Good morning WBF!​
I believe that XDMI is only available for Olympus and I/O. I don't think that you can add I/O to the Extreme. Emile?
I believe adding an I/O to the extreme was the lowest cost option for getting xdmi, per the pricing options post.
Edit: what dminches said
Reactions: dminches
Yes you can, you can add Olympus I/O with XDMI to the Extreme (as Olympus I/O is battery powered). The Olympus server can have XDMI mounted internally (because it has internal battery supplies). XDMI is designed to run off battery power.
Is the new CPU also in the I/O?
Or is battery power the "needed" new hardware not in the extreme?
Bob I believe their are 2 Options For The Extreme: Option 1 Olympus I/0, Option 2 Olympus I/0 XDMI. With both one has to return USB and Network card...
Reactions: Rhapsody
I have to admit that reading all of the posts about XDMI as well as some texts with Emile, I am every day more and more on board ith XDMI and now have a strong desire to hear XDMI analogue It is my inference that Taiko has been somewhat quiet about this new interface with the hope that new users will find what Emile has said all along...that XDMI is so good that it will become a new industry standard. I really doubt that Emile would make such bold comments if in fact he wasn't so sure about what he is hearing. For me to go XDMI into the Horizon via AES/EBU is a huge step back from my typical listening paradigm , yet having said that I believe he just might be onto something via XDMI analogue with the internal DAC. I get strong gut feelings from Emile's comments that XDMI analogue is indeed something very different and might, just maybe, equal or surpass the sound heard from everyone's External DAC.
@lukasz Lampizator fikus....if you're reading this, I sure hope you're working on a fix that will reassure us Lampi users if in fact the internal DAC is as good as Emile has stated, and again, there is just no reason to doubt Emile when he makes these forecasts. I think he is smiling to himself as he awaits some first owners' feedback as to what they hear with their DAC vs the internal DAC . Can someone explain how those who order XDMI digital or XDMI analogue will be able to hear BOTH? My head can't figure this out
Reactions: ctydwn
I think he is smiling to himself as he awaits some first owners' feedback as to what they hear with their DAC vs the internal DAC. Can someone explain how those who order XDMI digital or XDMI analogue will be able to hear BOTH? My head can't figure this out
If I understood correctly, Olympus XDMI will also keep the USB output based on the current Extreme card, so comparing XDMI analog out vs. using any DAC via USB will be very easy.
At least initially, when you order an Olympus or Olympus I/O with XDMI you get an XDMI "mother" card *and* two XDMI daughter cards -- an XDMI analog output and an XDMI digital output daughter card.
In my case I won't be able to do an immediate A/B comparison between XDMI digital to my Vivaldi APEX DAC and XDMI analog direct output, it will take a couple of minutes to swap the daughter cards on the XDMI mother card. But I can live with that for the purposes of the comparison.
I don't have to painstakingly switch back and forth, back and forth teasing out subtle nuances between my Vivaldi DAC and the XDMI analog output. If it is that close, then the winner for me is the XDMI analog output and the Vivaldi goes down the road. What I actually expect is that just hearing which one gives me the most joy and emotional involvement with my music will determine what stays and what goes.
Steve Z
well it’s just too easy. I have to admit that I saw the photos of the two daughter boards but it didn’t register on me that both are supplied I thought it was one or the other.
I still think that’s Emile is playing it tight to the vest re XDMI analogue and is awaiting early adopters comments. Suffice it to say that should this be as good as we all expected then I suppose we can eventually see a new industry standard evolve and this could be the goose that laid the golden egg for Taiko I’ve learned to never bet against Emile . I’m beginning to understand the logic behind members now asking for a volume control which in essence has one box going from server to internal DAC direct to amplifiers is the wheel coming full circle? There was a time when Integrated components ruled the day until they became modular and now perhaps a return to integrated
Reactions: ctydwn and VPN
Emile, I'd like to better understand the advantage Option 4 offers vs. Option 3. I recall in this discussion Option 4 offers a 10-15% improvement in sound performance for the reasons explained. Beyond the performance improvement are there other reasons to add the Olympus O/I such as the physical capability to accommodate future I/O options or would those be accommodated in Option 3 as well?
My two cents.
