that is certainly helpful and might alleviate the situation. How does it look in the bass? Are there any peaks?It is quite high and flat (never below 6 ohms)
Well said, this is one of the reasons I stopped with tubes. I want my system to sound as close to the same over a long range of time. And listening to a beautiful set of NOS tubes slowly die took a lot of the fun out of it for me.Then there is the constant moving target of tubes as they age. You may get a set of tubes that you love the sound of. But if you use your amps as regularly as I do, the sound will noticeably change over time and not for the better. After a certain amount of use it’s time to re-tube your amps after which they will sound different again and the moving target of aging tubes repeats.
You think solid-state dos noy age, albeit at a much slower rate? As that is always the question/ A candle that burns brightest extinguishes more quickly.Well said, this is one of the reasons I stopped with tubes. I want my system to sound as close to the same over a long range of time. And listening to a beautiful set of NOS tubes slowly die took a lot of the fun out of it for me.
Thankfully, my Class D is not candle-powered. If it lasts for 10 years without deterioration, that's good with me as I'm likely to have changed it before then. Class D is still evolving (now more slowly, unlike other amp types that matured decades ago), so I'm now enjoying an amp that betters my previous SETs and I'm looking forward to even greater things in the future.You think solid-state dos noy age, albeit at a much slower rate? As that is always the question/ A candle that burns brightest extinguishes more quickly.
They do. They sound really similar. I do think though that tube power amps are currently on borrowed time- why bother with them when you can get sound just as good and not worry about tube replacement?? The war in Ukraine certainly isn't helping...Ca n they coexist, or will they fight it ut to the death in a cage match?
The maker of a class A OTL tube amp hails the virtues of his class D amp which is the antithesis of his current line. Does one have to die, or can they peacefully coexist?
Transistors can corrode over time. Anyone who has renovated older solid state gear knows that! The industry has improved that issue over the decades- it appears that newer semiconductors do last longer since going to surface mount. It certainly helps that there is less heat in class D circuits. Class D seems to have the advantage that if the amp is well built, it will always be worth renovation (which will be likely about 30-35 years down the road; filter caps last longer when there's no heat). So I don't see that as a problem.I know plenty of people having to recap SS electronics at some time. Of course, the same applies to tube.
I'm not sure about the transistor. Does it burn out over time. What I have heard is when you loose a transistor, its not at all a simple swap. Its a big deal to get matched and they may not be made any more.
I.wonder the total life span of a SS vs tube amp before you have to throw it out. How many years do either run before the cost to refurbish is beyond getting new.
Preamps may be a little different. Especially with tubes. About 6 month ago I tried a fresh pair of Telefunken E88CC in my First Spund MK11SI. They sounded exactly the same as the original pair I have had in for 5 years or so. I have 4 pair as backup so I'm feeling pretty good my preamp.
Not really breaking news. The coming of age of Class D means that other types are already on borrowed time, although this was probably not true 5 years ago. It will be even more true in 5 years time when it will be really difficult for tube and Class D builders to sell their costly kit in the face of obviously superior and much more cost-effective Class D kit. It's enlightening that at least one well-respected tube amp builder has seen the writing on the wall. Hopefully others will follow."They do. They sound really similar. I do think though that tube power amps are currently on borrowed time- why bother with them when you can get sound just as good and not worry about tube replacement?? The war in Ukraine certainly isn't helping..."
Atmasphere
Thats breaking news!
I've been watching class D for over 20 years. I realized then that is was a rising star and like most technologies is on a Sigmoid cost/development curve. I realized about 6 years ago that we are very nearly at the top of that curve so it was obvious it was time to sort things out. IMO any audio manufacturer that hasn't sorted out class D will get left behind.Not really breaking news. The coming of age of Class D means that other types are already on borrowed time, although this was probably not true 5 years ago. It will be even more true in 5 years time when it will be really difficult for tube and Class D builders to sell their costly kit in the face of obviously superior and much more cost-effective Class D kit. It's enlightening that at least one well-respected tube amp builder has seen the writing on the wall. Hopefully others will follow.
I think the simple answer is just to arrange a home trial of a couple of top-drawer Class D amps. Sadly, I've not yet had the opportunity to hear the Atmosphere monos, but I do use an amp featuring the Purifi Eigentakt technology. This is considered by most as the best out there and certainly I've not heard better.I know I am asking a lot here. Its just such a hurdle to go from the accepted "Audiophile" world of high performance (whatever that means) with atmospheric pricing, to a new topology that is suppose to be as good or better for $6K or so.
Tubes were declared 'obsolete' in the 1960s when germanium transistors were really the only game in town. Obviously the declaration was premature. Then silicon came in, but we still had the problem of 'turn it up and it sounds bright and harsh'. The measurement/numbers guys spent 50 years trying to convince us that solid state was more natural. Obviously brightness and harshness is every bit a coloration and IME more dastardly than that of the warmth of tubes caused by the 2nd and 3rd harmonics.The decline has been predicted since before I was an audiophile. Instead even SET has made a Renaissance. I am not concerned.
The sound of the module has to do with its topology (and there are a lot of differences there), how much feedback it runs, how the feedback is implemented and how well its able to not have noise from parasitic inductances. GaNFETs have the advantage of really reducing stray inductances in the output since they literally have no leads. Because of their low gate capacitance they are easier to drive as well so the risetime and shutoff slopes are a lot steeper. So if you're careful a very low noise module can be created. If you read the early parts of this thread you'll see that we didn't know if we were passing the EU standards for noise so were reluctant to talk about export. But as it turned out when we were finally able to get testing it was no worries.How much of the sound of a class D amp is attributed to the GaNFET output transistors, Exclusive Atma-Sphere class D module, case and/or other components.
Where does the upgrade path start? As in, what is still being assessed to improve upon what we hear from these amps. Or how will you make them sound as natural as possible and up the power to say 300 or more watts.
Do you think in a blind test a group of people could tell the difference between monoblock amps like Boulder/Gryphon/Dartzeel? What would they hear different after living with them for a month or so.
Do you add in some color to keep an amp from being sterile. To flat and perfect?
I have been wrestling with this idea that maybe I like some degree of distortion or frequency bumps. I am not sure if some amount of deviation from a perfect amp is required to create a more natural sound???? Sure that sounds stupid on the surface. At times I feel I have heard a better violin or piano in my system, but other parts of the whole were wrong enough to make me move on. I notice this more dramatically when I used a horn speaker where the violin and brass instruments were fantastic, but the Harpsicord was buried. When I changed to a Coax with a paper driver and only a horn high, the harpsicord came out and stands as it should, but the violin and brass don't have quite the alive and up front I was hearing before.
One clean presentation would be much appreciated.^^ I'm sure it is. And I'm open to it.
I had to reread this thread to see if I had made some of the explanations here; turned out I'd done very little. When I got done, it was about time to head home. I'm not sure if I should try to collect all the different posts I've made or just write up a paper trying to cover all the various aspects of this topic and simple provide links to it.
Just to show you I was paying attention professor.^^ I'm sure it is. And I'm open to it.
