does the ref 6 have teflon caps?
doesn't look like it from the pics but not 100% certain.
I dropped the ball today and ordered a Ref 6 my first Audio Research product. I should see it in time
for the weekend
I have purchased new Audiodharma Cable Cocker. In the meantime I`m asking myself if the result will blown me away with the speaker-Capacitor burn-in , maybe I should also burn the capacitors of my new Preamplifier the Audio Research Reference 6 ? Thake them out and burn properly on the Cable Cocker ;-) Just a thought, the unit sounds great imho. I like soldering and make some test ;-) Does anybody know somebody done that ?
This is crazy - if you want to burn-in them just get some wires with alligator clips. If the preamplier is turned - off, the capacitors are in a medium -impedance state as the cathode resistor is around 10 kohm and the other wire of the capacitor is grounded by the mute relay.
