Very interest perspective and not boring at all Jack! I think one reason there are so many manufacturers is that a) it is relatively easy to get into this business and b) so many wealthy individuals confuse a hobby with a business and decide to go and manufacture such gear.
On (a), the availability of computer modeling and ready outfits in far east and elsewhere to build anything under your brand, has really changed the dynamics here. What used to require gray hair, lots of skill in manufacturing, and familiarity with a soldering iron, has yielded way to quickly packaging things up from ready parts and getting them to market. Nowhere this is more true of speakers where it is more about woodworking skills than any other trade. So we have a hundred different companies making high-end speakers.
On (b), I am guilty of that to some extent myself having started my own A/V business. You get frustrated as a customer and decide that you can do better by having products produced to your spec. And that since you are convinced you know more than other audiophiles
, you will be wildly successful. Alas, I heard a great line in woodworking magazine about getting into furniture making: "the worst thing you can do to ruin a great hobby is to turn it into a terrible business." It is fun to be an audio hobbyist but running a manufacturing line? Not so. And skill set in one business doesn't necessarily translate into another.
So I am not sure there is sound economics behind so many brands. A lot of money is lost on behalf of the wealthy investors in this business.
Finally, there is a component's performance, which is mostly subjective. When I hear - and I do - just subtle differences between cables, high priced ones have virtually no value in my book. When I audition the ML Summit X next to the Magico Q5 and I like some aspects of the X better than the Q5 - while everything else can't justify the price difference to me - then the high priced component doesn't offer much value either. When I calculate $3K in parts alone in a $10K amplifier and it performs well, then that offers very high value and the dealer isn't getting much for it.
Now seriously, aside from looks, "scale" comes at a high price. That 95% about large (10-12" ?) actives plus subs may be true of some aspects of reproduction but scale is not one of them. 50% vs a bonafide big rig would be more like it.
Comparing a small 3 piece active system with a system which moves a lot more air is like comparing grapes and watermelons. I like watermelons.
I don't want to throw you, Jack, but I am on Tim's side here. Physical size is only necessary for the woofer, but if you are prepared to throw lots of watts at it, even a miniscule box will do the job ...I really don't get this argument. I see that we're talking about is form factor. I don't really see what it has to do with scale.
I'm really not sure I get this argument at all. Let's just use an example, and please, let's not get into subjective opinions of the particulars, there is always another example, another sound, I'm just asking about reproducing scale and trying to get to what is meant when people bring this aspect of reproduction up.
Let's start with an Adam S3X-V:
10" woofer, 4" midrange, folded ribbon tweeter. Separate amps for each driver, which is a more efficient method that typically does not require as much power to do the job, but still, totaling 250w RMS, 32 - 50khz, 114db long term output.
Adam Sub12 (Let's take 2, I'll still be way under a comparable high-end system):
12" driver, 200 watts RMS, 22 - 150 Hz, 115db.
So I now have a 4-way system with 450 watts rms, capable of delivering 115db into a room from the lower threshold of human audibility to way above it. Where do I need more scale than this? More importantly, let's forget it is a "monitor" and a "sub" for a moment. Let's imagine it is a big floor stander in a single shiny cabinet powered by a 450 watt monoblock with enough current to push through the three crossovers to the four drivers so effectively that it is as if that amp and those speakers were made for each other (a very expensive proposition). Other than the lower distortion and increased headroom resulting from the active crossovers, and the higher flexibility resulting from my ability to separately adjust and place the woofers (not to mention tweak the eq of the monitors themselves for the room), what is the difference between this system and a big, four-way, floor-standing rig? All I see are advantages, but I could be missing something.
Tim
The recording engineers will use the nearfields to track, and to mix, use predominantly the nearfields and switch to the large soffit mounted beasts periodically.
Mmmm, a ported sub with only 200W wouldn't be my choice, but no matter. There are a number of very competent subs in this price range.Adam Sub12 (Let's take 2, I'll still be way under a comparable high-end system):
Stating what you already know, recording studio control rooms are fitted with more than one set of monitors for many reasons Tim. Yes one of the reasons is engineer familiarity and preference but also because they have different uses. The recording engineers will use the nearfields to track, and to mix, use predominantly the nearfields and switch to the large soffit mounted beasts periodically. Those big 'uns are meant for the producer/client primarily so Mr. Mix has gotta see if what he's doing satisfies. Now we draw the connection to mastering engineers and why they go with large monitors. He and the producers need to tools to evaluate from the end users perspective not the recording or mixing engineers.
I'm just saying that even the truly big no holds barred active monitors JBL, Tannoy, Genelec, ATC, PMC, Dynaudio Acoustics, that come closest to the scale of say an X-2, VR-11, Arrakis, Genesis 1 cost a lot and when you factor in how much it costs to build up around them to support their weight, feed them clean power, control their resonances you might be surprised to see the tab.
Grapes and Watermelons Tim, even within the pro and active realm.
