Hi Fishfood , I forgot to also post this website - " Glow in the Dark Audio " the fellow there has tried Over 30 fullrange drivers and his favorite for for a long time were the - Vintage Zenith 49CZ852 drivers....
But then after several years he put them up after he found these - F15 speaker drivers --
Glow in the Dark Audio showcases Kevin Davis’ personal collection of small-scale, DIY and one of a kind hifi audio gear, with a focus on single ended and push pull tube amplifiers and full range open baffle speakers.
glowinthedarkaudio.com
-- and here is the Decware ZF15L Speaker on YouTube:
To Continue - the company Lii Audio also makes Another REALLY Great driver called the - Silver 10 , it is a Very clean sounding driver and it is a Very Detailed speaker driver - it sells for -- $ 1,199 a pair .
Here is one look at a Speaker that uses it;
http://www.modelpromo.nl/The Liiondias Open Baffle Speaker.htm
- And if you don't have access to wood working equipment, or know someone , you can buy it all ready Built ...
- LII Audio sells the Pre- built speaker and Crossover for - $ 800 , then you order the drivers - the Silver 10 - $ 1,199 , and the F18 bass driver - $ 520 a pair ... and just screw in the drivers into speaker baffles...
----- So about - $ 2,500 for a pair of Amazing sound speakers !!!!!
( the F18 speaker driver is a 18 inch bass driver designed by Lii Audio for their Open Baffle speakers )
Here is the link to Lii Audio's , Pre- Built Speaker:
https://www.lii-audio.com/product/p...drivers-simple-and-musical-complete-solution/
The same driver is also sold at Decware in their ZC10M Open Baffle speaker design - !!!!!!!!!
- ( and there is an audio company called Caintuck Audio who came up with the best baffle shape for those Lii Audio drivers ....
This is the decware design:
https://www.decware.com/newsite/ZMS3.html
- You can Listen to the Silver 10 Driver , playing on the smaller Caintuck Open Baffles , with One W18 bass driver...
( If space is really important Steve also sells and uses their ZROCK2 - Bass Restorer , in place of a second driver to add more bass to the 10 inch driver! )
-- If you did get a chance to read the links I posted earlier for the ZF15L Open Baffle Speaker ... on - " Steve's BIG BETSY project " - his Prototype Speaker Build then you will have read how Impressed Steve is with Both the F15 speaker driver and the Amazing Silver 10 speaker drivers - !!!!!!!!!!!!!!!
-- ( here are the two forum links )
https://www.decware.com/cgi-bin/yabb22/YaBB.pl?num=1561942815
https://www.decware.com/cgi-bin/yabb22/YaBB.pl?num=1616372005/7
- ( With the Silver 10 driver to get the added detail you give up a some of the bass that you get in the F15 speaker driver , so you will most likely need an added woofer like in the Liiondias or some EQ to get the bass that many people are looking for - there are a number of units that you can use for the EQ like miniDSP, or Decwares ZROCK2 Bass restoration unit ) -
-- here is another way to add the Bass Driver that is a pretty good looking alternative
- the speaker set up there is made by Geno - a Decware forum member , if you would like to listen to other kinds of music on the Silver 10 speaker Geno has more videos here:
and Steve has more Music and better recordings here:
Now moving on to another set of Speakers to look at ...
FIRST is the NX-Otica , which a NEXT Level Speaker - !!!!!!!!!!!!!!!!!!
-- the folks have heard this said you haven't heard a Great Speaker until you have heard this Speaker... !!!!!!!!!!!!!!!!
https://www.youtube.com/watch?v=d0Pnm1Ea9M8&ab_channel=NewRecordDay
The Speaker kit is - $ 3,100 - ( plus possibly the Servo subs depending on your room ..... and how much bass you need / want you can always add the subs later) .
https://gr-research.com/product/nx-otica-2/
- - - WHEN Ron at New Record Day heard these he couldn't believe they were this good for the money!! - this speaker will out perform MOST of the other speakers mention here - !!!!!!!!!!!!!!!!!!!!!!
- don't worry - it's a simple kit to put together and doesn't take very many tools ... there are lots of tutorials and videos on how to do it and lost of help available - from both GR Research and from the all of the other Forum members over on Audio Circle that have built Gr Research kits - !!!! , which is a lot of folks...
------ If you don't have good subwoofers then GR Research offers Great Subwoofers:
- For the Servo subs - These are some of the best subwoofers available on the market and many other speaker companies use GR Research subwoofers for thier speakers!!!
- the Dual Subwoofers are about 3,100 are what Ron was using for Subwoofers : but you can add either single, dual, or triple Servo Subwoofers
- Duals subs - That's two sets of two - 2 x 2 ..... they are 1,700 + 600 for the flat pack of MDF so - $ 2,300
- single Servo Subs - 1 x 2 are - 1,400 ,
- and triple Servo Subs- 2 x 3 are - 3,100 + 800 = about $ 4,000 ,
I didn't see the single flat packs but I'm sure they are available too.
https://gr-research.com/sub-series/
- Flat Packs -
https://www.audiocircle.com/index.php?topic=139480.0
The Next Speaker is right up there with the NX-Otica's -- !!!!!!!!!!!
it is here --
https://www.youtube.com/watch?v=YHv9wBB3bjw&ab_channel=NewRecordDay
--- Spatial Audio Lab , M3 Loudspeakers - These are Amazing Speakers !!!!!!!!!
https://www.spatialaudiolab.com/product/m3 - $ 5,500
https://www.youtube.com/watch?v=pbH9wWr-Xrw&ab_channel=NewRecordDay
https://www.youtube.com/watch?v=iFQKGaxfIJk&ab_channel=NewRecordDay
--- Lets chat -
https://www.youtube.com/watch?v=DS3tGbPtXaE&ab_channel=NewRecordDay
Next up - Qacoustics : Concept 500 Loudspeakers...
https://www.youtube.com/watch?v=V3YkZx7Cbyc&ab_channel=NewRecordDay
***** Five Stars from what HiFi ---
https://www.whathifi.com/us/q-acoustics/concept-500/review
Hi Fishfood, I Hope I haven't freaked you out ... with all of this... (
-- I still have a couple of REALLY GOOD suggestions coming up so please don't make any hasty decisions .... we touched on Full Range options , Two major Open Baffles, Totem Custom made drivers , dreamed of Sonus Faber Loudspeakers .... Then the 500's ---- Next up is several unique Ideas - not to be missed - !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so I need to go, dinner is on it's way in , ...... so later tonight or tomorrow , and I will be finished , I think - LOL
Kind regards, Dean
