Melco HA-N1Z / 2EX-H50 Digital Music Server - Owner Review (Part1)
exupgh12
782
1,063
235
55
Melco HA-N1Z / 2EX-H50 Digital Music Server - Owner Review (Part 1)​
I would like to apologize English isn’t my native language
This is a review of the Melco HA-N1Z / 2EX-H50 digital music server I purchased.
A few months ago I bought a Luxman D-10X player/converter, the converter in the player is made by the Japanese ROHM, and allows music files to be streamed via a coaxial/optical and USB connection.
Until I received the server, I streamed music files to the converter using the existing coaxial port on the Streamer / DAC Cary DMS600.
A few weeks ago, I purchased a digital music server made by Melco, a model with the long (immediate) name HA-N1Z / 2EX-H50 (hereinafter: N1).
Melco Audio is a Japanese company specializing in the production of servers and switches designed for the digital audio field. Melco is affiliated with Japanese network and storage solutions maker Buffalo.
The "Melco Project" was based on the following assumptions:
A. Most audiophiles do not understand computers and do not want to mess with a computer.
B. Standard computers are not suitable for high-end audio (operating noise / operating system optimization, reliability, etc ..).
The N1 was built as a universal music source and an audiophilic alternative to IT NAS for streaming systems via a USB connection or via an Ethernet connection (including music services such as Tidal, Qobuz, Vtuner, or Roon).
External CD can be added to the server for RIP execution.
In addition, using the USB sockets in the device, you can expand the storage directory (insert an external HDD) and even perform a backup with the click of a button for files stored locally on the server to an external storage device.
The EX2 model, or MK2 if you will, brings with it a number of improvements over the previous N1 model:
- Using a single disk with a larger volume instead of a Raid array
- Attenuation update for internal storage
- Improved power supplies and capacitors
- Software changes (there are 2 server programs in addition to Roon and a tagging software called Kongmusic)
Supported file format and sampling frequency:
Supported Formats Server - DSF, DFF, FLAC, WAV, ALAC, AIFF, AAC, MP3, WMA, OGG, LPCM, Player - DSF, DFF, FLAC, WAV, ALAC, AIFF, AAC
Sample Rates 44.1K, 48K, 88.2K, 96K, 176K, 192K, 384K, 2.8M, 5.6M, 11.3M
Build Quality
The N1 transmits a solid, high-quality overall look (thick aluminum that has been sandblasted) even if banal (you will not find here a convention-breaking design, round outlines, or CNC work that will make you stare at the device for long minutes), after all, it is a kind of "computer" and no one It would be wrong to think otherwise.
The four legs on which the device is made of metal (TAOC) and according to the manufacturer the specific metal has features designed to insulate the device from the surface beneath it.
The interior of the device is divided into H-shaped cells, in order to separate the power supplies from the network and storage components.
On the front of the device is a large and convenient on / off switch, OLED screen for displaying information (album name, singer, and other information related to the player file or production menus, respectively), although the screen is not large it is exceptionally legible even from a distance of 4 meters and more.
Also, on the front of the device are 4 buttons that are used to browse and select the server menus without the need to use the app.
At the back you'll find, a standard power connection, 1 insulated USB socket (with separate power supply) for output to the converter, 3 additional USB sockets designed [1. for a backup device, 2. for an external CD connection (in favor of performing RIP to CDs) and 3. for an external storage connection].
In addition to the USB ports and connections, the device has 2 Ethernet sockets, the first is used to transfer the information from a computer/switch and the second is used to transfer information from the server to DAC with an Ethernet connection (ie the N1 itself is also an isolated switch).
Software menus
The N1 creates while thinking about audiophiles or in other words, those whose computer operation is not close to their heart.
The buttons on the front allow you to browse through the various menus and allow any layman to set parameters and create the device even without reading its operating manual and do so using an app/browser.
The options in the Settings menu will allow you to set the screen brightness, date, type of server software to run (there are 2), enable file labeling software, network storage sharing, Roon connection, USB output mode configuration, DSD Flags, internal storage formatting and even Deleting the information so that no one after you can read what was stored in the internal storage device (this is done by writing and deleting the bits several times, an operation that almost certainly ensures that the content will not be recoverable).
If you are subscribed to music services that allow you to download files, the N1 allows you to create the account and the date when the N1 will download the files for you from the same service.
