Hello. I am a skeptic too. But as electrical PE I now a little. Some of the power cords do help help eliminate noise on the power coming out of the wall. But I am a believer of power conditioning. I use ps audio regenerators and I get results I can hear and see.
Al
They are the famous Kraken costing $8400 - no need to PM. I hope we do not get insulted just because we are debating them.
http://www.monoandstereo.com/2014/02/stage-iii-new-kraken-power-cord.html
http://www.stage3concepts.com/PRODUCTS_Kraken_page.htm
What filters are in those power cords? How do they eliminate noise? I think it's a pretty simple answer, if we're talking about cable and plugs; they don't. A well-sheilded cable may prevent the introduction of noise, but it has no capacity to reduce it. And I don't have to hear this any more than I have to get on the space shuttle to know the earth isn't flat. Born a few years later, PT Barnum would have been a high-end tweak manufacturer.
Tim
It does, however, make sense IMO that one should not even be commenting about an audio products sound (or lack thereof) when said person has never heard it to begin with. I'm not trying to pester you, just understand why you (and perhaps others) would comment in such a strong way (calling something snake oil) on something they may not have even heard.
That's all that needs to be said. The rest could be considered hot air.You're right. I haven't heard it.
Tom
So Caelin Gabriel's a fraud too Tim?
Hello, Tim. I find it interesting to see you comment on something that I suspect you haven't ever heard. That being a $200.00 PC or an $8K PC. Now, if I am correct in this assumption then you are claiming snake oil in a hobby in which all of the pleasure derives from listening on a product(s) that you have never heard. If I am incorrect in this assumption, please forgive me.
Tom
How the heck can a super power strip and power cord make my soundstage 20% wider. Why does my system have way more inner detail... it's a power strip for gods sake. The HB Cable Design Marble and the Stage III cable Kraken power cord have shaken my belief system. The system sounds as if I threw the 5.1 switch. And get this, I've only hooked the preamp to them. Is $20,000 single malt this good? Am I nuts?
I was (very) hesitant to review these products and I thought before I pass them to a team member for formal review I'd give them a try.
I shot the video of the HB in October and I thought, while it's a cool product for those who believe in this stuff... and I'm sure it will make a difference (like sideways), I never imagined it would elevate the system's speed and bass, and warmth, there's just more there. How can this be?
Correct. Hotter for passing through the last 2 feet of marble duct work. Nothing to actually raise the temperature required, just marble...the edge is beveled...inside? individual runs for each outlet to reduce noise, no noise fliters required...magic!
Don't know him. Myles you do understand that those three links you provided me are all abou noise filtering? Right? I skimmed. Are they claiming that if it is elegant, heavy and expensive enough, wire and plugs alone -- power cables -- are capable of filtering noise? If not, we're not talking about the same thing. If so, yes, it's BS.
Tim
Caelin Gabriel = Shunyata. You must have read his many, many contributions to WBF. If not Steve, Marty, and many others talking about his products. So basically to sum it up, you don't need to read his material nor look at measurements he's provided to draw a conclusion?
The ?TRON ANACONDA is our reference power cord and represents the current state of the art in power cord design. The ?TRON ANACONDA power cords are currently being used in the world's most respected recording studios and in the finest audiophile systems.
Installing a single ?TRON ANACONDA on a key component such as an amplifier, HYDRA or critical source component will deliver a dramatic, component level sonic improvement to the system.
This is a direct result of our DTCD research into the effects of instantaneous current delivery.
Not looking to argue. , but do you use any type of power conditioning ?
Al
I rarely open cable threads. I should have stuck with that. (...)
Tim
Tim,
Wise words. We have had very interesting and informing threads on power cables in WBF, with the direct contribution of manufacturers we respect such as Gary Koh, Caelin Gabriel and others, that you ignored in due time. Now you openly injure and despise them, their products and the owners. Do you want to tell us what is the purpose of your posts?
Archimago recently tested a set of Tesla cables. Only 1/4 the price of the ones under discussion here... such a bargain.
http://archimago.blogspot.co.nz/2014/02/measurements-power-cable-redux.html
Check out the "Active Shielding", powered by generic wall warts... no doubt injecting their own power supply hash into the power cables.
Tim,
