Or after Scotch, one eye open and one closedBegs the question…which stage is on the record. The one with eyes open or the one with eyes closed
I don't understand why you want to simplify it so much. Many people rip their CD to a drive to play the music via Roon, JRiver etc. It warrants investigation to understand what limitations might arise in the process.I just don't understand why you want to complicate the experiment with ripping from a CD to begin with, why not just take any audio file, make a copy of it, and compare?
CD Ripping aka reading an audio stream from a CD Player is a way more complicated process than just taking a file on a computer and making a copy of it. But sure, if you can get a perfect ripping process that results in a bit by bit identical file both times, then sure, we can use those files.
How does one distinguish digital distortion versus other analogue related distortions? What specifically are the clear, undeniable indicators or may it be a mentally induced bias towards analogue similar to other biases we all have? Some folks on this forum are clearly anti digital and 100% analogue biased. Best.I think this comes down to some folks being more sensitive to digital distortion (as yet unmeasurable) than others.
Now that is a heck of an answer. I was just reading through Xymox post on Cable Modems ( https://www.whatsbestforum.com/threads/cable-modems.30094/ ). He too talks about all the noise from digital equipment and how it propagates inside itself and to other equipment. I believe you are calling this a resonant frequency.As a retired engineer who worked in R&D for several major consumer electronics manufacturers and has designed and produced several tonearms + turntables as well as digital equipment i have a different perspective.
I see both systems as sonically dominated by resonances of different natures that leave a particular type of sonic signature
Analog is dominated by acoustic resonances where every material, shape, cartridge and alignment, mass and material to material junction has a unique resonant signature that imparts character. In my opinion only the lathe that cut the master would have the least contribution to the pressing and even then the pressing is a result of the lathe signature. My belief is that a technically “perfect” playback setup would be fairly lifeless. The tables people like have a synergistic composition of material resonances.
Digital is dominated by the resonant artifacts of the sampling frequency, clock errors, RF noise, power supply noise, etc.
These resonances tend to not be consonant with the music and the only way to deal with them is to eliminate or mitigate them as there is no way to treat them like the analog counterparts. Technology and manufacturing is eliminating most digital issues but for the most part we are stuck with the redbook Fs that will impart a signature even with apodizing filters to eliminate the harmonics of the Fs.
If we stop to think about it, even measured distortion is a harmonic resonance that is measured by harmonic order and magnitude.
Knowing these differences it’s best to accept that these are 2 vastly different approaches that will probably always be dominated by different resonant domains whose signature will differentiate the 2 approaches as the implementations mature and converge on perfection.
I think DHT4ME response says a lot. A digital distortion has nothing to do with the fundamental music distortions. Analog distortions are mostly related to the fundamental signal. Aside from say motor noise or noise in the power supply of the phono stage.How does one distinguish digital distortion versus other analogue related distortions? What specifically are the clear, undeniable indicators or may it be a mentally induced bias towards analogue similar to other biases we all have? Best.
What???I think DHT4ME response says a lot. A digital distortion has nothing to do with the fundamental music distortions. Analog distortions are mostly related to the fundamental signal. Aside from say motor noise or noise in the power supply of the phono stage.
One easy way to identify the signature of the 44k sample rate is to use a program like HQ Player with an apodizing algorithm that strips the fundamental Fs artifacts from the uprezz. It is a very nice tool for identifying the signature of upsample algorithms and if you have a DAC that is NOS it usually can accept sample rates up to the chips limit or the limit of the interface. To see the effect use a non even integer of the base Fs.How does one distinguish digital distortion versus other analogue related distortions? What specifically are the clear, undeniable indicators or may it be a mentally induced bias towards analogue similar to other biases we all have? Some folks on this forum are clearly anti digital and 100% analogue biased. Best.
If you are using a computer for streaming. PC or Laptop, some assumptions here.One easy way to identify the signature of the 44k sample rate is to use a program like HQ Player with an apodizing algorithm that strips the fundamental Fs artifacts from the uprezz. It is a very nice tool for identifying the signature of upsample algorithms and if you have a DAC that is NOS it usually can accept sample rates up to the chips limit or the limit of the interface. To see the effect use a non even integer of the base Fs.
