Good morning WBF!​
No. The first reason is outlined in post#16, the second reason is with the network card "isolated" from the Extreme/Olympus by interface and floating on it's own dedicated battery supply it's just not necessary.
I see. I thought that was just about a mini bps.
Not a bad estimate! If you rank Extreme + IO at 200% I'd rank Olympus at ~300% and Olympus + IO at ~330%.
So the big question would be the price difference between „just“ the IO upgrade vs a Extreme to Olympus trade-in.
Hopefully the Olympus is price wise not in the stratosphere like other High-End offerings these days, that makes such a consideration even possible. Fingers crossed!
Well the future is now is indeed the mantra.
Pricing to come as well as trade back on existing Extreme....fabulous
A few questions for those interested in option 4
1. Availability -ETA
2. The question of transferring one's library from existing Extreme to Olympos --how does that happen
3. For Olympus is the Taiko USB board necessary with XDMI coming
4. Will XDMI be part of Olympus when Olympus is shipped
Reactions: PhoenixRising
Not too sure I understand your reply. Do we use Olympus to power router and switch? Or there is no need for that because network card is isolated and floating.
3. For Olympos is the Taiko USB board necessary with XDMI coming
4. Will XDMI be part of Olympos when Olympos is shipped
I did see that XDMI comes included with the Olympos so the big question is how to convert ones internal library to that on the Olympos
with the new XDMI, I gather that that makes the Taiko USB card obsolete...In the trade in of the Extreme what happens to that USB card? Is there some sort of credit given on it or does it become an expensive paper weight
Reactions: Ackcheng
1 - XDMI is an interface. I am not sure how that affects one's music library.
2 - The question is, does one's DAC require that interface to optimize it? I assume so but I am curious what Emile says.
I never said it affects ones library but I thought that XDMI obviates the need for USB. And yes I know it's an interface. There has still been no explanations to how each different externalDAC will pair with the new interface. I thought I read several months ago that the Horizon uses i2s and MSB uses their Pro usb interface
as for Library I have 16 TB to copy and IIRC the memory cards are not used any more
I never saiid it affects ones library but I thought that XDMI obviates the need for USB
Sorry. I misunderstood "I did see that XDMI comes included with the Olympos so the big question is how to convert ones internal library to that on the Olympos"
Thank you.
This looks very optimistic.
I am not ranking extreme + Io at 200 % as I had no chance to see it or hear it.
This is estimate based purely on your first introduction chapter.
it looks the biggest improvements are with adding Io to extreme .
But from what you say it is triple the improvement from pure extreme to pure olympus.
Not sure if Emile will find a moment to write his estimates and sady few works about his sonic impresions with new Olympus
Reactions: DW101
How the 2 are connected ? Extreme to Io and Olympus to Io ?
I use to have and use adnaco pciexpress to isolate usb card and network
with my server 7 years ago .
is that a simmilar concept ?
I used fiber to connect 2 chassiss Because they had separate supplys.
Very nice designs!
Does your baseline of 100% include extreme + Xdmi card digital out, or just today's extreme with the USB output card?
The IO architecture suggest that the xdmi card, without daughter card, would reside in the extreme and move data to the IO via the new xdmi output format and the function of the daughter board(s) would move to the IO where it would be battery powered.
Can we expect an announcement for the xdmi digital output card soon? That is actually what I had been expecting today. The Olympus was quite unexpected here.
How do u know the memory cards are not used?
