Why does the Tp-1000 have two inputs and the associated input level controls if it’s playback only?
The ATR can handle 14" if the reel motors are mounted in the appropriate position. Otherwise, the limit is 10.5", but all ATRs can be converted without further modification and all have swappable deck plate inserts to support both motor-mount locations.A80 does and 820 does even 14s....I think ATR102 might too
you misread.....A80 does 12,5 maxThe ATR can handle 14" if the reel motors are mounted in the appropriate position. Otherwise, the limit is 10.5", but all ATRs can be converted without further modification and all have swappable deck plate inserts to support both motor-mount locations.
The A80RC does 14"? I thought it was limited to 12.5".
Congratulations! I saw one at the Tampa show and was impressed.My Analog Audio Design TP-1000 tape deck has been delivered.
The grey and black finish is quite pleasing. The touch screen is very intuitive and allows accessing numerous settings. I acquired the optional remote control. There is also an ethernet port for downloading the software update and allowing remote diagnostic.
This is currently a repro only machine but it can be retrofitted into a record machine once Christophe Martinez has finalised the record version.
The transport is very smooth and ultra quiet. It can play reels up to 12 inch.
The current setup is temporary as I am still waiting a professional 19" trolley as well as the mounting kit from Analog Audio Design which will allow to install the tape deck into the trolley.
I still need to compare it against the Studer A80 RC MKII with modified repro electronics and the Nagra IVS/QGB combo but the first listening sessions are very convincing.