XDMI is designed to improve two things:
1. From player to digital signal out.
2. From digital signal out to DAC getting I2S.
For player to digital signal out: this step will usually need to go through
a) Windows drivers
b) Some hardware for digital output, e.g. a USB PCIE card or a AES/EBU PCIE card
Both of these are very suboptimal at the moment, since in order to manage R&D cost and due to lack of deep enough understanding of all factors that affect sound in the process there are (at least) three limiting factors:
i) Usage of off the shelf driver components/code for the driver
ii) Usage of off the shelf hardware components and schemes for the cards
iii) Non optimal way the driver and hardware work together
This whole area of player to digital signal out seems to have been reimagined from the grounds up in XDMI and it seems to have found a way to transport this signal through QSFP and DAC cable with very close to no loss in SQ.
The signal is transferred from either Extreme or from Olympus to Olympus IO through QSFP DAC cable.
Olympus IO transmits either
a) Digital out through SPDIF or AES/EBU, and even though the digital “close to lossless SQ” signal received by O IO from Extreme or O needs to go through a conversion, it benefits from everything above and the conversion itself I would bet has also been to a high extent rebuilt to minimize SQ loss. In other words, the digital signal received by the DAC is way better than previously through USB.
or
b) Analogue out, and in this case the DAC module receives immediate I2S directly from the digital “close to lossless SQ” signal O IO received from Extreme or O. So even if the engineering surrounding the DAC module itself is somewhat compact, by getting rid of the conversion steps to AES and back to I2S and by powering it with the BPS and separately enclosing it in the O IO the gain might be so huge that it exceeds the engineering of almost any DAC.
Now, if a stand alone DAC could receive the “native” QSFP digital signal, you get all the benefits of the signal transmission and the DAC engineering, but without BPS to power the DAC (of course the QSFP module on the DAC could be externally powered by a BPS). So in that case it would be a matter of the gains in DAC engineering vs the loss of one more QSFP transfer and lack of BPS.
I’m not sure anyone has really heard this yet, but this would be my bet for best SQ. And once people hear the analogue out of XDMI, DAC manufacturers should be much more incentivized to include the “native” module.
From Emile's post #542 in this thread:
All I can say that IMHO XDMI analogue out is at the very minimum competitive to anything I've heard. If you like it better then your current DAC however is just not something I can accurately predict. I'm very interested in people's experiences with it which is the main reason to supply both analogue and digital output modules in addition to the introduction discount. (bolding and italics mine for emphasis)
This is coming from someone who has always struck me as being careful to manage expectations and does not engage in hyperbole. So, very significant as well as very promising. The proof will be in the listening of course.
Steve Z
There are plenty well designed AES/EBU cards available but they do not perform on the same level as XDMI. In fact they don’t even perform on the same level as our USB solution.
May it be possible that the XDMI - Taiko USB work better then XDMI - AES/EBU?
My two cents.
a) Windows drivers
or
As I am (trying) to understand, we have the following 4 scenarios to compare and choose from with regards to XDMI digital to analog conversion.
1. Olympus > via USB > DAC.
2. Xdmi digital > via AES > DAC
3. Xdmi digital to analog > direct to Pre amp
4. Xdmi digital > via QSFP > to XDMI board and BPS at DAC?
I seems like Option 4 could be implemented a number of different ways from relatively straight forward to complicated and expensive.
To me, Option 3 is beautiful in it’s simplicity. I would love to go this route.
Option 4 seems to be by far the most complex, ambitious and expensive proposition. Maybe, cost no object, it could be the best?
It will be interesting to see if dac manufactures and Taiko can come up with a practical solution for option 4.
Steve Z
That's the million dollar question I think we all want to know. Whether XDMI analogue out makes our Dacs redundant and the trade up price more palatable!
I will be sure to report what I hear when my Olympus arrives -- but that won't be until March 2024, barring any delays in production.
I'd love to be able make decisions without uncertainties or unknowns. However, my life just hasn't played out that way. Like many here I am relying on Emile's past track record which so far, has been 100%.
But howiebrou, I promise you'll be the first to know what I think!
Steve
Steve
Appreciate that! It is a big jump getting into the Olympus but that option seems to make more sense than adding a I/O XDMI to the Extreme given the generous trade in of the Extreme.
So Olympus or new Mercedes or kids' school fees.....decisions decisions.
