What are the Top Horn Speakers in the World Today? Vox Olympian vs Avantgarde Trio vs ???
Blue58
899
686
1,155
London, UK
Reactions: G T Audio
Fred Crane
272
443
135
No, it is Charney Audio.
Ahh, I had forgotten about Brian's work. Shame on me. I didn't know he was offering field coils but it makes sense that he would.
yes I am aware of Dave Slagle's Lowther FC though never got to hear it. A guy who had made horns out of that moved to Slagle's stacked quads I think, if you are referring to John P on the gon.
Two different guys I believe. I never really adopted A'Gon's forum. I'm sure there were/are some interesting bits there.
yes but the whole point of running full range AER is not having a crossover, imo, to bass bins. The AER in Oris were up to BD3, even lower, and there were significant jumps to BD4 and from BD4 to BD5. Bill and I heard from BD4 to BD5 and Murat has a video where he shows difference between BD3 and BD3b.
To a point I agree, though I've heard a few compelling systems wherein a full ranger was employed as an extended midrange to fine effect. In my room at that time, listening to my typical fair, (a fairly eclectic mix with highlights in small group jazz, chamber music, big bands, orchestral, what I would call New Orleans rooted music and some contemporary classical) the bass bins gave more than they took, running the horns full range. I suppose it comes to taste and environment.
Yes I love dual woofer front loaded horns which do exactly that, have a good CD on top and two woofers at bottom. You can throw any music at them and they can accommodate a range of SETs and low watt push pulls. You don't lose anything on a Pnoe BD5 listening to large orchestral works like Beethoven 9th or Mahler 2. In fact you gain more because not having the crossover increases the dynamic range. But this can be heard only on high quality LPs.
Great experience on your part, though, having gone through these horns.
It sounds as though this train of discussion is headed towards a listening expedition : )
Reactions: Willgolf
wil
1,522
1,551
428
The horn colouration you heard is down to partnering amplification, cabling and system set up which the AG's are extremely critical of. If its not done right you will hear it!
Wood horns will produce more colouration than ABS or Kevlar if done correctly. Remember spherical horns are as near to perfect horns you can get. Cessaro when from machined wood horns to their current kevlar/glassfibre horns and the difference between the two from an audio prospective was night and day. If you were making a horn today there is no reason to use wood, other than because it is cheap. There are vastly better materials available today to make good horns from.
Interesting. It just seemed, on an intuitive level, that a wood horn would remove the plastic coloration that I (imagined?) I was hearing. The coloration I heard from the horns was never due to amplification. It always seemed to be a result of horn material itself.
The best amplification I found by far, after years of trying different SET tube amps, was the solid state Bakoon 23r. It had the AG's absolutely singing with unforced, natural sound. The Enleum low watt amp is the new version of the Bakoon.
bonzo75
22,650
13,688
2,710
London
Sorry - to clarify, Charney is making AER based speakers, BLH, smaller than Pnoes. Not field coils
Oh you have been on my watchlist :) - my US trips will take time.
Fred Crane
272
443
135
We're welcoming a new location in France later this year, so perhaps neutral ground : )
  • Love
Reactions: bonzo75
Audiophile Bill
4,293
4,093
675
What you have written is perfectly correct. It is also a monumentally more complex thing than one first thinks. The type of material is only one component to it, the thickness of walls, finish, type of wood, adapter - literally everything make a difference.
Also to be clear - making a horn in “wood is cheap” is an idiotically ignorant statement. If one were to attempt to make a full Cessaro type horn in solid ebony (which would be extremely challenging but technically viable) or rosewood, the costs of materials alone would be horrifyingly high let alone getting someone to risk the manufacture.
There is very good reason that Aries Cerat employ wood in their horn systems including Symphonia, Contendo, and their new model. There is also very good reason that Sierra audio do the same as well as many others - it isn’t because they can do it cheap lol.
Unfortunately everything has a resonance profile that imparts some form of its own impact on the end product. It is no surprise that some people adore the sonics of paper cones / woofers modern and vintage and can’t stand glass fibre and other materials for their drivers. This is no accident.
Your experience is reflected in my experience and many others. I have ABS and wood horns in same profile and one can easily hear the substrates. One can hear the substrate in Cessaro horns as well as the Pnoe easily. Your brain adjusts pretty rapidly though and it doesn’t make them bad but the colour is there. To claim otherwise is nonsense.
Also Amplification has little impact on this horn substrate colour. I have heard Pnoe with all manner of amps and the same profile is there regardless.
Sorry - thought I would share not only my direct experience but opinion on this topic.
