All that is wrong with "HiFi"
This is a subject that has driven me crazy, especially since the obsessive drive for more "detail" has risen to insane proportions. But the departure from "musically correct" reproduction didn't begin there.
No. It actually began with the use of high feedback in the pursuit of vanishingly low harmonic distortion. This inturn led to the focus of designing solely by numbers as a dominating criteria instead of listening to what truly sounds good, and what doesn't. This has proven to be a mistake time and time again, but few have seemed to learn from it.
What I hear when I listen to the majority of modern hifi components and systems is a bright, hard and fatiguing presentation, often bordering on severe stridency while being harmonically distorted and/or threadbare, and noticeably lacking in musically engaging qualities. What you end up with is an over-hyped sonic microscope that is overly detailed and brutally revealing of everything that is wrong with the recording.
The problem compounding this is that nearly all of the so-called hifi components that I have heard over the last 40 years clearly displays one or more of the above traits to the level of distraction, especially since the majority of them often possess distorted and/or unrefined high frequencies. You may not be able to hear it as well as I do, but I am really sensitive to it.
To sum up this rant, I would like to say that I am looking to form a conglomerate of audio-oriented manufacturing associates with the goal of producing more musically correct components at reasonable prices.speaker-wall.jpg
Perhaps there and with loudspeakers lacking sensitivity and having lower-than-4-Ohm impedance dips.
The audio market will respond with what people want to buy. I don't know if there is a 'problem' with 'HiFi' as much as a problem with audiophiles not knowing what they want and driving the market on that basis.
Not knowing what you want is as much an issue as lacking a reference to guide you. Do you carry a steady notion in your head of the sound you seek, or do you have a reference against which you can compare what is before you?
It can take a while (years) to learn or discover one's preferences that will stand up over time. Do you have an idea of what you want and take time trying to find it? Or, do you discover what you want by going through different systems and components until you hit on it? I suspect the latter is the case for many. If you allow others to tell you what you want (dealers, media) you may find yourself bouncing around from gear to gear.
The most important question for every audiophile is “what exactly I need?” .
I think it takes minimum 5 years to find the right answer.
Finding the answer is not easy and In this way Magazines and industry are not helpful.
There are many audiophiles who (even after 30 years) change their expensive equipments every 6 month and claim the new equipment is better.
I agree Tim, it does usually take years to get to a point that you can put together a satisfying system ( usually for a lot less money than spent getting to that point). Why is that?
Why is it that whenever someone here tries to share an insight learned the hard way on this (and nearly every other website or magazine about our hobby that I have ever read) someone, who probably unwisely invested in the error the insight was given to prevent themselves, argues vociferously against it. Although it might make he who spent unwisely feel less stupid in reality all it does is confuse those looking for answers and leads to their also making expenditures that might not be wise (see number 49 above).
The OP asked if the search for “detail” (with or without negative feedback) has made music reproduction equipment, “less musical”? To me, he is asking if vintage equipment has really been improved with all the developments in this hobby of late.
Yes, one could assume he is talking about any piece of equipment used in this hobby, and there is a lot of devices for sale today that I personally doubt value in, but I think rather than arguing whether or not diamonds on the surface of a speaker cone improve the sound so much that the cost is worth it, that he is instead asking us to stop for a moment and consider whether or not we agree with the direction the hobby has taken, and why.
Reactions: tima and PeterA
Even worse, listen to old Western Electric speakers with modern SET (or Silbatone hybrids) and you will think speakers have done nothing in 90+ years.
Hmm.. I can think of two fundamental advances since the WE era, addressing the problem of low distortion: Peter Walker’s Quad 57 and 63s, Paul Klipsch’s folded horn. The 63 was phase linear but not capable of high volumes, although perfectly fine in small to medium sized rooms. The Klipschorn is not phase linear and its response is a bit ragged by modern standards, but it offered very low distortion and high decibels from tiny tube amplifiers. 99.99% of modern audiophile speakers are just cones in a fancy box. Unfortunately the high end audio world has lost its original geniuses like Walker and Klipsch, and now we have largely marketing types but no genuine new science. So, we continue to get boxes with cones. Nothing new here.
Reactions: PeterA
Many years ago, I discovered that a group of men in Japan were turning this old technology into mind blowing systems that would make one wonder why we ever stayed from it.
I have heard English systems from the '50's that sound heavenly as well.
Reactions: Republicoftexas69
I can write a book on the sonic issues that too much feedback can introduce. Suffice it to say that it is best to only use as much as is actually needed.
The proven method to avoid negative feedback is a single-ended circuit -- which you mentioned above. These are low-powered and expensive to manufacture (mostly hand-made) so, unfortunately, hardly mainstream products anymore.
Well, starting next year I am going to be experimenting with design idea's that may lead to viable products, all well under $1K US.
Cartridges, LAN filters and tonearm designs will be my initial targets.
Design ideas: could you toy with the idea of a solid-state no negative feedback circuit, maybe transformer supported? Or, place feedback very high, well beyond the audible range?
Or, am I dreaming :)
Current sourced feedback does a lot less damage to the audible range.
Designers such as those at Accuphase as well as Nelson Pass have shown us ways to minimise its effects on a circuit.
I have come up with many ideas myself over the years, but have not tested them in working circuits.
The amp I use has no feedback mechanism - not really tube or solid-state (though a resistor is) - works great with vintage loudspeakers as well - no need for SETs :)
There may be other products out there that are not well known and offer interesting solutions.
Simply step back into the past, buy a Sansui tube or solid state amp, have it reconditioned and add a Altec/JBL studio monitor and simply enjoy music emotionally with all its strengths and weaknesses.
