Hi All, my first post here. I recently had my horns installed in my dedicated listening room and the system is now oriented 180 degrees from my previous setup. The horn builder took some measurements and strongly recommended installing absorption covering 100 hz - 2000 khz. The puppy barking test disclosed significant slap echo and midrange bounce.
For context, the horn system is comprised of a mid-bass horn, mid-range horn and supertweeter covering 90 hz- 20 khz. For bass, I am using a Crown dsp amp driving two large sealed cabinets with a 15" pro driver in each.
How would you go about accomplishing this? I am open to all suggestions. Thanks.
