I have a MSL Platinum Signature as my second cart! But different systems perform differently. I have a Vitus Masterpiece Phono stage ordered. So, I may change carts at that time.But is it different enough as a secondary to a well loved Lyra Etna?
I have Magico m2 btw
I followed your journey to the m3
Does the plat and opus sound similar or notably different? Made by same gentlemanI have a MSL Platinum Signature as my second cart! But different systems perform differently. I have a Vitus Masterpiece Phono stage ordered. So, I may change carts at that time.
I don't think the Etna and Opus 1 sound similar. I own and prefer the Opus 1, but I was able to demo an Etna (though a Lambda SL version).
Ask Tony about a Fuuga.I have a MSL Platinum Signature as my second cart! But different systems perform differently. I have a Vitus Masterpiece Phono stage ordered. So, I may change carts at that time.
I agree. But prior to the Lambda generation I do think the Etna was the least Lyra-like with the least analytical Lyra house sound.
Within the Lambda line, what is your assessment of Etna and Atlas, if you've had the opportunity to hear them?
The Opus is more like Koetsu then Lyra vs Koetsu. I’d say the Opus just the opposite to Lyra. So YES, you can definitely go with an Opus as a secondary cart to Lyra, because they will perform completely diffrent to your records. It will be a very good compliment to one and other.The Lyra and Airtight seem to be different enough in built (naked housing vs bodied) that perhaps it will give me a good enough variance between the two without having to go Koetsu for the 2nd cart.
Maybe a Koetsu for the 3rd someday then.
