Having read the articles, I will have a lot more to say laterAs I posted on that forum, if two "identical" files with the same playback chain sound different, then either the files aren't identical, or the listening test methodology is flawed. Are there other possibilities I'm missing?
... If we are to believe that fidelity changes as we play one file vs another, then doesn't that invalidate all the testing they did? I mean if that is the case, then the performance of the fixture (PC + outboard DAC) is so variable as to make any kind of testing with different files impossible. After all, if the mere fact of moving the bits from one place on hard disk to another makes the sound different, maybe that is why the lower sampling file sounded worse than higher sampling! One can't buy into one argument and not the other. Ditto for their testing of different sample rates in JRiver. Maybe all of that is due to CPU usage changing and nothing to do with any fidelity differences due to sampling rate.
... They could have kind of ruled that out by changing the CPU load arbitrarily and seeing if that changes audio.
I(...) Although TAS is not as influential as it once was, I still think it's completely irresponsible for a well-known specialty (print) mag to publish something like this.
So, the earlier post was correct to say the differences were due to defects in the playback chain. That is 100% correct. But it was not correct to say such things are audiophile nonsense ...
Frank
...This paper tries to analyze and opens the discussion on many aspects related to music servers, that are kept hidden from debate until now, or at less not so openly. It is not a prescription book, perhaps an introduction more clearly stating it would be welcome...
Indeed this has been my primary concern from the beginning. Although TAS is not as influential as it once was, I still think it's completely irresponsible for a well-known specialty (print) mag to publish something like this. Among other things, it seems to be trying to undermine the whole foundation of computer audio by implying that 2 identical computer audio files may sound different for undetermined reasons.
And again as Amir says, if the testing methodolgy is flawed (and it must be to have the findings reported in this post), then none of their conclusions can be considered valid, even though some probably are.
JAES is peer reviewed. AES convention papers and posters aren't.Rbbert,
I have to disagree on this point. TAS is not IEEE. Even AES, as some of our members explained before is not a peer reviewed publication.
fas42 said:But it was not correct to say such things are audiophile nonsense ...
The "defects" I talk of are that the electronics on the analogue side are affected by what's occurring in the environment, specifically the type of processing activity on the server. Of course it shouldn't, therefore it is a "defect" that there is such an occurrence.I don't see where anyone called it "audiophile nonsense". What I'm saying (is the problem) is that defects in the playback chain ---were not even considered--- as possible explanations for the observed phenomena. Not in the original article, nor in the avguide web responses.
Unfortunately, very unfortunately, that is exactly the case. A car analogy goes nicely here: a bog standard family sedan will do the job nicely of carting the family around the suburbs, with the engine out of tune, any old tyres will do, etc, etc; but get your decent Ferrari, put the hammer down, and the slightest mismatching of tyres or flat spot in engine performance will be screamingly obvious.Obviously I beg to differ. 'Everything affects everything' makes it sound like audio systems are hothouse flowers negatively affected by the slightest change. But that renders the concept of 'tolerances' meaningless. Evidence suggests the contrary: that there are measurable variations that don't have any significant effects on system performance.
(...) 'Hidden'? By whom? You might be surprised to learn that such issues have been dissected before, albeit on more 'skeptical' audio sites than perhaps you are familiar with.
... the most controversial aspects in this article...?
There isn't likely to be much discussion about how two identical audio files can sound different, which is likely the single most controversial assertion. But there's a fair amount of discussion about the upsampling on www.computeraudiophile.com
Unfortunately, very unfortunately, that is exactly the case. A car analogy goes nicely here: a bog standard family sedan will do the job nicely of carting around the family around the suburbs with the engine out of tune, any old tyres will do, etc, etc; but get your decent Ferrari, put the hammer down, and the slightest mismatching of tyres or flat spot in engine performance will be screamingly obvious.
In other words, the more ambitious the enterprise, the more glaringly apparent will be every minor imperfection ...
Thanks. Can you point us some direct links or references to articles that debate the most controversial aspects in this article in a systematic way you consider valid?
BTW, what do you mean by "skeptical" audio sites?
The Hydrogenaudio.org forum has discussed the 'flac sounds different from wav' fallacy numerous times, among many other audiophile fallacies. It's discussing this article right now. (...)
The article we are discussing is based on blind tests. So that remark doesn't apply. Indeed, that is what makes this report interesting in that it starts off with very high level of objectivity yet arrives at conclusions that are normally associated with not-only sighted testing, but wishful thinking!A skeptical site is one that views claims that appear to fly in the face of known science (including psychoacoustics) and technology with a critical eye. It does not accept 'sighted' reports as reliable or even credible without some objective supporting evidence.
I was replying to the "hothouse flowers" comment in the context of the level of performance seeked, and expected of the system; not some seemingly bizarre connections between ability and conditions. No-one expects an ordinary family car to operate to high standards, but everyone would be disappointed if the Ferrari was ill-mannered in significant ways. So for an audio system: if used to supply background music, no expectations; but if the volume is wound up to realistic, natural levels, and you're listening to how well the qualities of a solo violin or solid drum kicks are reproduced, then the slightest perturbations in the tonal qualities will be very audible, and disturbing if negative in quality.So often do audiophile haul out the auto analogy, and so often does it fail.
The better analogy to the audio under discussion would be more like, reporting a perceivable performance increase due to using a different car wax. Or a different tyre inflator plug. Will you notice that more in a Ferrari than a Ford?
The plain fact is, not every variation matters to performance in audio -- or in cars. If your audio system is really such a 'hothouse flower', I would suggest you replace it with something more robust.
