My current status of lessons learned on AF3P:
- As AF3P has no integrated "suspension" system, the turntable is sensitive to placement.
(more than my former Micro Seiki SX 8000)
If you are not happy with performance, you might customize your base to the needs of AF3P.
- Different belts sound different, material and length of belt can easily heard. Tension is important too
I prefer the TechDAS recommendation: original belt with low tension
- Platter weights make a difference. if you like resolution and a more lean precise , deep base type of character, the gun metal Micro Seiki ST-10 or similar will work, more smooth with a darker character the Harmonix TU 812 will be the alternative. I like sweet and open vocals, so I use now the graphite Audio Tekne weight.
- smart Motorbase tuning: Place a small Artesania Damper on top of the Motor, diameter exactly fits.
Result is (little) more details without a change of tonal balance. As the Artesania Damper is "cheap", I like this
(will not work with 4 tone arms)
- Even if TechDAS are not offering Gun Metal ToneArmbases, they can make a difference, depending on the Tonearm. All original Micro Seiki Gun Metal Tonearmbases do fit, so depending on your tonearm, you should try. Principle logic is, that a heavy tonearm with high effective mass will benefit if fitted to a heavy tonearm base.
- Some tonearms to have the possibility to be fitted with a heavy nut underneath the tonearm base. This will work fine with AF3P (like SAEC, Ikeda, Fidelity Research)
more to come, still learning ...
In principle it can be said, that AF3P is much more "neutral" than AF3 or AFV. Both have in comparison a bass performance driven "jump factor" which makes fun in the beginning. In direkt comparison many friends do prefer AF3 or AFV immediately, but after a while, they realize, that AF3P is more "real".
So I am very much interested into your comparison with Vyger.