The remote control can be done using a browser (so Melco closes a number of options that could allow hackers to remotely exploit the server - smart on their part).
Audio files can be played using Mconnect software (or through a Melco app - Mconnect version) or in my case by Roon - the compatible device.
In conclusion, operating the device and manufacturing the device is quick and easy, these are issues that are particularly appealing to those who are afraid or disgusted by computer operation.
Reactions: howiebrou
Melco HA-N1Z / 2EX-H50 Digital Music Server - Owner Review (Part 2)​
Sound, how does the N1 + D-10X combination sound
For me, the N1 is connected to an integrated device (SACD \ CD \ DAC) by Lexman via a Cardas USB cable (Cardas Clear USB), in the future, I will diagnose additional USB cables.
Even before the end of the "break" of the device, there was no problem in distinguishing the outgoing sound from the D-10X compared to the streaming made in parallel from the Cary Audio DMS 600 device (via RCA Digital connection) to the streaming made from the N1 server, these differences sharpened as the N1 worked ..
In short - the combination of the N1 with the D-10X surprised me beyond the expectations and digital experiences I have heard so far with me or other friends, yes also converters at a price north of 100K NIS (roughly equals to 30k USD).
As someone who has already gone through a number of digital sources the first thing that suits the listener is the musical experience and excitement that the combination of the N1 + D10X produces, for analog lovers like me it is love from first sound, a digital sound that is not ashamed or apologetic next to analog.
And by elaborating ...
Emotions
- If there is anything that Analog manages to convey and to this day I have had a hard time accepting it digitally it is emotion, here the combination of the N1 and D-10X is hugely successful. the combination of the two managed to overwhelm veteran audiophiles from the abundance of erupting emotion.
Sound Organic - The sound is full of emotion and natural dynamism, the feeling that the only thing that can limit the sound emanating from the system is the quality of the recording.
Sound Textures - The combination of the N1 and D-10X manages to bring out a deep and dense layer of textures, these allow you to enjoy a particularly rich range between the lowest and highest tones.
Presentation - The N1 has excellent presentation capability to produce detail, separation, depth, stage, and 3D. these were not there at the same quality when the files were streamed through the DMS 600 media server.
Micro Dynamics - All the details of the tools, even the smallest and weakest, are easily distinguished.
Macro Dynamics - Noisy sections (drums slam, musicians' croissants) are difficult to impossible to come up with, the reaction here is immediate and bursts loudly whether it is a symphony orchestra or an electronic section.
Bass - Bass segments sound deep with a lot of layers, more than streaming through the DMS600 which excels in the lower range, I will note that the bass combined with the N1 + D-10X is a little more caressing though deeper than through streaming from the DMS600, this and much closer to what That I'm used to getting from my analog source (Brinkman Balance).
Vocal segments - the human voice sounds ... human (easy to say, much harder to describe), in short, you will not find here a hint of a digital artifact.
Combination N1 + DMS 600
For comparison and out of curiosity (although I already knew what the server brings with it streaming music) I chose to try to connect the N1 to the DMS converter unit (once with a network connection and once with a USB connection), not surprisingly you can also feel an improvement in sound this time. the music has become less flat and more clear, focused, rich and harmonious, in addition to an even more "black" background than what is obtained using the streamer built into the device.
Roon Connection and Integration
Music Server Software - The N1 comes with two music server software (Twonky, MinimServer) and tagging software (SongKong), I prefer working with Roon due to the richness and user experience that come with the software all ought in sound quality some versions of Roon can be drag behind the internal server software’s.
The integration with Roon is simple and fast, selecting the production menu in Roon as the control software allows, as expected, the N1 to be used as a Roon End Point (the connection to the DAC is made using USB or an Ethernet connection).
Roon immediately recognized the N1 as the Endpoint (after configuring the server USB DAC), and if you shared the N1's internal storage, Roon could play the stored files, as well as connect to music services like Tiddle and Qobuz.
Points for improvement.
Connecting to the DAC via a USB cable brings with it countless options through the use of different cabling - assuming in the coming months I will find myself testing USB cables instead of enjoying mentee music time - an advantage for devices that combine strangers and converter together.
Screen, albeit legible and clear but quite spartan and without graphics of the playing album, as the owner of a streamer/DAC that combines a large screen with high resolution that displays graphic richness including the album cover as well as detailed information about the playing file, this is a step back - really do not understand what the problem is In 2022, include media servers that display graphics richness such as Cary Audio, Rose150, Aurander, and others.
