I think this is a rather important paper in the discussion...been referencing it for yearsAn interesting paper on the topic of this debate: https://next-tube.com/articles/Cheever/cheever.pdf
Interesting!Shindo sounds good, the probem is in earlier models used carbon mass resistors that have not been painted, their values change depending on the humidity in the room. the device sounds different every day. can be exciting for the listener.they have to be baked dry afterwards varnished. then measured and matched. then there will never be coloured again. ExsampleView attachment 109137
This looks more interesting:Soundgate has a parallel 45
What tubes do I need to buy to make this amp sing. As in, do I need some old stock that are really expensive. Or are there newer tubes that are more in the $300 each range that sonically work well.
I don't think the 6922 is a good choice for any audio application. Frame-grid triodes of this type can be quite linear, but microphonics are always a problem. Having done this a while, I'm really not a fan of miniature tubes in a power amplifier, unless that power amplifier is using feedback. How the voltage amplifier and driver circuit behave have 90-95% of the 'sound' of the amplifier most of the time.Sorry to hear i look at the specs I find the values very optimistic in terms of distortion. Normally, at full load, they are between 3.0 and 10% with set amps. the low weight makes me suspicious, good main and outtransformer re heavy for 211/845 high voltage. it could be that one of the two is running at the limit and thus produces hum and noise. I don't want to badmouth this amplifier, I don't know the structure and components that are used. But the values are unrealistic
- Type: Zero feedback, single-ended triode mono power amplifier
- Tubes: 1× 845, 1× 6922/6H23N, 1× E182CC per channel
- Power output: 25W Class A into 8?
- Loading: four and eight ohm nominal
- Frequency Response: 13Hz–34kHz ±3dB
- Distortion: <?0.1%
- Noise: <?(CCIR) –90dB
- Sensitivity: Variable >?150mV full output
- Dimensions (W×H×D): 26×25×46cm (per channel, excl. tubes)
- Weight: 12kg per channel
Its hard to imagine one sounding better than the other. As I understand it, AC filament power is used to prevent hot spots occurring on the filament of the power tube. So this is to get longer life out of the power tube (or any DHT for that matter). But just because AC power is used for the filaments there still should be no hum.The noise and hum of SET amplifiers is not their property, but a designer's error. Or the user's religion.
When I made a SET amplifier for 6B4G for speakers with a sensitivity of 102 dB, I had to rectify and filter the voltage for powering the heaters well. But there are users who fundamentally want the heaters to be powered by alternating voltage. It sounds better to them regardless of the hum. I call it religion.
They are more expensive. I don't know anything about the GM70 tube. I hear talk about the 211. Never really sat with either.
Cheever's opening statement is no longer true, although it for the most part was in the 1980s. He bases some of his comments on stuff from Stereophile- I remember Robert Harley exclaiming in a later issue that 'no-one knows why an amplifier can measure so poorly and yet sound so good' (paraphrasing). In this statement he was wrong- he didn't know the right designers or didn't ask them. Sometimes you have to make your hand move to get things done...I think this is a rather important paper in the discussion...been referencing it for years![]()
It's hard for you to imagine, but this is actually the harsh truth of life.Its hard to imagine one sounding better than the other. As I understand it, AC filament power is used to prevent hot spots occurring on the filament of the power tube. So this is to get longer life out of the power tube (or any DHT for that matter). But just because AC power is used for the filaments there still should be no hum.
You seem to be quite knowledgeable about many things audio and I do mean that as a compliment.Shindo is quite coloured. The fact that some SETs are coloured does not mean colouration is a trait of SETs
Personally I find the Shindo quite musical! I am not sure I know what perfect is or heard perfect even at live events. Do the Shindo components have a particular colouration that bothers you? I am assuming you have heard their components in appropriate environments.
Thanks for the well considered reply. I will look for the previous information on this thread.yes the Shindo Giscours and Monbrison were compared with the top of the line Shindo Amps, and direct without pre amp. The person who owned the Giscours also later preferred the dartzeel preamp into his Shindo power amp. I compared that Shindo power amp to an ear push pull power amp on tannoy reds, and in another system posted on this thread the Shindo 300b power amp you will see comparisons and also the Monbrison was compared the basic Mayer 10y copper, with a Shindo power amp. I have also heard the entire Shindo system and compared the Shindo Garrard 301.
i am not saying it isn’t enjoyable. And the Monbrison for its price is very good value for a 1 box phono plus preamp with only Ear as competition at that price. But I prefer more neutral SETs and cleaner tubes in general
Looking through your impressive system I could not figure out what you are using for an amplifier. Perhaps you have many choices?
Do you have some specific suggestions for more neutral SETs?
Aries CeratThanks for the well considered reply. I will look for the previous information on this thread.
The case the Audio is built in is a piece of junk. You can not access anything from the bottom. You cant access through the top. You have to unsolder the amp to get into it to do any work.
The iron is good. That is not the issue. My belief is there is a circuit board PS sitting over the transformers and either the CB is a piss poor design or its picking up emi from the transformers. I have installed a piece of magnetic metal around the toroid power transformer and that blocked some noise. But it goes further than than.
If someone were to mess with this amp again, it would need to be removed from its case, landed in a new one, completely rewired. Basically I would be handing some iron and sockets to an engineer and saying, make me an amp. Which Ken of Soundgate said he would do. But, what do I end up with.
I once had a monbrison, a friend also, really good preamp you don't need more to listen to music. but they 2 monbrison looked different inside other components. not meant to sound bad but he used what he had in stock to build the amps. the f2a poweramps are a masterpiece, one of the best tubes ever made from siemens.Interesting!
I had never heard of anything like that before.
My components are the latest edition, hopefully I won't have similar issues.
I'm a big fan from ecl/ecf pentode driver for power tubes.very linear, gain variable triode or pentode mode. energetic lifelike sound love it.Cheever's opening statement is no longer true, although it for the most part was in the 1980s. He bases some of his comments on stuff from Stereophile- I remember Robert Harley exclaiming in a later issue that 'no-one knows why an amplifier can measure so poorly and yet sound so good' (paraphrasing). In this statement he was wrong- he didn't know the right designers or didn't ask them. Sometimes you have to make your hand move to get things done...
I like that he shows the IMD does not correlate to THD as so may purport. When our amps got measured by Glass Audio, they found the IMD was quite low, much power than the THD.
Much of what is stated in this article is stuff I've been pushing for a long time. What I didn't see though was any talk about distortion vs frequency. In a zero feedback amplifier, this will be a flat line across the audio band. If not flat, other tones will be heard and will contribute to harshness. So it was implied...
Yes , I understand this to be the case , I came to my own Cortese F2a having spend some time with the Siemens F2a11 valve modifying vintage Audiomaster 11A mono blocks to run the Siemens F2a11 instead of EL34’s in those amps, via socket adaptors and a couple of component changes , this was all the rage amongst a couple of guys on the Review 33 forum at one time.I once had a monbrison, a friend also, really good preamp you don't need more to listen to music. but they 2 monbrison looked different inside other components. not meant to sound bad but he used what he had in stock to build the amps. the f2a poweramps are a masterpiece, one of the best tubes ever made from siemens.
This tubes runs 30 years without problems, good choice and nice amps.This is a pair of Audiomaster 11A’s adapted to run the Siemens F2a11 owned back then by Marantz7c ( forum handle)
Apologies for the slight Off Topic .
