I have a bay window in my living room/listening room. When I stand under the bay window it is very boomy - like sticking your head in a car trunk when music is playing. When I stand on a chair to put my ears closer to the ceiling/sofit of the bay window, it is much worse. Knocking on the ceiling/sofit tells me it is hollow.
I borrowed some cotton blow in insulation cubes from Home Depot and putting them on the floor helps a lot. But it is still very bad. So I don't think just sticking in bass traps is the solution. I need to attack the source of the problem.
I could do either
1) Blow insulation into the sofit to fill the hollow cavity.
2) Cut out the ceiling of the sofit and turn it into a bass trap
Would either of these solutions eliminate the boomy bass or is the nature of bay windows such that you can never eliminate this problem?
I am deciding whether to enclose this open living room and convert it into a dedicated listening room. But if I cannot eliminate that boomy bass, it would not be worth pursing. I would have to look at building another room, possibly in the garage.
I could do either
