Which BNC 50-ohm cable for NHB-108 and NHB-18NS interconnection
manjy
53
18
913
Thanks mike
For the true story of why Herve uses the ‘zeel’ 50 ohm BNC interface; here is an article he wrote in the Sept 2001 issue of Stereophile, page 59 to 69. “Reflections, Echos and Music”.
this article was written prior to the brand 'darTZeel' being launched.
Thanks Mike. Would you have the full article? would be an interesting read.
Mike Lavigne
Apr 25, 2010
12,596
11,689
4,410
Thanks mike
i do have the Sept 2001 issue with the article. Herve does clearly (AFAIK) lay out the shortcomings of conventional interconnects, and i've been told it holds water scientifically although it's beyond me. i can get the drift of the points but not the details.
i've done enough A/B cable compares over the years to believe.
manjy
53
18
913
I found the 10mm Zeel cable very stiff and not easy to route. My pre and amp are close to a back wall, and curving the cable was not easy.
My preamp is on a rack behind me and the power amp is in front between the speakers. They're about 20' apart and I have a 1.5" diameter conduit going under the floor between the 2. I'm wondering if I will be able to route a pair of the 10mm cables through.
Zeotrope
1,796
1,415
230
49
France, Canada
I think so but you’ll have to manhandle it a bit. The biggest challenge for me was angling the cords at the BNC connections on the amp and pre, since the components are very close to a back wall.
manjy
53
18
913
Thanks.
Has anyone compared the 8mm with the 10mm cable? Is there a significant jump in SQ?
Zeotrope
1,796
1,415
230
49
France, Canada
Has anyone noticed if the Dartzeel BNC cables are susceptible to increased background noise if in close proximity to an AC cord?
DasguteOhr
2,439
2,619
645
Germany
MRubey
104
102
95
65
San Antonio Texas
There are a lot of choices of Huber Suhner at Mouser. Some are made for offshore petroleum exposure.
It deserves more research than I’m going to do right now but this one looks interesting.
Silver over copper. About 5mm.
