Sorry...not always following your adventures...are you saying dual 18" cone subs (ie, pure cone no horn)?
No, horn loaded.
Thanks..so you anticipate a massive horn across 2 x 18" cones for each channel? Quite a sub! Presume that will physically be massive as well.
Awesome! That's dedication! Efficiency of space is the primary reason I have not ventured to horns...even the Elysian with its horn subs has a massive footprint, let alone your all out design. Well done...look forward to when you have finally got it all manufactured and built...been a long journey but imagine it will be well worth it when its finally done.
I gave you quotes of both retail and used
I am well aware of horn loaded woofers, but I prefer dual 15s or 18s. I also know that the horn loading amplifies by 6db.
Quite superior? I doubt that...Kevin Scott has decades of experience on this one design and you...very little I think. You have valid opinions on a lot of systems but the LV is not one of those I consider your opinion valid...you have an axe to grind there somehow...Sorry I won't have those subs. I was discussing for those who do, and comparing to LV which carries over woofer in the Midbass. These require space but is quite cheap, and will be quite superior to the LV. If I ever get a system, it will definitely have dual 15s in the Midbass. The slotted open baffle design does make efficient use of floor space, though not vertical space
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
