It's really good to hear that you like your LPS MR so much. I am still amazed at what my old and long in the tooth Benz Ruby 2 can do. The LPS MR is a step-up over the Ruby 2, as such it must truly be a great cartridge. Since it is one of the very few cartridges that has somewhat adequate output voltage, which means I do not have to give up my tube phono stage, it remains high on my list for when I replace my Ruby 2. Whether it could compete against the latest designs from Zyx, Proteus and other remains to be seen, but since they all are favoring paltry voltage output, right now the Benz remains a contender. Too bad the other manufacturer's cannot seem to produce a cartridge that is SOTA and also has decent output!
3 of the 4 Zyx's I heard were with tube phonos, one was an Ear where we did the 4d vs LPS MR compare.
Very interesting! Mehrad tells me that the Zyx's seem to put out a lot more output than their numbers suggest. While this is good news, I am very concerned to try one of these cartridges with my CAT preamp and discover it will elicit too much noise. Whilst I know that there are higher output versions of many of the Zyx models, I have been told by a a'phile friend whose ears that I trust, that the lower output versions are the only ones with the magic. Did you happen to notice how much further up the gain curve you had to go with the EAR when listening to the 4d vs the LPS MR to match levels?
Zyx give their output for 3.54 cm.s instead of others builders wich give it for 5 cm.s.so you must convert results
I had been using Benz cartridges for years, taking advantage of the trade-in that Benz offered. About a year or so ago I switched to the Lyra Etna (.56) and have never looked back. Deeper bass, fast as lightning. and dynamic, big soundstage this
is a great cartridge. So, going from the Benz LP to the Lyra Etna was a major upgrade. I listen to classical and jazz vinyl. No digital.
The Etna really is an amazing cartridge. I once had the pleasure of being present at a comparison of four Lyra cartridges: Kleos, Kleos SL, Etna and Atlas side by side all mounted in one of four Kuzma 4Point tonearms on two Dr. Feickert Firebird turntables. This was quite an extraordinary experience, and it was hard to believe how big the step up from the Kleos SL to the Etna was.I had been using Benz cartridges for years, taking advantage of the trade-in that Benz offered. About a year or so ago I switched to the Lyra Etna (.56) and have never looked back. Deeper bass, fast as lightning. and dynamic, big soundstage this is a great cartridge. So, going from the Benz LP to the Lyra Etna was a major upgrade. I listen to classical and jazz vinyl. No digital.
Up until tonight, I have been using a LPS MR for the past 2 years and have loved it until I wacked the tonearm and it was never the same. I have an Aries 3D with a 12" 3D arm that seems to be quite sensitive with regard to the LPS.Not sure how you know this ( that others ( which others?) are measuring at 5 cm.s)? However, the Benz is measured at the same 3.54cm.s and still outputs 0.35mv, whereas the Zyx typically measure at 0.24mv. I suspect that the 0.11mv difference could be enough to push many tube phono stages into noise. Theoretically it is appx 1/3rd less output.
About 90 minutes ago I started listening to my new ZYX Universe Premium, but I also had my tonearm wire upgraded to Nordost by VPI so it is hard to tell what is the cartridge and what is the wire. My phono stage is a Lamm LP2.1, but I get plenty of output, but not as much as with the LPS. Although it is too early to tell what the cartridge sounds like, I already hear what I consider superior midrange and articulation, and impressive soundstage improvement, but no bass yet.
I will keep you posted.
+1Russ, please tell us your further thoughts comparing the LP-S MR to the ZYX UNIverse Premium.
One of the Benz Micro press releases refers to improvements in the LP S.
November 2014 press release: http://benzcartridges.com/benz-micro-update/
". . . advances in design and materials, have resulted in new Benz-Micro models that surpass all previous versions in music reproduction."
I just don't know what that means or how, if at all, these improvements make the new LP S different from the old LP S.