PS. Ask Stavros about costs and difficulty together with rationale in manufacturing his Contendo mid bass horn lol. It is one thing me saying it, but best coming from a large manufacturer like that. Or watch a video from the Aries Cerat YouTube page.
morricab
9,532
5,070
1,228
Switzerland
Indeed, very well said Bill! Just because Cessaro changed from wood to synthetic materials doesn't mean anything definitive over and above the implication that the designer preferred the colorations from his new horns over his old wood ones. At least in going from the small Chopin to it successor Wagner, it seems that they also may have changed the profile of the horn and also possibly the compression driver, both of which could have a profound effect on the sound.
Reactions: Argonaut
morricab
9,532
5,070
1,228
Switzerland
I can also say that one of the reasons I think I like AC horns and Odeon horns has to do with the wood horns.
bonzo75
22,650
13,688
2,710
London
Only the new 80+ k Odeon are wood. Where are the 28, 32, 38 wood? The horn part was composite.
morricab
9,532
5,070
1,228
Switzerland
No its not...it is lacquered wood.
morricab
9,532
5,070
1,228
Switzerland
THE ODEON AUDIO SPHERICAL WAVE HORN​
THE SHAPE MAKES THE SOUND​
The most important basis for the quality of our loudspeakers are the specially developed spherical plywood horns with their individual curve. ODEON AUDIO is the first company to serially produce horns made of solid layered birch plywood blocks. In several years of development, we have succeeded in creating a shape that ensures maximum linearity and dynamics to properly reproduce all types of music.
The shape and material of the ODEON AUDIO spherical wave horns prevents exaggerated frequency dips and peaks. Extraneous resonances are also reduced using our horn technology for a clean and tonally balanced reproduction. Odeon’s main designer Alex Gersdorff has developed breakthrough concepts that eliminates prejudices against horn loudspeakers and convince even customers who are skeptical about high-efficiency loudspeakers the benefits of new horn technology. Helix_walnutroot.jpg 48423-da5be522e3148636f034e65fa2933c4a.jpg laboheme.jpg
G T Audio
I, along with many others were witness to the differences in horn sound when we exhibited with both wood horns (Munich 2012) and carbon fibre/rubber resin horns (Munich 2013 & 2014). The lack of colouration was significant going from wood to modern non resonant materials which is why Cessaro made the huge investment in making the change for future production of horns.
Audiophile Bill
4,293
4,093
675
This “non colouration” is a misnomer - it doesn’t exist. I have heard big Cessaro systems on many occasions and it is always quite obviously present as it is for AG. I am not criticising them btw - they are beautifully engineered products in their own way. And by the way, their bass horns are wood covered in car paint unless I am misguided.
manisandher
243
217
950
www.the2ndtier.com
Yep, that's why musical instruments are made of such materials. Oh wait...
G T Audio
My reference to wood horns being cheap, is anyone can get a few sheets of plywood, which is what the majority of commercial horns are made from, cut them into squares sections and glue them together and then machine them on a wood lathe. This is cheap when you consider the huge cost of getting moulds made for serious production. I remember talking to Holger Fromme (owner of AG) back in the mid 1990s and he told me the moulds for the original Trios were massively expensive. Think in excess of €100,000 for each horn. From this you can also tell who are the serious manufacturers. Anyone making horns out of ebony or rosewood would either be in very small scale manufacturing, or the DIY arena because a lot of that type of wood is banned from use in a lot of countries today.
Audiophile Bill
4,293
4,093
675
Agree Mani. And then you’ll hear back that this isn’t relevant argument but it fully is because everything has a resonance profile and sounds. Imagine your Anima’s mid range replaced with a big ABS Oris. I have a hunch that you’ll not like it as much.
Reactions: manisandher
manisandher
243
217
950
www.the2ndtier.com
Bill, you'll no doubt recall that I had the Swings a while ago. Nice enough in some areas, but having natural mids wasn't one of them. Maybe carbon fibre/rubber resin fixes things, but personally I'll stick with wood (for bass, upper-bass- and mid-horns at least).
Reactions: Audiophile Bill
Audiophile Bill
4,293
4,093
675
The use of vaccum formed plastic is due to scale, reproducibility and speed of manufacture after having forked out the up front costs of moulds. If you look at the process to CNC mill a Aries mid bass horn on his 5 axis etc versus sucking a bit of plastic over the mould and injecting it with gel you’ll realise the time difference.
Ebony and rosewood were just 2 woods that came to mid and you miss the point. It could be any other decent hardwood as employed by OMA for instance whether that be Ash, Oak, doesn’t need to be protected.
G T Audio
You won't find many musical horn instruments made from wood apart from the Oboe, Clarinet and bassoon and these are not strictly horn instruments. Whereas the Trumpet, Tuba, French horn, Saxophone, Trombone are all made from brass not wood.
Reactions: HughP3