HQP is a great learning tool if you take the time to listen to the effects of algo/dither combinations on the ringing/harmonic/artifact. The best sounding combos take considerable processing power and it becomes obvious that many compromises are made to get the simple standalone DAC box solution.
Many artifacts show up when the full scale output is reached or is approached. Technically the digital representation should never reach the 0 (max) point and always should have some headroom as its a hard limit even though the majority of representable info is in the loudest last level of data.
When you upsample redbook it is common to reduce the signal by a touch because the reconstruction filters can create a transient waveform that will calculate to a higher signal level when reconstructed and push toward or clip signal transients. Dac chips do the upsampling either internally or by an ASRC chip ( most Ladder dacs) just before the DAC chip and the math is fixed in the latter. I found that reducing the level a bit higher to -1.5 db to 2.5 db is needed and some tracks readily show the result.
Daphile is a free OS/player that has upsampling capacity and with the highest quality settings it will record that you have digitally clipped the transients and prompts you to reduce gain digitally in the upsample algo. I do not use Daphile any more however it was the first clue for me that correlated measurable problems with a particular sonic characteristic especially since my DAC is NOS.
Knowing that there was a preference for NOS DAC's among a segment of the audiophile community and knowing that the majority of DAC's upsampled internally it was an eye opener as the sonic character of upsampling without a gain reduction reminded me of a lot of digital quality issues I had encountered over the years. I now see why MFSL purposely reduced the gain on a lot of their releases.
Tracks that are recorded hot seem to be frequently harsh/digital artifact plagued. I can't think of many modest level recodging that have issues.
Tracks that I have found to be problematic to the above and yield better results from a gain reduction when upsampling are good tracks to identify the digital problems. Most Enya albums, There are a few Allison Krauss tracks, almost every rock CD that I had and on and on. I don't have a formal list however I should say that these are results from R2R ladder dacs. I understand that there is significant headroom in the Sabre dacs 26+6 bits so possibly that moves the bar significantly.
My post engineering profession is in digital imaging and its amazing how many things in digital audio have corresponding imaging situations.
Yes, a computer is needed to test these situations, however as a means to identify sonic attributes it is an easy to accomplish task. High level use is obviously an whole other topic.If you are using a computer for streaming. PC or Laptop, some assumptions here.
The clearest indicator of digital distortion is you want to turn the system off or skip to a good sounding album. Regarding the difference between analogue and digital distortion, one area that is different is digital distortion burns my ears whereas analogue distortion doesn't.How does one distinguish digital distortion versus other analogue related distortions? What specifically are the clear, undeniable indicators or may it be a mentally induced bias towards analogue similar to other biases we all have? Some folks on this forum are clearly anti digital and 100% analogue biased. Best.
I think these are very good questions.* I, myself, cannot describe a particular distortion of digital.How does one distinguish digital distortion versus other analogue related distortions? What specifically are the clear, undeniable indicators or may it be a mentally induced bias towards analogue similar to other biases we all have? Some folks on this forum are clearly anti digital and 100% analogue biased.
For me, the solution to a poorly recorded/mastered/processed album is to not listen to it.The clearest indicator of digital distortion is you want to turn the system off or skip to a good sounding album. Regarding the difference between analogue and digital distortion, one area that is different is digital distortion burns my ears whereas analogue distortion doesn't.
I prefer not to be around biased people what ever their biases are, or if they align with my preference.Hi Ron,
For me, there is very little (if any) difference between the words "biased" and "prefers".
Very little difference, if any between biased and favors. Just checked the definition of bias. "Prejudice in favor of...." IMO, there is no confusion.I think these are very good questions.* I, myself, cannot describe a particular distortion of digital.
He/she prefers analog simply because he/she genuinely prefers the sound of analog. he suggestion of bias here confuses rather than illuminates.
