according to their website:are there any Atma-Sphere dealers in Norway?
I run Powersoft class D from 550 and down and all out BP designed 300B monos from 600 and up on TAD TD-4003 in custom Norwegian CD horn
tried First Watt SIT-1s on 4003, but they didn´t "cut it"
close, but no cigar as we say over here.....ha-ha
BP designed 300Bs?are there any Atma-Sphere dealers in Norway?
300B monos designed by my friend Gary Dews of BorderpatrolBP designed 300Bs?
Those sound cool. What is your opinion of the Horning SATI 520b amp, which uses those same type of transformers?300B monos designed by my friend Gary Dews of Borderpatrol
Tommy Hörning SATI nanocrystalline interstage and SATI Litzwired nanocrystalline OPT
this shop doesn´t exist any longeraccording to their website:
Norway
Loddefjord HiFi
Gamle Mathopsvei 22b
5173 Loddefjord, Norway
mob.phone: +47909 92 551
Kjetil Melvik
Initially we did think that they needed less burn in time than our tube amps, but even early on it seemed more than just a couple of days. Feedback from the field suggests that isn't the case- the time seems to be about the same. Given how very different the circuits are, the commonality seems to be filter capacitors in the power supply.'Mr. Atma-Sphere'--I was looking for reviews of the A-Ds and ran into someone writing that YOU wrote that these amps require very little burn-in, as in only a day or two? Is that your opinion?
Mine have been running 24/7 since Jan. 24--about 400 hours--and still sound excellent; I guess I can stop that.
...umm..'about the same' as what? Your tubed amps? 'More than just a couple of days'?Initially we did think that they needed less burn in time than our tube amps, but even early on it seemed more than just a couple of days. Feedback from the field suggests that isn't the case- the time seems to be about the same. Given how very different the circuits are, the commonality seems to be filter capacitors in the power supply.
TYVM; at 400 hours, I'll be finished burning in the Ds.. Have reinstalled the PS Audio M1200s to 'warm them up' a bit before comparing them with the Ds.Yes.
