ARC or Pass Labs preamp for XA60.5 ?
BlackTT
5
Maribor, Slovenia
Hello everyone,
I am buying used preamp for my XA60.5 and have two options at price about 8K€:
Audio Research Reference 5SE
or
Pass Labs XP-30
Right now I have nice self made tube preamp, but would like to go fully balanced from my Marantz NA-11S1.
Can you share some opinions-diferences between this two preamps and wich would be better for my system...
Thnx & best regards from Slovenia...
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
A lot can be said about using pieces from the same manufacturer. That said, I'm keeping my XP-30
BlackTT
5
Maribor, Slovenia
Thank you Bruce B...
Just wondering... Did you hear them side by side?
budda
22
Norway
I am very happy with my XP30 :)
BlackTT
5
Maribor, Slovenia
That is nice to hear budda... Did anyone on this glorious forum had both of these preamps at home...
Now really leaning towards xp-30... No tube troubles... :D
budda
22
Norway
No tube troubles and can stay on all time so you don't need warm up time :)
Frank750
821
1
928
I had both and both are great preamps. I preferred the Ref 5 with ARC amps but chose the XP30 when I decided to go with Pass Labs amplifiers. I preferred overall performance of the XP30 over the ARC REF5SE and ARC REF40 in combination with Pass amplifiers. I've since changed to the Pass XS pre.
BlackTT
5
Maribor, Slovenia
Thank you very much for your replay Frank750... I guess that's it then... :D
XS combo must be great... ;)
Did you try some difrent fuses then stock on amps & preamps...
Furutech blue fuse with cryo treatment maybe...
MadFloyd
775
1,700
Mass
I've also owned the Ref 5 and the XP-30.
They are very different beasts. ARC has a 'house' sound that is, to my ears, very elegant, pleasant, but a little white-ish sounding. Very fluffy sound - especially evident on piano.
The XP-30, to my ears, has very little coloration, will produce much better timbre (especially in the bass), but imaging will be little more flat than the Ref 5.
Tubes versus solid state; really depends what type of sound you prefer.
BlackTT
5
Maribor, Slovenia
MadFloyd thanx for your replay... You have really nice setup with Magico S5's... That is on my future list...
I like tube sound but in the long run I wan't to have preamp for life... No troubles...
It's very hard to move stuff in Slovenia for right price... Like you got married, hard to break up... :cool:
