn't hold with streaming. There are so many complicating, and apparently not easily knowable, factors about streaming and computer audio in general, it is ridiculous.
I have heard so many problems with computer audio over the years, and also direct comparisons with CD transport (including with reclocker which is even better) that it now seems obvious to me that few people , using streaming, actually get out of their digital what it is inherently capable of.
Many complaints about digital audio sound to me like complaints about the streaming itself, rather than digital per se.
Until computer audio becomes mature, I'll stick with CD transport and do streaming over headphones on Youtube where sound quality just doesn't matter that much to me.
Sure, a SOTA assault on streaming like the Wadax server may get all out of it, but in the real world with real world prices there are just so many pitfalls in computer audio.
"Bits is bits". Sounds suspiciously like Perfect Sound Forever. I thought we had gotten over that one.