A few months ago I listen to a system like this and I have to be honest and say that to this day there has been no progress, no matter how much money you spend.
That's a harsh judgement on modern hi-fi gear, but unfortunately that's my opinion. I only buy old, good devices that are renewed and I enjoy the great sound.
Exsample
I was about to start a new thread on a very similar subject, but DasguteOhr’s post seemed totally in line with my recent thinking and I felt compelled to respond here with the question, “have we really advanced the hi-fi art that far over the past 60 years?”. I draw your attention to the live vs recorded events that Acoustic Research conducted back then. By all accounts it was very successful, causing many people to remark how fooled they were believing that the Fine Arts string quartet (recorded anechoically) was still playing when the live music transitioned to AR-3 loudspeakers driven by Dynaco electronics and Ampex tape machine. Granted, this kind of demo could never be pulled off successfully with a larger ensemble, but the fact remains that the reproduction equipment of the day was accurate enough to successfully execute the deception. Geez, I wondered what gauge lamp cord they used to connect the amps to the speakers.
It would be very interesting to have a comment from any member here (probably well into their geezerhood) who was present at one of these AR demos.
Reactions: tima and DasguteOhr
Listen. As much as we may crave the ability to recreate live unamplified events in our listening spaces, only a handful of recordings are good enough to even begin to realise such a feat.
Instead, I argue that we should concentrate on reproducing musically correct sound that will inturn render a very palpable presentation with a wide variety of recordings.
The interesting thing is that I experienced something similar a few years ago. The Detmold University of Music in Germany had an "open day".
You could listen to a performance by a small symphony orchestra in the concert hall; it was being recorded.
Then came the extraordinary thing: you could listen to the recording in the control room. The control room uses a wave field synthesis loudspeaker system with over 100 loudspeakers that also generate virtual sound sources.
I sat on the chair this loudspeaker system created a perfect 1:1 illusion, just like in the concert hall, even though there were several hundred meters of digital and LAN cables in between. I have never heard such good music from a recording in my life.
I can recommend that everyone listen to it; it's an experience. That's what I call progress. Oh, I forgot, a similar loudspeaker system is also installed in the large concert hall.
With a program they can change the reverberation times in the concert hall. For example, simulate a large church or other concert halls.
Sound and its effect on people are researched there. Musicians and sound engineers (recording) are trained. It is very interesting for anyone who likes to listen to music, I promise.
PYE PF91 pair audio amplifiers 12 Watts 0.1% distortion KT66 ECC33 ECC35 GZ32 Circa 1955 , as you opine , they sound rather heavenly with well matched transducers .​
I agree, when I reentered the audio world in 2016, I was surprised how little things had changed except the prices.
Reactions: CorDn
Lynn Olson wrote about it in a Tiny History of High Fidelity. I was lucky enough to hear some of these systems in the eighties.
Sorry, I had SOTA AR-LSTs from 1981 to 1988. AR made some great stuff, but nobody would ever confuse it with live.
Interesting demonstration, but not very practical for home use! Similar systems have been constructed by many folks. I recall an article in The NY Times several decades ago when a retired architect built a custom house in Connecticut using a similar wave field concept, where music would emerge from many small loudspeakers embedded in the ceiling arranged in a particular way that simulated an actual concert hall. I think the issue with a lot of these simulations is that you are superimposing two acoustics: the original venue ambience and that imposed by your listening room at home. It's the same issue with omnidirectional systems that have been developed by many manufacturers over the years (Bose 901, MBL, et al.). The basic principle is that you avoid beaming the sound from a point source at the listener in the standard two-channel mode, and instead beam it over a wide area that contains a large percentage of reverberant sound. Amar Gopal Bose was an MIT professor who got interested in the science of hifi in the early 1960s, and was shocked to see that normal loudspeakers sounded nothing like what he heard in the concert hall where the Boston Symphony performed. He did some measurements and found that at the listener, a large proportion of the sound was reverberant from the countless number of reflections that happen in the hall. So, the Bose 901 tried to mimic that by arranging to have most of the drivers point at the back wall, and bounce the sound off, and only one driver point at the listener in the front. It's sort of works, except when you measure it by conventional means, the frequency response is pretty awful. Of course, the inserted equalizer is even worse made of cheap parts.
Peter Walker who designed the Quad electrostatics dismissed all such attempts at mimicking the reverberant sound field, arguing in a classic article in Hi Fi News that the Queen sits in a box at the Royal Albert Hall, and largely does not hear much reverberant sound. He also said if you covered the back of an audience member with a sound absorbing material, he doubted there would be much sonic difference. In general, he did not believe in multichannel sound reproduction, viewing it as a gimmick. At the end, despite the valiant attempts by Sony and Philips to market multichannel DSD, it seemed to never get much attention in the market. I think the problem is that you end up superimposing two acoustics, and it doesn't really work. It''s also far more difficult to get the multichannel system to work with various room correction procedures (e.g., Lyngdorf's RoomPerfect, Dolby processing etc.).
Reactions: Rensselaer
Nearly everything I have in my 2 systems were purchased unheard, thats including all the cabling and stuff that were sold (EMM LABS TX2/DA2V2/TSDX/DAC2XV2).
The exception are:
TA-E1 - free
TA-N1 - free
SS-M9ED - 1st pair free, 2nd/3rd pair purchased from France and Japan.
And nobody, not even the maker, had an inkling how the Modi and Thor with the custom Delrin platter and Delrin weight were gonna sound like.
