Center Stage 2
nonesup
1,050
626
355
Spain
Steve do you have any pictures where I can see how you have placed your Center Stage 1.5 under your Extreme? Looking at pictures of the bottom of the Extreme, practically everything is full of holes.
Ive out this photo up a few times. My CS2M 1.5's are inside the stock feet and moved forward (in the front) and backward in the rear until the footers are just under the edge of the Extreme.
Reactions: nonesup
joelavrencikCMS
155
57
33
74
I am liking these under my EMM Labs DV2!
Oh yes. Steve is right. If you like this arrangement, the feet directly touching the bottom of the component with the dampers removed should be even better 7 to 10 days down the road. Please let us know.....
Reactions: gfroman
gfroman
466
571
1,150
Thanks, Guys.
Will do.......
joelavrencikCMS
155
57
33
74
Thanks for this really useful thread. I had a question- I know that there are benefits to using 4 rather than 3 footers. I actually have 8 CMS 0.8 footers and a relatively heavy power amp (23kg). Is there any benefit to using >4 CMS footers?
PS, I also have a symposium board, but one of the lower range that has an aluminium top rather than a stainless steel one. It works great with the CMS footers :)
I'm not sure if we answered you so forgive me if I am being redundant. Firstly, thank you for the last paragraph. This is very useful information. I read this to mean the feet are on the board? Can you please confirm or correct my assumption. Thanks!
Finally, using 4 is based on tests that clearly indicated an audible cost/value improvement with the 4th. You're better off opting for 4 than 3. Let's face it, those of us that use these feet are all about true high end performance and 4 gets you closer.
Muni
49
79
23
CS Footers are voiced 4 per set and are sold that way. You only place them under your component.
How about power distributors, Steve - recommended?
I have several friends who use them with a Niagara power conditioner with excellent results however I wouldn't start there but rather leave the power conditioner to the end before decide to try them under it
Muni
49
79
23
thank you Steve - the rest is already taken care of - sounds good that I can expect results!
I felt the same about power supplies to my equipment. They were the last I did and I wasn’t expecting the results I got. Definitely was an uptick
Muni
49
79
23
thanks, Steve these feet are wonderful!
Reactions: Steve Williams
jelt2359
241
255
133
39
Hi- yes the board goes on the rack, then the feet, then the component. Your assumption is correct.
Noted on the 4, I'll stick to 4, and won't go more than that!
jelt2359
241
255
133
39
Hi @joelavrencikCMS have you tested the CS2 in contact with a magnesium board? I’m assuming it should be okay?
jelt2359
241
255
133
39
RnRmf
96
42
248
I have a component with non-removable 1.5" footers. Do you have any suggestions for me to try and use CS2M footers?
I really don't want to put them under the stock footers and raise the component 3 inches in the air.
They aren’t designed to be put under the stock footers
joelavrencikCMS
155
57
33
74
Steve's response was correct, of course, but let me add that we make an interface about 3/16" of an inch tall which can be placed under CS2M 1.5s to elevate your stock feet off of the shelf surface. They are available for purchase with the feet and are the solution you need.
RnRmf
96
42
248
Thanks for clarifying!
