Best match for watt puppy system 8?
Farzad.r
7
44
Hello there,
I was just wondering which power amps would be a best match for w/p 8s?
I have already seen AR and pass labs would be a great match.
I am not a tube guy and will not be willing to empty my bank balance!
I was also thinking about McIntosh mc1000
Would be appreciated if any one can give me a real experienced suggestion?
Thanks
Lamm M1.2 Reference monos are one of the traditional pairings with the WP series. Levinson 3 series too.
Reactions: Sharp 1080
When I had mine, I was using arc ref 210’s and sounded really good. A ref75se should also be more than adequate.
Good luck with your search
Hello there,
Thanks
Compared to the various Sashas, W/P 8s has a stronger/more forward upper bass and mid bass.
I remember that at that time the best matching ss amps were from Spectral.
When I had my wp 8's, I used Ayre MX-R's....Great amps
Thank you Nemal for your suggestion. The issue is that I not really into tube amps. And a bit biased toward SS. BTW, it is a chance to think about AR also.
Dear Keung, it was so helpful. Thank you
Give D'Agostino a try.
If you are so inclined most of the big ticket ss esigns will work.
I have heard
Solutions,Boulder and Mackintosh...
When I owned Watt/Puppy 7's I drove them with a Mark Levinson 335 stereo amplifier. I sold both to upgrade equipment. I have heard them on both tubes and solid state. They were really good sounding on the smaller VTL monoblocks. It has already been mentioned that most solid state amps will work. Good luck in your searching.
Sharp1080 thank you for sharing your experience
