Installed Dedicated AC Circuits - FINALLY - and the results...WOW!
J.R. Boisclair
250
385
150
I wish I hadn't taken so long to do this, but I eventually got around to asking @Kingrex (Rex Hungerford of https://www.kingrexelectric.com/) for help to guide me - and my electrician - through the installation of two dedicated AC circuits for my audio system. With the aid of some photographs of the inside of my electrical panel and main AC service drop (on the outside of the home), he had a panoply of changes and tweaks to the arrangement of the nest of wires and breakers within. He also defined what type of wire to draw to the drop point in the room, how to properly arrange the two runs relative to each other, etc., etc. To the credit of my electrician, he went along with what was - for him - quite unusual requests made by Rex Hungerford.
I have had all components plugged into an Audioquest Niagara 7000 and the Niagara fed off of one basic house circuit. For first impressions, I decided to simply evaluate the entire system plugged into one of the new circuits feeding the Niagara so the change would be a simple one - a single new dedicated AC line with the second sitting on the sidelines for the time being. I was *astonished* at the improvement in resolution and inner detail. I expected transients to have better impact (they did). I expected dynamics to improve (they did). What I did not expect was how much extra resolution and sense of musical "ease" I would gain. The noise floor dropped considerably presenting a wonderfully black background to the music. The soundstage grew in width and depth. It simply sounded more like I was listening to music and not listening to a stereo.
I was also quite surprised that I had to decrease the gain to my bass amplification by almost 2dB to get it as well balanced as it had been before the electrical change. I suppose the bass amps were previously just a little bit starved and now they had the instantaneous current they demanded WHEN they demanded it.
I have not yet moved the amplification to the second circuit as I am simply enjoying these improvements too much to care right now. I like the idea that I have more to look forward to!
Thank you so much to Rex! I can certainly say I have benefited from my consultation with him.
What wire did you upgrade to?
It wasn't the wire itself that was special (it was basic 10ga romex). I think the magic was in how Rex made sure the H, N, G were all landed at the proper location, that there weren't any ground loops inside the panel, the location of the breaker, removal of some things the last electrician left in there, strategic application of Deoxit, measurements of impedance to H, N, G and quite a bit more details I don't currently recall. Every home's panel is laid out a bit differently so they each get a special work-over from Rex.
Rex did the design for my house last year, and like you I had a great local electrician who executed exactly to Rex’s plan. Wire for the drops was provided by Rex. I had #2 AWG copper run from a dedicated breaker in my main (outside) service panel to a new dedicated subpanel just for the room’s six dedicated circuits. Result? Outstanding! One of the best expenditures ever made in my years in the hobby. I can recommend Rex for a top job in this end of the hobby!
When we built our house we had dedicated circuits and lines going into my listening den. We did not know of Rex 21 years ago. Box is separate from the main trunk. Did the same for our pool equipment.
Thanks JR and Tony. It's always a pleasure to help.
Reactions: J.R. Boisclair
Congratulations, J.R.! That's a wonderful report!
Must be me--I too have my system on a dedicated line----I hear not a difference...
I'm under the impression that a quality line conditioner is enough to do the trick......
I just don't hear the dedicated line making a difference..the only up side is that it was not expensive
of a week----few hundred as opposed to thousands
That is unexpected. Did you have @Kingrex involved in your planning?
EE degrees do not automatically relate to how things affect sound. Please do not let that be a benchmark for the ultimate in sound.
Tom
Tom
Not a benchmark but in conjunction with his incredibly strong knowledge and experience
With in the hi end audio industry—-
It really does depend on how much your electrical system has been mangled over the years due to changes in the property, fixes due to changes and regulations, et cetera. Mine was mangled by two extensions to the house, two new external buildings and a car charging point. Before doing anything, I had two electrical surveys carried out, one of the internal wiring that was my responsibility and the other of what you call the AC service drop, i.e. the cable coming in from the street that is the property and responsibility of the electricity network.
I remember Michael Fremer did a video of getting his house survey spending about $14,000 upgrading the AC service drop alone. This made an enormous difference to his internal power, and he changed from using AC regenerated power to a fairly standard mains conditioner.
In my case, both surveys were pretty disastrous. When the power network inspected my connection, they said it was so bad they refused to reconnect it and left me without power. So we had a new connection installed from a 3-phase supply, every single part of the existing system was removed and the entire house rewired.
Besides the obvious safety elements, I think the complete absence of any grounding issues is the main benefit. The grounding arrangements obviously depend on the type of electrical supply into the property, the type of installation and whether it is carried out to the required specifications.
I photographed the whole thing, but it is very specific to a UK installation using a 3-phase supply.