Hebrew Fonts Support ( I know that’s not a concern in the US) – No font support, the device's monitor does not display Hebrew fonts (song name, singer), instead you will see large squares - it's a shame.
8.5 / 10 user experience, compared to an integrated and polished device like the DMS600 which has the best user experience that can be found such as Remote on and off using Roon, flexible range of connections (Ethernet, WIFI, BT, USB, COAX, OPT) Nice graphical interface, built-in capabilities Like up sampling format conversion and more .... the N1 looks and feels much more spartan. Although the N1 allows control via the Mconnect app, Roon or browser and even sends the device to Sleep mode, it lacks the professionalism to do so in style and convenience such as using the iPhone.
For example, the last option (browser) does not transfer the production menus, as usual, these will show you a photo of the device when the production is done by simulating a push of a button on the physical device (scroll the mouse and click on the buttons of the drawn device - a bit puzzling).
Summary
Regarding the combination of the N1 together with the D-10X, although this is not a result that is equal to the analog stick I have (if we are honest, horribly expensive converters are not competition for an analog set at the level that I and some other forum members own), if it is the N1 + D combination 10X succeeds where almost every digital step I have heard to date has failed - to create an exciting, melodic, live, and dynamic sound, a sound that while listening manages to make me forget that the source of the music is in a digital files/streaming from the network, for me at least that says a lot about the duo's abilities.
Regarding the N1 only, if we put aside the (very light) operation (very good) construction, the Hebrew font limit, and the slightly spartan interface and concentrate on the main point - sound, then we are talking about one of the best devices that can be found in the "sane" price segment and I will not be ashamed To say that even at a much (very) high price than the price of the N1.
Emotions
Summary
Thanks for the great write-up which échos my own experience with adding a Melco to my integrated CD player.
In my case I added a Melco N1Z S - 40 to my Vitus SCD mk 2.
l listened to the N1Z H in parallel, but the S version was just plain better in All the areas you describe.
I also listen to Innuos Statement, Lumin and others with the Statement also outstanding, but I found a great deal on a 6 month old latest spec N1ZS.
ripped cds are better than spun CDs and down loaded hi_res even better.
USB cables make a very significant difference - I eventually selected a Tara Lab grand master evolution - amazing…even if rather expensive.
i don’t spin CDs any more.
streaming from Qobuz is not quite as good, but I’m still running in my network - Ansuz power switch D2 and D2 Ethernet With 3 net gear switched in between my router and the ansuz all powered by LPS.
like you I also have Brinkman Balance which I still prefer, but the gap is close enough that I can listen to both with pleasure.
Not a lot of love for Melco on this forum which is a shame as they are highly complétive and offer outstanding performance.
not quite the level of the very spendy Uber streamers, but I paid 1/4 of the price….
But I did listen to the new Tidal Arkus streamer which was on a totally different level……
@3125simon
Thank you so much for your comment, and elaborated experienced opinion on the Melco server and USB cables.
Reactions: Armsan
You can get many good tips for the Melco in www.hifistatement.net.
For example you better use the Ethernet connection instead of the usb connection.
And use a switch.
And you can easily exchange the HDD to a SSD.
My personal favorite is the Samsung 860 pro 4 Tb.
Reactions: exupgh12
And use a switch.
Thank you for the comments and link.
I recently compared my N1ZS/2 to the new N10/2. N10/2 delivers N1ZS/2's goodness to a slightly higher level.. clarity, noise level, separation etc. Not a day and night difference but easily perceivable.
Reactions: exupgh12
Thank you Kimurastanley for your hint to the new N10/2 with his additional linear power supply.
Seems to be a real progress to the N1Z with the integrated two switching power supplys.
There is a rewiev in hifistatement with pretty pictures:
www.hifistatement.net/tests/item/3349
Reactions: exupgh12
Emotions
Summary
I realize this is an older post, but I just replaced my N1Z/2 with the newer N1 and right out of the box the difference was amazing. I never dreamed that a sever could make such a dramatic difference in a high end system. Listening to a few familiar favorites, I immediately heard a more musical presentation from my system. Biggest difference was the amount of detail that I was missing with N1Z. I started hearing instruments that I never heard previously, and everything was much more transparent. Can't wait until this unit breaks in.
Reactions: exupgh12
Thank you for adding your experience, it's great to know the new line had improved performance.
