Does the Nuforce and BDP play SACD? I thought not
Why else would I consider it?
It will not. All stock OPPOs output 24/88.2 from SACD.I am auditioning the MSB Technology UMT which is, at it's core, an Oppo 93. For SACD playback it sends out a 24/176.4 stream over all digital outputs. I have it hooked up to the Bricasti M1 and I'm rediscovering my SACD collection. I've been told a stock Oppo 93 will output the same 24/176.4 signal as well.
On a brief tangent, The UMT is an impressive piece of gear. On Redbook playback it was easily as good, if not better, than the Accustic Arts tranport I've been using the past 4 years.
I think it is unlikely as the difference in my experience is tiny and elusive. Also, as discussed in other threads/forums, there may be reasons to prefer 96kHz for signals being communicated between devices.Will a system not consisting of SOTA equipment, but a fine one nonetheless be able to tell the difference in resolution?
The UMT may do it but stock units will not. That suggest that those smart guys at MSB have done some deep work.I have not tried a stock unit. This what I was told. The UMT is definitely outputting 24/176.4.
Ah. So, we do not know if the MSB guys have modified the device to convert DSD to PCM at 176.4 or if they are simply upsampling the regular 88.2 conversion to 176.4. Curious.SACD - not Redbook. The UMT does PCM conversion into 24/176.4.
Quoting from Vade Forrester's review on the Ultra Audio site:
"If you’re wondering how you’d play an SACD through a standard DAC, so was I. Basically, the UMT converts SACD’s DSD signal to PCM. But wait -- wouldn’t that infringe on Sony’s licensing agreement? Indeed it would; so, to honor that licensing arrangement, the UMT can play SACDs only through MSB DACs, which have a proprietary connection. With that connection, when you play an SACD the front panel of the DAC tells you it’s converted the DSD signal to 32/384 PCM, then downsampled that to 32/352.8. Want surround sound from your SACDs? The UMT is currently just a two-channel model, but a surround-sound version is coming -- for another $1995. "
I would appear that Mr. Forrester is only partially correct. The UMT can play SACDs through any DAC. Over the AES/EBU it is passing the DSD converted to PCM signal at 24/192.
And to really beat this to a pulp, Nicholas Bedworth said the following in his Postive Feedback review:
"For example, according to the UMT's designer, Dustin Semansky, rather than relying upon the low-level processing circuitry in the Oppo 93 board, he instead grabs the raw digital from the media (CD, USB thumb drive, etc.) and places it in a buffer memory. Thereafter, the digital data are transported through MSB-engineered gates and line drivers, without any additional processing or upsampling, to the outside world.
All the audio streams, except for SACD, are handled in this manner. In the case of SACD, the decimation step (meaning the conversion of the 1 bit delta-sigma SACD data into standard PCM formats) is performed on a special MSB board connected to the Oppo "core". As a result, MSB can guarantee bit-perfect and low-jitter bit streams for all these formats, even up to 384 kHz, 32-bit samples, for those listeners who opt for MSB's new Pro I2S Network II."
Curious, indeed. I have 4 different OPPOs and all output 88.2 only. I also have modified OPPO which outputs 3xS/PDIF and, again, at 88.2 only. It is not a processor limitation as other players will feed 176.4 to the same processor. This conflicts with ""It's an Oppo thing. We didn't do anything to it." I will contact Vince about this for clarification.Kal:
I didn't get into a heavy conversation with Vince Galbo (MSB Sales Manager) about this but we did discuss it. A recent review of the UMT specifically said that it would only pass a 24/176.4 signal to the MSB DAC via its proprietary connection. I asked about this. Vince then told me that it would pass the same signal to the Bricasti over the digital outputs. He specifically said (and I'm paraphrasing) "It's an Oppo thing. We didn't do anything to it". I was of the impression that a stock Oppo 93 would the same as well.
Beyond that all I can tell you is that the Bricasti is locking on to a 176.4 signal and I've been able to blow dust off a small section of my collection.
Ken
I run an Oppo 83 that has been modd'd a bit thru a Valhalla BNC cable into my Zanden DAC. a lot of people think i'm crazy...but i get to play movies thru Zanden, etc and it works blooy well while i wait for SOTA transports to come down in price, or music servers to improve in quality/ease of use. And if/when i do go SOTA transport or server...i've still got an Oppo that can play movies thru my zanden DAC. i like the flexibility.
the question is...has anyone actually compared the Oppo transport (via digital out) to higher-end transports? believe it or not, i have not done this yet. I have been told categorically, this is a big weakness in my system.
I had, the Oppo is good, but my Accuphase transport sounds with more body and gives more detail in instruments like strings and drums.
Lloyd, I could be wrong, but my guess is that the difference remains on the PSU used in either units.
