+1I could not ask or dream for anything more on my preamp. It's one of those once you have it...you're done.
not curious about the K-15
I believe the Atma-shere MP-1 can drive low input impedance amps. Only heard it in a show setting though.
Caesar,
What amplifier is this you speak of?
If it did this for you, what preamp were you using that made this happen? Additionally, was it an SS or Tube pre?
Last question: What speakers of yours did you attach to this "game over excellent" amplifier?
I think these questions would add a little insight, at least for me.
Thanks for your reply in advance.
Dre
except for the 'tube rush' or high output impedance and microphonics...I get a perverse sense of pleasure reading about others toils with expensive NOS small signal tubes going bad in 6-mos. yep, haven't had to change my transitors in 20-yrs and and my preamp is still going strong
I usually have more second thoughts about replacing a SS preamp for a tubed one. but when its the other way around I usually cant get rid of the tube piece fast enough, mostly on the heels of a recent spat of noisy tube replacements (expensive) or some new hum or buzz I cant get rid of.
not curious about the K-15![]()
Honestly not right now...i think i could better my sources and amps first. I realy keep hoping for a matching phono stage...the k10 is that good to me. Of course i havent heard a k15...
Never had any of these issues with my two BAT preamps.
I have an Atma-Sphere MP-1 Mk. 3.2, but haven't listened to it, yet![]()
the audio angels are looking after you Sam:b I'd love to try the MP-1 one of these days...im always up for trying something different. my favorite tubed preamp to date was the Joule Electra...the most hyped piece I disliked--okay, the noisiest--was the Hovland.
What power amps have you been using until now? I run my MBL 101e's with Krell because I had the amp when I bought the speakers, and it works well. I have been itching to try better amps in my setup!
If you are talking state of the art they both will be quite good. My opinion of course but IME, the top end tube preamps will be smoother and more dimensional.
Thanks Bruce!
The MBL preamps I have seen are very well-built. I was unable to listen to the one I to which I was exposed- it was too bright for my taste. I am curious- what was the change in the system configuration that led to this?
Puroagave and Flez007, what exactly have been the noise probs w/your Hovland preamps? I've been running my HP200 w/50's Telefunken tubes, since 2006, and if it's been noisy, I haven't noticed it. Are your noise probs faults, or inherent in the design? Ironically I'm considering a move, not due to dissatisfaction, just that the whole of the rest of my system has moved on, and I'm curious re alternatives.
