New! Octave MRE220SE ... I am in love!
nunobrazuna
20
77
120
53
I would like to announce to the community that I am in love again. And I was already convinced that those times of passion had already passed.
The big culprits are the new Ocatve MRE220SE amps and the HP700SE Pre.
Background
I've always been a passionate fan of valves, especially single-ended amplifiers (SET).
For years I had great SET amplifiers from Wavac, Viva, Aries Cerat and out of prejudice, I always avoided push pull or solid state amplifiers.
However, in 2021 I had the great opportunity to buy TIDAL Contriva G2 speakers at a great price and I thought it was time to try a solid state amplifier and put an end to the paranoia that comes with always having to maintain a valve amplifier.
After 2 or 3 experiences, I ended up purchasing the Gryphon Antileon Evo (class A), which went very well with the Tidal.
Although the sound was very good, and with some tube sound characteristics that I like, I felt like I had lost something and even some pleasure in listening to music (I know it's silly, but that's what I felt).
It was then that at the beginning of this year I decided that I had to go back to the valves, but I had a small problem. While Tidal aren't the most difficult speakers to amplify, SET amps were out of the question.
I was in a dilemma. Either I would also change speakers, or I would have to put prejudice aside and listen to Tidal with a push-pull valve amplifier.
In the distant past I had already heard some push-pull amplifiers, such as Audio Research and Jadis, with 6550/KT88 valves, but always with unsatisfactory results.
However, my distributor insisted on trying the new Octave MRE220SE amp / HP700SE preamp.
Not very convinced, I decided to try them at home.
The Sound
The Octave MRE220SE are push pull amplifiers, with KT150 power tubes with a total output of 220 W at 4 ohms. Enough for my speakers (Tidal recommends 150 W minimum).
My system also consists of the DAC Aqua Formula Rev2 and the Antipodes Oladra streamer.
First impressions were in a awe. I immediately noticed a more open and transparent sound than I was used to hearing in the last two and a half years.
The soundstage was holographic with great focus and precision. The voices more real and present in the room. The highs more natural and the bass with natural texture, but tight as I didn't expect from a tube amplifier.
In comparison, the Gryphon has a more big "wall of sound" presentation, but a little "muddy" in highs, and the soundstage a little flat.
Once I got used to this drastic change in sound presentation, I started listening with a more critical sense.
I have little to criticize, but at times, in some average recordings, the upper midrange can sound a little harsh and some female voices a little hissy.
Nothing to be worried about, as from my experience in the past, tube rolling would eliminate these small flaws.
And so it was. I replaced the installed russian drive tubes (12AU7) with NOS valves from Amperex and RCA, and the sound became even more natural and the harshness disappeared definitively.
Conclusion
So for the last few weeks I have been in heaven.
Listening to Yael Naim on her live album "Live Solo in Paris", I was literally transported to the Saint Eustache church in Paris where the concert was recorded! Simply magnificent!
John Coltrane or Miles Davis' saxophone has already materialized in front of me. Magic!
Kurt Wagner from Lambchop sang just for me several times. Impressive!
And other sublime experiences that the Octave have given me since they entered my room.
In conclusion, I can say without any doubt that the sound of my current system is the best I have ever heard, regardless of the price.
And for the price they cost, the Octave MRE220SE / HP700SE are a real bargain, as I'm almost certain that up to €50,000 there will be few amplifiers that can compete with this masterpiece.
Congratulations to Andreas Hofmann, the boss and chief designer of the Octave.
@nunobrazuna Since you have tried many top tier tube amps, could you please help compare the sound of Octave to Wavac and Viva? I'm looking to upgrade my tube amp as well :)
Hello,
I had the Viva Solista and the Wavac 805.
For me, the Wavac is superior to Viva and I have good memories of those times (at that time I switched from Viva to Wavac and compared the two side by side).
Viva sounds beautiful and holographic, but homogenize the sound a little, and all recordings have the same characteristics.
The Wacac is more neutral with better dynamics than the Viva (20w against 50w).
The Octave is my first push-pull and I honestly wasn't expecting this level of sound quality at all, as I've always been obsessed with SET amps.
The Octave MRE220SE can do almost everything the Wavac/Viva did in the treble and midrange, but with a much better bass, transparency and dynamics. And can play virtually with any speaker.
Another very important thing...the Octave is incredibly robust and seems to me to be a product capable of working flawlessly, only needing to change the tubes when they are at the end of their life.
Reactions: SCAudiophile
Hello,
The Octave MRE220SE can do almost everything the Wavac/Viva did in the midrange and transparency, but with much superior dynamics.
Thank you for your comparison. I’m also obsessed with SET amp. Guess I’ll have to give push-pull a try :)
Which Aries Cerat amp did you have?
Aries Cerat Concero 25 with Incito S preamp ... very good sound but at the time not the best with my Tidal speakers (only 25w is low for my speakers).
I really wonder how it would have sounded with the Conceros 65.
I bet that would have been awesome :eek:
Reactions: morricab
The SET path is treacherous , filled with roadblocks landmines and potholes :) , happy for you you found the right path . ;)
Try Convergent as well if you have the chance which is also a great option
  • Sad
Reactions: morricab
Background
The Sound
Conclusion
Congratulations on your new Octave preamp and amps!
I have Octave amplification myself:
Octave HP 700 preamp
Octave RE 320 stereo amp
(See my signature for the rest of my system.)
I am also very happy with my Octave combination. While I have heard several SETs and liked the sound, I have yet to discover the alleged magic of SETs. The purity of midrange is supposed to be their strength, but I have yet to hear better vocals, for example, than through the Octave on great recordings.
I did exchange the KT 150 tubes in the power amp for KT 120s which I prefer.
Reactions: Republicoftexas69
Hey Nunobrazuna, I just read your report on the Octave HP 700 SE and the MRE 220 SE monos. Can’t avoid the impression you like Octaves :).
Also, I think they have implemented a variable damping factor option in the new version of the monos to render the amps more flexible to handle different loads. This was reported as an issue here earlier, but appears now to be remedied.
So, I read your report with interest, as I came across the updated MREs by coincidence. The reason why I started to read up on the amps is that I stumbled into a dealership last weekend and heard the full dish with the pre, monos, and super black boxes. I do live in Germany, so I know the brand and have even been auditioning their smaller brethren maybe a decade ago.
I do have a small tube amp in a secondary system, but am otherwise not a tube aficionado as such. In my main system I do have an AudioNet Humboldt. But what I heard last weekend triggered my interest, it was really quite good. Even though the speakers in the demo were nothing special.
I will go back later this week with an audio mate and will give them another listen. Just to see whether the positive impression is repeated or if I hear something different this time. In case of a repeat good experience I might them at home as well.
Thanks for the write up, it’s always nice to compare notes.
Hello Kuoppis,
The Octaves are really special and versatile. I think you can go with any speakers. The amplifiers can extract all the qualities of that loudspeaker.
So, you tried them with the Tidals or you decided it wasn't enough and had already moved on?
I tried the Aries Cerat with the Tidal speakers... excellent with acoustic music or vocal jazz, but struggled with rock and symphonic music.
The Aries Concero 65 would probably be a better option.
Reactions: morricab
I also use Octave amplification - RE 320 + SBB and HP 700 SE - together with Marten Parker Trio speakers.
A very good combo!
I was considering upgrading to MRE 220, but the RE320 together with the SBB has more than enough juice to drive the Martens easily.
