Probably moving to Europe, how do I change my system?
Some speakers arrived, so I pulled out the new amps and got cracking getting some cables put together.
The pre-amp‘s power supply had a yellow sticky note on it saying 110v.
I sort of didn’t believe it and plugged it in… and shu-nuf the light just blinked.
Then I got the bag out with the parts in it, and pulled the power supply’s cover off put in the jumper marked 230v and changed the fuse.
Wholla - it is now 230v !
Reactions: LarryK
It looks like we will be moving to Europe.
I can’t convert the voltage on my Gryphon Colosseum so I will be selling it.
I can convert the Pandora but I might sell it and buy the Diablo 333 to simplify.
My wife is adamant about pushing my speakers up against the wall in a new apartment so I think I will have to sell the Cantatas.
Which speakers should I get that will work against the wall? I suppose I’d like to stay with Gryphon.
Thanks,
Larry
The small Gryphon speakers work great against the wall. When I met Gryphon’s Rune Skov at a demo in Stockholm he had placed the speakers close to the front wall. Normally speakers (like YG) are placed much further out in this room.
Cool! Thanks for posting this picture. If we do wind up in France, and absolutely must put the speakers against a wall, I will look into getting these speakers. For this year, it looks like our move has been canceled due to circumstances beyond my control.
  • Wow
Reactions: Holmz
Is this a Pandora?
Reactions: Holmz
Good pun @LarryK -
A lot of the Eu electronics are multi voltage.
I found it all sounded fine with the low current stuff on a transformer, and maybe a transformer acts like a bit of a filter.
But it is also a pain having to use a transformer, and the smaller the room then the more painful it is.
... For this year, it looks like our move has been canceled due to circumstances beyond my control.
Is there anyway to think of ^that^ as a silver lining?
Good pun @LarryK -
It means I have a valid excuse for not enrolling in daily French classes.
Reactions: Laurusri and Holmz
Why not do it anyhow?
And the wine-n-cheese-crescents as well :D
One of the most intelligently designed moving coil loudspeakers is made by Gradient in Europe (Denmark). They are expressly designed to take the room out of the sound field, and have several models. I use the Gradient Helsinki's in my bedroom. It works great up agains the back wall. The first time I heard it, my jaw literally dropped on the floor (this is high praise from someone who has owned high end loudspeakers for 40+ years). It received very positive reviews from TAS (Robert Greene) and Stereophile (Art Dudley).
What most speaker designers forget is that the room coloration is the biggest problem in loudspeaker design. You have to tackle that in an intelligent way, and not simply throw more cones in a larger box, as most moving coil loudspeaker designers tend to do. Fortunately, in electrostatic designs, which are what I typically listen to in my listening rooms, there is no lateral radiation, so they tend to be less affected by sidewalls. What Jorma Saalmi of Gradient did was to figure out how to design a cone loudspeaker that simply doesn't "see" the room. It works really well if you position it against the back wall.
There is no closed box cabinet, and the 12" woofer is on an open baffle at right angles to the forward direction. The midrange is housed in its own enclosure that is designed to have no back radiation. The tweeter is horn loaded and both the midrange and tweeter are angled upwards to minimize floor bounce. When you hear a good classical recording made in a concert hall, your room just disappears. It's an eerie sensation. By minimizing the first reflections (floor, side wall, back wall etc.), Jorma achieved a minor miracle.
Some caveats: don't expect thumping boomy bass -- if you crave that, you can always add a big subwoofer. It does not flatter poorly recorded material, and there is no false warmth from the cabinet, like Harbeth and other BBC derived designs. It's relatively small and is intended to sound like a loudspeaker in an anechoic chamber. It's a reminder that in loudspeaker design, as in every other engineering field, there is no substitute for original thinking. As Peter Walker said many decades ago, you design loudspeakers for "documentary reproduction", meaning you are trying to capture what the microphones caught in an actual concert hall. Having just attended a live concert by the Philadelphia orchestra, where peaks exceeded 100 dB even though I was a hundred feet or more away from the musicians, there is no thumping bass. When the bass drum kicks in, it is fast and the transient comes and goes in an instant, without the typical box overhang. That's very hard to reproduce in a typical listening room.
This week, I'm attending three concerts by the Vienna Philharmonic at Berkeley, where I will get a more detailed reminder of what music sounds like in an actual concert hall. That's what Gradient Loudspeakers are designed for. They don't get horn level dynamics, but they can go pretty loud. I tend to listen at lower volumes at home, so it doesn't bother me.
Last piece of advice: I buy loudspeakers only from companies that have a long track record of producing innovative designs. Anyone can throw cones in a box. It takes genius to figure out how to make moving coil loudspeakers sound something like a concert hall. You have to pay attention to room induced coloration, and not just the loudspeaker volume levels.
Your description of the Gradient speakers is spot-on. I share your love of classical music and the Gradients excel in its reproduction. At my shop, I am pleased to represent them and have their newest model, the 1.4 on display.
