I'm close to retiring and making a significant effort to upgrade my audio system, so I thought I would share that process here and perhaps get some advice on rooms, cables, power and components. I've also very much enjoyed reading about other's journeys so I'm hoping this might be interesting to others.
My primary room is about 26 feet front to back, 24 feet wide, vaulted ceiling peaking at about 12 feet, and with a large adobe chimney about 7.5 feet from the front wall. I'm placing speakers about 2+ feet out from the chimney, so about 11 feet from the front wall. Speakers are about 8 feet apart and 7 feet from their edges to the side walls. The pictures should help on the details - there is an open stairway to the basement and open doors in the front wall to the bedroom hall area, with a similar floor plan in the basement (but 8 foot ceilings) where I plan to set up a second system. I will never use the fireplace and would like to remove the chimney to open the space visually, but not sure if I will do that in the future. I don't want to add curtains over the large glass windows, but I might add some folding panels at the back wall and area rugs on the hardwood floor. The back wall angles out at about 5 degrees, so that might affect room reflections.
I've had Sonus Faber and Martin Logan speakers in the past, with tube amps and preamps, but for simplicity I'm going solid state and looking to explore Class D for energy efficiency. Current components are Pass INT-25 and Boulder 866 integrated; Playback Designs MPS-8 (Thanks Scott!) and a 20 year old Accustic Arts CDP. Speakers are SF Elect Amator III, and I will be adding Pure Audio Project Trio15 Coax-10 and YG Hailey 2.2 speakers and AGD Class D amps. If I keep all three speakers, I'll move the Electa Amators to a 20x13 foot bedroom and the PAP Trio15 to the basement. So I'm looking at setting up 3 different systems to experiment with different sounds in different rooms. I have a variety of budget Cardas, Harmonic Tech, AudioQuest and Nordost cables and interconnects and will demo some other cables. I'm at the end of the line on my rural power grid, but I think I'm getting good, stable voltage, reliable power (per my Ting power monitor).
I've been to RMAF in the past, and to local dealers recently to audition equipment, but never found those experiences very satisfying - too rushed, too many distractions, and poor room set ups, so I didn't feel like I could make useful evaluations in those settings, and I'd rather test systems in my home for several months. I know I will pay some cost for reselling components that don't work out but I think it is worth the risk. The only really good experience I've had at a dealer was when Mike and Neli from Audio Federation were in Boulder demoing equipment from their home.
My first priority now is to replace the old audio rack in the center of the speakers with something that does not affect imaging. I'm also wondering if the chimney is affecting imaging. Any comments are welcome, and I'll post some updates as I try out the new equipment. I had SF Amati Homage in the past, and I'm very happy with the EA III, but I'm hoping the YG and PAP speakers will provide more of the full range sound that I had with Amatis. I listen to a variety of music: alt-rock, folk, world, some jazz and classical, but strong low bass is not a priority, so I'm thinking I wont need to add a subwoofer to the YG or PAP. I could add much more detail about the tube amps etc that I used in the past, but this is already too long for an opening post.
