I use the Stromtank S2500 quantum for all my gear except the amplifier.
Very pleased with the improvement.
i also find I can listen at slightly lower volumes.
Not sure why it lost you the dynamic. But it’s perfect here. Lots of dynamic with s2500 in my system. Only sources and pre are connected to it.In my point of view, Stromtank is a over-price product, you get a better music density, more details but with the trade-off cost of power swing, dynamic constrast and lively performance. The sound become softer, more calm down and relaxed, but loss the feeling of exciting let you gone with the music.
Some kind of problem related with the build quality, with a high price tag it should be better
+ The internal cable inside Stromtank is not an audiophile grade just like a popular electric cable
+ The grounding bus bar inside is too small and not good enough for a good earth ground path
+ The chassis is not thick and solid enough
Even I tested the 2500 quantum for only my MSB Digital Powerbase, it got the same result.
One of my friend who have an extreme power soultion with Stromtank but still have a slightly dynamic trade-off
+ S1000 for the CD source
+ S2500 quantum for preamp
+ 2 x S5000 HP for each poweramp (left & right)
+ Earth grounding enhancement for each unit
Please try it with home demo and listen it in your system before you decide to buy.
Is there any grounding enchancement boxes in your system?Not sure why it lost you the dynamic. But it’s perfect here. Lots of dynamic with s2500 in my system. Only sources and pre are connected to it.
No I wasn’t aware of the possibility of enhancement packages.Is there any grounding enchancement boxes in your system?
Although Stromtank is battery power bank, but when you change the hign quality cable for it the sound will be much better.
I don't see any issue with build quality. The real meat and potato is going to be the output inverter. Is it a stock unit packaged in a nice box with a couple lithium battery. Or something better. My experience tells me they found a good inverter. Its almost impossible to get a plant to make anything on small scale. But I don't know.It looks pretty good to me.
Much more importantly . . . Rex, what do you think?
It's a comparison between MSB Digital PowerBase > QB8 > Main Wall Duplex Socket vs MSB Digital PowerBase > Stromtank > Main Wall Duplex Socket.Dear Sir,
Thank you for sharing your experiences. When you are talking about losing dynamics, are you comparing this in terms of having the components plugged into the wall or to other audiophile power concoctions (Shunyata, synergistic, ansoyuz, audio quest, etc.)?
Maybe these audio companies are "adding" stuff to goose the dynamics to please audiophiles?
As far as all of this audiophile stuff, it all exists to make money. But I don't think anyone knows what the "truth" is, how it will work in ones system, match anyone's taste, or match the taste of the audiophile herd to raise the particular brand over the others.
But your observations are very interesting
Yes you're right, for a AC-DC-AC solution the inverter is very important thing. But for the audio, AC current is not enough esspecially for hiend audio, you need to play with some enhancement solution for a better signal ground, chassis ground, earth ground.I don't see any issue with build quality. The real meat and potato is going to be the output inverter. Is it a stock unit packaged in a nice box with a couple lithium battery. Or something better. My experience tells me they found a good inverter. Its almost impossible to get a plant to make anything on small scale. But I don't know.
I know 3 people with Stromtank. All use it on the front end and like it. Non use it with an amplifier .
I wonder how it differes from a PS Audio P20 or other battey unit. The technology has been around for a long time.
For comparison, I looked around and talked with a bunch of inverter manufacturers and battery packers. A smoking good inverter with high peak power and low distortion is about $4k to $5k. Think twice the power of a Stromtank S5000. Each LIFeP04 battery that is equivalent in size to a S5000 is about $4500. The output of the inverter would go to a Torus RM40. You now have the equivalent power of 2 x S5000 for about $18k in parts.
FWIW, this is basically how Equitech handles power distribution in area with fluctuating voltage. In other words, what I described above has been used in thousands of homes with great success. Equitech specifies an industrial all in one box UPS, but the concept is the same. I too sought out UPS for audio use. But to me, they all used a lead acid battery, were very large and very expensive. Maybe $30k for the UPS. And every battery has a sound. Lead acid is slow. Lithium is supposed to be pretty good.
More and more people are using something like a Tesla powerwall and going direct to the rack or to a Torus wall mount, then the room. Tie that Tesla to some solar and you now get fed and local rebates for the gear. There are options.
Please take a look inside, they should have a better audiophile build quality with their price tag.
View attachment 112082View attachment 112091View attachment 112092View attachment 112093View attachment 112094
