Acrolink Mexcel Series
Someone has or tried these cables?
Hi Gian 60
I have Mexcel PC: 9500, 7500 and 7300 and IC: 6300, 2090 Speciale and D5000.
As you can see I am a big fan of Acrolink/ Esoteric 7 N cables.
Very good build quality, very good connectors, older series were a bit more transparent but lean compared to the new one which is more saturated and warmer.
9500 and 2090 are new ones, others from previous series. Details in" about me".
I hope it helps,
Mariusz
Yes, I listened before 50 hours and the sound is ultra smooth (super soft), pure, crystal clear and all things are in control even in complex music.
Turn the volume up and there is no distortion/forwardness.
I will write a review after break-in.
I use the bnc cable between my esoteric cd player and clock, highly recommended but stiff!
Haven’t tried any of their power, signal or speaker cables but assume they will be of similar quality.
Hi Gian 60
I hope it helps,
Mariusz
Hi Marlso,
Old thread resurrection. I'm considering an Acrolink 7500 power cord for my music streamer/server as I recently started using an Acrolink 6300 aes cable.
How do you feel the 7500 would work on a digital component? Definitely trying to avoid any softness or rounding etc.
The 7500 and 9500 series are warmer and less technical sounding compared to 7100/9100 series and to the lesser extent - to 7300/9300.
But still very neutral and smooth imho.
BTW I use 7500 to my Aurender W20 despite the fact that the power cord should not influence the SQ of battery powered gear .
Theory is good, practice is better;)
Reactions: Gryffles
Thanks for your response. Guess I’ll have to give it a try on my Antipodes K22.
I was using a Sablon Prince for a while but it was a bit warm overall.
Agreed, practice always answers the question
Acrolink S20000 is wonderful speaker cable
Rich, clear, Pure, transparent , dynamic
The most accurate cable at high spl in complex music
