Manufacturers recommend CAT6 cables so as to eliminate the possibility of a shield-tied cable messing up the sound. There are ways around this and worthwhile to experiment, IME.
I have some BJC CAT6a cables which are shielded but the shield is not tied to ground. I use this cable in non-critical areas. It is extremely well made and has guaranteed specs. Unfortunately it does not sound as good as some of my other cables.
All ethernet cables from Audioquest, the Melco C100 and most likely others have the shield tied at one end only. I've modified STP and S/FTP cables by removing the gold wrap from one end, leaving only the non-conductive plastic. I've modified CAT8 cables by replacing one metal RJ45 connector with a generic plastic connector. I had one of my Furutech cables modified, upgrading both connectors with Telegartners and lifting the ground on one end. In some cases I use a LAN Isolator to break the ground connection, a strategy also used by SOtM for their ethernet cables.
Sometimes I use a shield-tied cable, with precautions. The EtherRegen B-side port is one situation where this is acceptable, I use a shield-tied cable between my switch and FMC, but both devices are electrically connected to the same ground point. Also, I only allow one cable with a shield to be connected to each device. Other connected cables are UTP or have the shield ground broken by one of the methods described above, which blocks shield current coming from a third device. I do all this because in my experience STP and S/FTP cables generally sound better than the many generic UTP cables I've tried. I have no doubt there are CAT6 cables with elevated sound quality and price, which I have not tried.
