Good luck Joe. Looking forward to reading about the Strads when they finally land in your system.
+1!
I first auditioned my then SF Guarneris against 2805 first. In my own personal opinion, I was happier owning the Guarneris (which I eventually traded back in for Strads) than I would have been with the 2805s. That was a real shocker for me. There was something just that bit more tangible in the strike of the notes with the Guarneris than the 2805s (not the 2905s which I found superior for their stronger/fuller presentation).
That was again a very big surprise...and took me down the road of the dealer bringing out the 2905s for a few hours...and then the Strads. Took all day.
And that was when I realized that with the right amplification, the Strads did most everything the Gs did...but with FAR, FAR greater scale, authority, control and delineation. I was most surprised...I found quite a bit of smearing in the lower mids/upper bass with the wrong amp...but when they switched to bigger ARC monos...that all disappeared. I ended up with the Strads as my favorite for that day...and then went back to match them up against the Maxx IIs a few weeks later. I also heard the Elipsas in between. The shootout results with the Maxxes were that the Strads had a sound I preferred though I knew it was a sound designed by Serblin...but it did not have the all-out power of the Maxx IIs when pushed...but had maybe 75% of the full-out Maxx power and drive...which at the time was more than enough for me, given that I had a sound I loved in the SF Strads.
LLoyd, an interesting observation of the differences between Strads and G's. I do think that the Strads in a BIG room will easily have more scale and authority than G's. However, if one matches up G's with a good sub, which I think is mandatory in order to get anything below about 50hz, then the scales tip back to the G's, IMO. I think the G's and particularly my GH's are more coherent and slightly cleaner with better delineation up top than the Strads and with a sub, as stated, more revealing.
Micro, have you tried this near-field listening in a smallish room?
Look, let's not kid ourselves here no matter how some wish it to be true about mini-monitors pulling off feats of magic in small rooms vice large systems in large(r) rooms. Assuming both systems are set up correctly, a large system in the proper sized room is going to do things that mini-monitors even with subs just can't pull off. The scale of the soundstage in all dimensions will be smaller, and the midbass and upper bass will certainly be lacking in power by comparison.
In summary, a large scale speaker system set up correctly in a proper sized room is going to whoop ass on a pair of mini-monitors (and I don't care who makes them). You can fool yourself and think that the sound you are getting in a small room with a small system is just as good as a large system in a large room, but the reality is that you are listening to a small system in a small room that isn't moving much air. Moving lots of air is a key ingredient to true realism.
I have found this to be true also. However, I have heard the large Magico Q7 and the mighty Wilson XLF in very well designed rooms with great amplification. Sure the scale was large and the sound was dynamic, but the imaging was also large, and in fact I found it unnaturally so. Vocals came from HUGE heads, stand up bass was the size of a piano. These systems sounded great for large scale orchestral music, but for smaller chamber or solo acoustic music, it just was not believable. Perhaps it was the systems and set ups, but for smaller scale music, I prefer a high quality mini monitor based system, especially in smaller rooms.
The Q7 driven by Spectral at the local dealer clearly has the ability to sound small, big and anything in between, including properly sized vocals and instruments - I haven't heard such things as "huge heads", in fact, just the right size - and I have commented about this in past postings in detail.
It's not supposed to sound that way which indicates something was amiss in the setup. People who own the big Wilson speakers talk about how they correctly scale image sizes in accordance with the recording. If your system produces "Fat Head" sized images on every recording with speakers that are known not to do that, you need to put on your Sherlock Holmes hat and grab your pipe and start investigating.
These weren't my systems, and I would not have felt comfortable asking why they did not sound right to me. And I'm no Sherlock Holmes. They were presented as reference caliber systems. I was just not expecting them to sound that way. I agree and I've read that Wilson owners describe the large Alexandrias as correctly portraying scale and image sizes in accordance with the recordings. You are probably right that something was amiss in the set ups and perhaps they will reproduce image size the way a really good small speaker can.
These were very large professionally designed rooms with high ceilings. I've seen photos of forum members' Alexandrias in rooms with very low ceilings, say 7'-6" or 8'-0" high. Perhaps the lower ceilings have something to do with it.
Thanks RJ,
I have not made any final decisions and still have some auditioning to do. Maybe with a few tweaks, my current gear will satisfy in the long run. Who knows. Good luck with your system my friend. Thank you for posting.
